Tuck & Run Clothing CoJardineProducts.comBluTek HelmetsAdvanstarMotorcycleShowsAnnitori DistributingSoupy's PerformanceBikeBanditMotoworld IncSee your ad here!
Old 01-11-2008, 10:38 PM   #1 (permalink)
Jswartou
vvrrrroooooommmmm
Jswartou's Avatar
Casino Cash: $8999
Sportbike: 2008 ZZR600, 2003 YZ250F
Jswartou is on a distinguished road
Default Front Mototeck signals!
When installing front turn signals, do you have to remove the entire front cowling? im trying to keep this as simple as possible, but is it necessary to remove the entire front?
USAF Security Forces
Jswartou is offline   Reply With Quote
Old 01-12-2008, 12:44 AM   #2 (permalink)
brandon2286
EET FUK
Casino Cash: $38304
Sportbike: 2007 KAWASAKI zzr600, 99 Husky Wr250 2smoker
brandon2286 is on a distinguished road
yeah dude...ill give you a hand with it if you want but im booked tomorrow til the evening
Street Ridden...Track Bound
I love the smell of 2 stroke in the morning...
brandon2286 is offline   Reply With Quote
Old 01-12-2008, 01:35 AM   #3 (permalink)
Jswartou
vvrrrroooooommmmm
Jswartou's Avatar
Casino Cash: $8999
alright cool, im pretty busy 'till then also. I have my tail section here also. the pipe was easier than expected, about a 10min job, but it sounds nice and clean now.
Old 01-12-2008, 02:10 AM   #4 (permalink)
Scootimus
Scootimus's Avatar
Casino Cash: $20625
Sportbike: 2007 Kawasaki ZZR600
Scootimus is on a distinguished road
a buddy of mine did his without removing the fairing, but I think it's way easier to do with the fairing off. It's not a tough job, just takes a few minutes.
Scootimus is online now   Reply With Quote
Old 01-12-2008, 02:17 AM   #5 (permalink)
brandon2286
EET FUK
Casino Cash: $38304
yeah i tried to jimmy rig mine without taking off the front and it was a real pain in the ass so i just said screw it and took it off. you like the yoshi? what are you gonna do with your stock pipe? ill take it off your hands if you dont want it. ill help with that undertail to if you want. i have a training for work tomorrow so ill be riding my bike there its suppose to be decent out
Old 01-12-2008, 09:04 AM   #6 (permalink)
ZZRrocket
MODERATOR
ZZRrocket's Avatar
Location: Originally from Atlanta GA. Live in Milan, Indiana
Casino Cash: $59467
Sportbike: 2006 ZZR600 2008 Ninja250R
ZZRrocket is on a distinguished road
Yes you will need to remove the front upper cowling assembly. Don't forget to unhook the RAM-AIR. You will need a 1/4 end wrench to turn those screws on the turn signals. Also before you install them the MOTOTECK instructions suggest running the screws all the way in and out of the lenses. Jay
SBN KAWASAKI FORUM MODERATOR
USAF VETERAN 1984-1997 SUPPORT OUR TROOPS THEY ARE THE REASON YOU ARE FREE TO RIDE THE OPEN ROADS OF THIS GREAT COUNTRY THE ANSWER GURU The 2005-2008 ZZR600 are exactly the same except for paint color. Having trouble finding parts for your 2005-2008 ZZR600? Try searching for parts that will fit a 2000-2002 ZX6R "J" model.
The 2005-2008 ZZR600 has one gas tank! It holds at total of 4.8 gallons of which 3.7 is available until you have to switch to reserve to use the remaining 1.1 gallons of gas.
ZZRrocket is offline   Reply With Quote
Old 01-12-2008, 04:16 PM   #7 (permalink)
Jswartou
vvrrrroooooommmmm
Jswartou's Avatar
Casino Cash: $8999
thanks, im gona try and do the front signals and undertail tonight...so i hope i dont mess things up...too bad...
Old 01-12-2008, 11:33 PM   #8 (permalink)
Jswartou
vvrrrroooooommmmm
Jswartou's Avatar
Casino Cash: $8999
finished my signals, and rear undertail...it was hell, but i think it came out ok..
i never want to touch that bike again..lol..5 hours on this stuff is too long...didnt realize how involved it was.
it being 30 degrees out while doing this didnt help much either.
pictures posted soon...when i regain my will to live.
Old 01-13-2008, 02:13 AM   #9 (permalink)
06_ZZR_600
risk taker
06_ZZR_600's Avatar
Casino Cash: $11202
Sportbike: 00 Honda 929 Fireblade
06_ZZR_600 is on a distinguished road
I feel your pain. I just got in from doing an undertail on my Honda 929. Will be doing the flushmounts in the morning. I wasnt cold though, as I have heat in my garage, so I can only imagine how miserable that was for you.
06_ZZR_600 is offline   Reply With Quote
Old 01-13-2008, 07:05 AM   #10 (permalink)
ZZRrocket
MODERATOR
ZZRrocket's Avatar
Casino Cash: $59467
Hate to burst your bubble but did you purchase the load resistors from MOTOTECK? Otherwise your turn signal will not flash at the proper rate.
Solution to the Tridon EL12 Flasher Relay that worked for me. Used a KURYAKYN # 6004865 load equalizer with the Tridon EL12 Flasher Relay. It has two purple wires and one black wire. On the MOTOTECK undertail LED's all I did was tap into one black wire with the black wire from the load equalizer and tap into each yellow wire with each of the two purple wires. I then plugged the Tridon EL12 flasher relay back into the female connectors that I had installed on the wires. Make sure you plug the Orange wire into the "L" marked on the bottom of the EL12 relay. I used some double sided tape and mount the load equalizer to the rear frame. You want to stick it to any plastic parts because it gets hot. And presto. I turned the key and turned on my hazard flashers and they flash at a normal rate, just like stock turn signals do. Turn signals right and left also work properly. Problem fixed. Any questions .
Cost:
Tridon EL12 Electronic Flasher $8.99 at AutoZone
Kuryakyn Load Equalizer # 6004865 $5.00 at Dealership
Old 01-13-2008, 09:25 AM   #11 (permalink)
brandon2286
EET FUK
Casino Cash: $38304
i have yet to get anything for mine and they strobe.
-Joe you could have used my garage and we coulda worked on it down here i have a heater in there, post pics up soon i wanna see it
Old 01-13-2008, 11:05 AM   #12 (permalink)
Jswartou
vvrrrroooooommmmm
Jswartou's Avatar
Casino Cash: $8999
they came with resistors...but i was too tired to figure out how to hook them up (a couple plastic pieces i had no idea what they were for..) so i just shrink wraped the wires so i could go back and perm instal them later when i feel like it...plus i dont know where to hook up that white LED license plate light.
Brandon, ill make sure to bum your garage when i get my brake line and ignition advance...i dont like numb hands trying to turn a wrench..haha..plus it will be nice to have another set of hands working so i dont have to enlist my knees and thighs as hands.
but i looked at the job this morning, polished the plastic and it looks good.
pictures will be up tonight in the ZZR Mod sticky.
Old 01-13-2008, 04:55 PM   #13 (permalink)
ZZRrocket
MODERATOR
ZZRrocket's Avatar
Casino Cash: $59467
You hook the little white LED for for license plate into your tail light. I said tail light not brake light.
Old 01-13-2008, 05:10 PM   #14 (permalink)
Jswartou
vvrrrroooooommmmm
Jswartou's Avatar
Casino Cash: $8999
oh, uh...which wire is that?
my tail/break light wires are all wrapped together.
Old 01-13-2008, 05:50 PM   #15 (permalink)
Farsscf
Farsscf's Avatar
Casino Cash: $26676
Sportbike: 2006 Silver ZZR600
Farsscf is on a distinguished road
mine too, I think people might notice it more, I hope
Farsscf is offline   Reply With Quote
Bent The Front Wheel ZZRrocket ZZR-600 39 09-23-2007 05:02 AM
Front End suspension - rebound. tkl999 FZ6 6 07-03-2007 03:14 PM
Help with turn signals front and rear. BigDaddyK Help Me Fix It 8 02-27-2007 08:38 AM
How to do all the wheelies explained dennisred69 Stunterz Corner 2 01-16-2005 05:27 AM
Changing front sprocket help??? SpDFrK ZX-7R 9 06-29-2004 04:09 PM
