Originally Posted by Farsscf
I wasn't even gonna get into the brands, lol. Changed yesterday, a piece of cake. I don't see why people are opposed to removing the fairing it was no problem. I used the whole gallon and the level is barely above the bottom marks though. I didn't use a larger oil filter, I used the Mobil M1-108.
I'm personally against removing the fairing because I have frame sliders installed, and removing the fairing would involve removing the frame sliders each and every time... it's a lot easier, for me at least, to take off the drain plug, let all the oil drain out, then lower to front onto the ground, with the rear still up on stands, turn the wheel right and take off the oil filter, AFTER putting aluminum foil under the filter to guide the oil into the pan... much much simpler than taking off the fairing, whether you have sliders or no...
Oh and I actually use less than the whole gallon, with a KN-303 filter change, and the oil level is just below the top line... about 3/4ths up from bottom line
