Motorcycle.com Classifieds!
Allstate
Soupy's PerformanceSportbikeTrackGearBritish Motorcycle Gear AdvanstarMotorcycleShowsBikeBanditMotorcycle.com Classifieds!McCoyMotorsportsSee your ad here!
Old 03-11-2008, 12:10 AM   #1 (permalink)
GravelHatesMe
GravelHatesMe's Avatar
Casino Cash: $9903
Sportbike: 2005 ZZR600
GravelHatesMe is on a distinguished road
Default New Rider Bites it and Needs help
Hey guys,
I'm a new rider and my '05 zzr600 was my first bike. I had it for about a week when i bit it on some gravel in a parking lot ... of all places. I was going about 5-10 mph, but pretty much everything that bolts on the left side of my bike needs to be replaced.
Does anyone have any tips on where i can get some good prices on these items? I've looked on e-bay and some other sites, but I was curious if anyone knew of some reputable places that had cheap parts.
I need a lower left ferring, front LH peg bracket, handlebar clutch lever, left mirror, left signals, and i cracked the cover to the oil (the bolt on, finned cover on the LH side).
Also, any tips for things I should ahve looked at before I start it back up and get on?
Any help is appreciated.
GravelHatesMe is offline   Reply With Quote
Old 03-11-2008, 12:21 AM   #2 (permalink)
Scootimus
Scootimus's Avatar
Casino Cash: $20625
Sportbike: 2007 Kawasaki ZZR600
Scootimus is on a distinguished road
Hey gravel welcome to the forums. I'm not sure about he replacement part other than e-bay but I know there are some guys on here that have had to replace plastics and gotten them from other places.
The cracked cover for the oil is the stator cover. My buddy had the same thing happen on a slow laydown. Those things don't seem to take much to crack. He snapped a bolt while trying to take it off and ended up going to the dealer to have it replaced. Good luck with the repairs.
Scootimus is offline   Reply With Quote
Old 03-11-2008, 12:24 AM   #3 (permalink)
rayzzr
World 500 GP Racer
rayzzr's Avatar
Casino Cash: $31351
Sportbike: 07 Kawi ZZR 600/06 Kawi KLR650/05 Kawi ZRX1200
rayzzr is on a distinguished road
Total Awards: 4
Check with local bike salvage shops if you have such a thing close to you. Lots of time you can get good prices and great service from those guys. When I was riding 17 years ago the same guys were working at that shop. Not many dealerships can claim such tenured employees.
As for things to check before riding off after a crash:
Yourself - make sure you are not seriously injured. It should go without saying, but with the adrenaline flowing you may not realize it at first.
The bike - check for where the bike is - is it safe to leave it there? If in a road get out of the road asap.
Check for leaking fluids - oil/gas/coolant.
Check the brake reservoirs - are they between the lines?
Check the frames for obvious cracks.
If the levers are damaged, are they still functional?
Check the lighting - do the lights still work?
Check to see if the bike will start, and listen for any unusual sounds.It is not unusal for a bike to be flooded after a get off like that.
If bike is started, watch for anything usual - change in idle, engine missing, engine sounds, charging issues, temp issues.
< Where me and the bike have been
"Is it bright where you are, and are the people changed, does it make you happy you're so strange?"
rayzzr is offline   Reply With Quote
Old 03-11-2008, 12:25 AM   #4 (permalink)
Jswartou
vvrrrroooooommmmm
Jswartou's Avatar
Casino Cash: $8999
Sportbike: 2008 ZZR600, 2003 YZ250F
Jswartou is on a distinguished road
are the plastics shattered?
if not, you can body fill, sand, and paint.
the Magnesium cover you can find on ebay.
USAF Security Forces
Jswartou is offline   Reply With Quote
Old 03-11-2008, 01:06 AM   #5 (permalink)
GravelHatesMe
Casino Cash: $9903
thanks for the heads up on the terminoligy scoot, i'm a bit new to this and wasn't sure what to call it.
the lower front isn't shattered, but it's scraped up pretty badly so I'm thinking I may look for a new one. I've only seen unpainted ones on e-bay for about $250, but I'd rather buy a prepainted one (is that possible since the 2005 was only one color?). Does $250 sound right?
The rear plastic though just has a thumb sized spot on it that was scraped, maybe i could touch that up. Is it hard to touch up paint and make it look okay?
Old 03-11-2008, 02:33 AM   #6 (permalink)
Grimy
Grimy's Avatar
Casino Cash: $8824
Sportbike: 2006 Kawasaki ZZR600
Grimy is on a distinguished road
Ron Ayers Motorsports - Motorcycle, ATV, Jet Ski and Generators Parts and Accessories
that should get you to a BLUE left side ferring. for 216.
I have repaired plastic and let me tell you what it DOES save you money but when done properly and after buying all the esential stuff you end up dropping like $80. And ALOT and i mean ALOT! of work.
1st Mar Div
USMC irrrrr
Bike - 2006 Kawasaki ZZR600 - SilverGoodies - Yoshimura RS-3 Stainless Steel Oval Bolt-On with Race Baffles exhaust, Goodridge Stainless Steel Front Brake Lines, Factory Pro Ignition Advancer 4 degrees, KN&N Performance Air filter, R&G Frame Sliders, R&G Racing Slider Bar Ends, Zero Gravity Dark Smoke Double Bubble Windscreen, MOTOTECK undertail with intergrated LED amber turn signals, MOTOTECK Flushed front LED turn signals, LED Brake Lights,
Grimy is offline   Reply With Quote
Old 03-11-2008, 03:10 AM   #7 (permalink)
GravelHatesMe
Casino Cash: $9903
thanks grimy. I'm going to try and get all this stuff ordered tomorrow. I'll do some before and afters. Thanks for everyone's help; I'm new to these forums and you guys are great.
Old 03-11-2008, 09:48 AM   #8 (permalink)
brandon2286
EET FUK
Casino Cash: $38088
Sportbike: 2007 KAWASAKI zzr600, 99 Husky Wr250 2smoker
brandon2286 is on a distinguished road
aside from all the good tips the guys here have given you, in the future just try to be VERY mindful of your surroundings. Its hard to avoid certain things like that and it does get the best of us from time to time. Hopefully you werent hurt, and this will help you be a little more mindful of what to lookfor when riding. Unlike a car where you can get away with not paying attention some of the time, you have to LOOK at EVERYTHING on a bike. Trust me on this, ALWAYS look to whats 5-10 seconds ahead of you coming up, and if you are unsure proceed with the utmost caution. Hope this helps, get that thing fixed up and ride on, and good luck!
brandon2286 is offline   Reply With Quote
Old 03-11-2008, 03:32 PM   #9 (permalink)
fallclassic02
DIG OUT YOUR SOUL
fallclassic02's Avatar
Casino Cash: $5604
Sportbike: '05 Kawy Zzr600
fallclassic02 is on a distinguished road
Gravel, any pics of the bike you can post?
2005 CRF 450r
1989 JS 550
I miss the two-stroke!
fallclassic02 is offline   Reply With Quote
Old 03-11-2008, 03:37 PM   #10 (permalink)
OreoGaborio
Cheap Bastid
OreoGaborio's Avatar
Casino Cash: $41208
Sportbike: See sig.
OreoGaborio is on a distinguished road
From what i've heard through some friends, EmpireGP.com does excelent plastic repairs.
And it's "fairings"!!!!
Keep your eyes on ebay for the other parts... Anything from a 98-02 ZX6R will work for just about all of those parts.
-Pete
LRRS/CCS #187
Racer for ECK Racing, RiderCoach for Ironstone Ventures and Instructor for Tony's Track Days
Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsports | Motorcycles of Manchester | BostonMoto-Pirelli
Member of New England Street Riders, SV Racer Forums
My "Resume" | The Garage : '03 Aprilia Tuono (Street Hooligan) | '06 SV650 (Race)
OreoGaborio is offline   Reply With Quote
Old 03-11-2008, 04:19 PM   #11 (permalink)
GravelHatesMe
Casino Cash: $9903
I just hate throwing my fairing out. It's in good shape, not cracked or anything, just scratched up in an area. EmpireGP looks good, but I think between paying for the work and shipping, i'd probably be better buying a new fairing and trying to sell my old one cheaply.
I looked at some of the topics regarding repainting panels and it's way above my head to do it properly.
Edit: Okay found the camera - I've already taken most of it apart, but you'll get the idea. Like I said, it was a slow wreck, but it still hurt the wallet (luckily that was all).
Old 03-14-2008, 10:25 AM   #12 (permalink)
rayzzr
World 500 GP Racer
rayzzr's Avatar
Casino Cash: $31351
Total Awards: 4
I'd try and fix that plastic instead of replacing it. Doesn't look that bad really.
Old 03-14-2008, 10:53 AM   #13 (permalink)
Saintmole
Saintmole's Avatar
Casino Cash: $0
Sportbike: 2007 Kawasaki ZZR600 Candy Fire Red
Saintmole is on a distinguished road
I agree with Rayzzr...doesnt look that bad. Take the money you were going to spend on fairings and swap out those terrible Dunlop's for a decent set of tires and some Frame sliders.
Parts411.com - Motorcycle accessories featuring Lockhart Phillips, Yoshimura, Joe rocket and Pro Circuit Products (always running tire specials)
Cycle Gear - Motorcycle Apparel, Parts and Accessories (next choice)
58cycle | Motorcycle Performance Parts & Accessories (sliders, exaust, everything..)
Saintmole is offline   Reply With Quote
Old 03-14-2008, 10:56 AM   #14 (permalink)
Saintmole
Saintmole's Avatar
Casino Cash: $0
Its not bad enough that a little touch up paint would hide the blemish...I mean, it wont look great but from a distance it will be fine.
And you could always tell the ladies that 5 guys were trying to bike jack you..but you kicked their A*s!
Old 03-14-2008, 11:35 AM   #15 (permalink)
bumblebee
bumblebee's Avatar
Casino Cash: $55110
bumblebee will become famous soon enough bumblebee will become famous soon enough
Maybe you should sell it and buy a smaller bike to learn on
When the government's boot is on your throat, does it matter if it is a boot from the left or a boot from the right?
bumblebee is offline   Reply With Quote
