WilzGarage
RacerPartsWholesaleChainDrain.comNice CycleAdvanstarMotorcycleShowsBazzaz PerformanceSpringfield ArmorySoloMotoPartsSportbikeTrackGearMotorcycle.com Classifieds!KomodoGear.comArnottAirRideJazzMotorsports.comSumOfAllParts.netSee your ad here!
Old 05-30-2008, 08:37 PM   #1 (permalink)
mcwtrainer
Casino Cash: $2762
Sportbike: 2007 Kawasaki ZZR600
mcwtrainer is on a distinguished road
Default Chain too tight?
My chain from when I bought it last June has not loosened up at all and I'm afraid it might actually be too tight. Should there be any slack at all in the chain? I can push down on the chain and it doesn't go anywhere...
Whatcha think? Do I need to buy a bigger chain even though the one I have on is stock and not even a year old?
mcwtrainer is offline   Reply With Quote
Old 05-30-2008, 09:00 PM   #2 (permalink)
ZZRrocket
MODERATOR
ZZRrocket's Avatar
Casino Cash: $30597
Sportbike: 2004 ZZR1200 R.I.P. 2006 Kawasaki ZZR600
ZZRrocket is on a distinguished road
10-4 Final Drive (Service Manual Part No.99924-1254-04)
Chain Slack
Standard: 30-35mm(1.18 - 1.38 in.)
SBN KAWASAKI FORUM MODERATOR
USAF VETERAN 1984-1997 SUPPORT OUR TROOPS THEY ARE THE REASON YOU ARE FREE TO RIDE THE OPEN ROADS OF THIS GREAT COUNTRY THE ANSWER GURU The 2005-2008 ZZR600 are exactly the same except for paint color. Having trouble finding parts for your 2005-2008 ZZR600? Try searching for parts that will fit a 2000-2002 ZX6R "J" model.
ZZRrocket is offline   Reply With Quote
Old 05-30-2008, 09:12 PM   #3 (permalink)
Liquelo
Casino Cash: $4596
Sportbike: 2007 Kawasaki zzr600
Liquelo is on a distinguished road
Maybe you've discovered the chain's tight spot, there should be one place on the chain that is tighter than anywhere else you check provided you are pushing at the right spot. Are you putting pressure on the chain where the book recommends? How many miles on the clock? There should always be SOME play!
Liquelo is offline   Reply With Quote
Old 05-30-2008, 11:40 PM   #4 (permalink)
mcwtrainer
Casino Cash: $2762
There is only like 1500 miles on it. There's literally no play no matter where I push on it. I just find it odd that the chain didn't loosen up at all since I've had it.
Old 05-30-2008, 11:42 PM   #5 (permalink)
brandon2286
EET FUK
Casino Cash: $25590
Sportbike: 2007 KAWASAKI zzr600, 99 Husky Wr250 2smoker
brandon2286 is on a distinguished road
well loosen it up and get it into spec and see what happens? i check and lube mine every 4-500 miles
Street Ridden...Track Bound
brandon2286 is offline   Reply With Quote
Old 05-30-2008, 11:52 PM   #6 (permalink)
Liquelo
Casino Cash: $4596
Yeah man, I have never seen a chain do that. Set up too tight at the factory? I don't know but a little loose is always better than way too tight which sounds to be the case with your chain. For sure adjust it.
Old 05-31-2008, 07:43 AM   #7 (permalink)
lecchilo
lecchilo's Avatar
Casino Cash: $16379
Sportbike: 2007 Kawi zzr600
lecchilo is on a distinguished road
+1 to what they said... as a very very general guideline for you, if you look go low on the ground and look at the chain directly from the side, and look directly at where the swingarm meets the front of the rear wheel (in your view not actually touching it of course) you should be able with pretty little force push up on the chain at that point and touch the swingarm... again, this is very general, but if you can't push up on the chain and touch the swingarm from that point, or another point on the swingarm moving toward the front of the bike, the chain is way too damn tight... hope that helps
-Ivan
LUSTR Auto Detailing
lecchilo is offline   Reply With Quote
Old 05-31-2008, 10:08 AM   #8 (permalink)
mcwtrainer
Casino Cash: $2762
Thanks for the feedback everyone. I'm still new to this... How do I loosen the chain?
Old 05-31-2008, 10:23 AM   #9 (permalink)
Liquelo
Casino Cash: $4596
down load the manual from the sticky on top. Find someone who has done motorcycle chain (aka final drive) adjustments to help.
Old 05-31-2008, 11:32 AM   #10 (permalink)
adamp961
adamp961's Avatar
Casino Cash: $18202
Sportbike: 94 CBR600F2 - sold, 99 ZX6R Wrecked (deer), 07 ZZR600 - sold
adamp961 is on a distinguished road
Drive over to my house and i will help you!!! See you in a couple of days
adamp961 is offline   Reply With Quote
Old 05-31-2008, 12:14 PM   #11 (permalink)
Liquelo
Casino Cash: $4596
NO! Not while your chain is still that tight!
Old 05-31-2008, 02:33 PM   #12 (permalink)
mcwtrainer
Casino Cash: $2762
Wish I lived closer...
Old 05-31-2008, 03:06 PM   #13 (permalink)
lecchilo
lecchilo's Avatar
Casino Cash: $16379
mcwtrainer... you'll need to start with the right tools...
go to your local car shop and buy (if you don't own it obviously):
1. 1/2" 10-150 (or something close to those numbers) torque wrench
2. 1/2" breaker bar (long bar with the ratchet tip to go into the socket)
3. 1/2" 32mm socket
4. screwdriver (for little screws on chain cover and also to push chain up when measuring)
5. 12mm (I think, but might be 11mm, damn it I should know I just adjusted my chain haha) small wrench for the adjusting bolts/nuts
6. a few cotter pins (buy either from dealer, online store, or just find similar ones at your local hardware store)
7. and you'll need some regular tools like pliers, etc. just to bend the cotter pin, pull it out, re-bend it later when putting in the new one, etc..
I think I covered everything
To adjust the chain:
1. take out old cotter pin
2. loosen the axle bolt (just enough so you can pull the wheel back and forth, not completely)
3. loosen the adjuster bolt nuts on both sides (the nuts that are tight against the swingarm, away from the axle)
4. turn in both adjusting bolts and push the wheel in(towards the front of the bike) so that the little plates around the axle are pushed up against the adjusting bolts
5. make sure the marks on the swingarm and those plates line up pretty evenly on both sides
6. tighten the adjusting bolt nuts then re-check the markings after you push the wheel again
7. tighten the axle nut pretty well (so wheel cannot move) while pushing the wheel forward so the adjusting plates are pushed up against the adjusting bolts
8. stand up, pull the bike up straight, then bounce it a bit to move suspension and also push it forward, while in gear, to seat the chain/wheel properly (simply push the bike so it stops due to it being in gear)
9. check your chain slack... I like to check mine about the point I mentioned above (right where the front of back wheel meets the swingarm when looking from the side) because there when I push the chain up and it's the right slack it doesn't hit the swingarm too much towards the front... I might be making this complicated... basically I do it here because, if you can imagine, when I push the chain up anywhere towards the front of the bike from this point, the chain hits the swingarm, so you should do it towards the back to get the chain to fully stretch.
10. repeat steps 2-9 until chain is at right slack (every time I adjust mine I try to do it to about 33-35mm, which is kinda the minimum allowed, just so I don't have to adjust it for a while, but you do what you want)
11. once it's the correct slack, and all the alignment marks on swingarm and adjusting plates are pretty much lined up, tighten the axle nut to 90-95ft-lb, insert new cotter pin (put longer side away from the bike, then bend into the bolt hole, and bend the smaller side that's toward the bike simply back against the bolt side)
12. RIDEEE
-Ivan
Old 05-31-2008, 03:09 PM   #14 (permalink)
lecchilo
lecchilo's Avatar
Casino Cash: $16379
Forgot to mention... when I see my chain needs adjusting, I always clean it off with Kerosene before hand, adjust it while the Kerosene completely dries off, then when I'm done adjusting spray it with Maxima chain wax... 2 birds 1 stone I guess
-Ivan
Old 05-31-2008, 03:22 PM   #15 (permalink)
adamp961
adamp961's Avatar
Casino Cash: $18202
speaking of 1/2" torque wrench
I bought one at harbor freight a couple of weeks ago for 12.99
Harbor Freight Tools - Quality Tools at the Lowest Prices
and when i got back to work, we torqued something with our high dollar Snap on torque wrench then the harbor freight wrench
suprising the cheaper harbor freight wrnech was spot on and it looks to be very well built
Picked up that 99 CBR F4 yesterday but I think it needs a chain sorny General Sportbikes 10 03-16-2008 06:38 PM
Chain Maintenance JustWondering General Sportbikes 33 02-08-2008 11:05 PM
First time - Cleaned, Lubed, Adjusted my Chain jasonn General Sportbikes 17 01-28-2008 03:12 PM
DuPont Teflon Chain Lube PCHbreeze General Sportbikes 38 06-02-2007 11:06 PM
change your chain and sprockets advr4 How-To's Section 6 03-21-2006 03:02 PM
