SumOfAllParts.netSoloMotoPartsArnottAirRideKomodoGear.comCheapCycleParts.comSportbikeTrackGearSuperbikeToyStore.comMotoGiya.comAdvanstarMotorcycleShowsRacerPartsWholesaleNice CycleSportbikeTrackGearMotorcycleToyStoreSee your ad here!
Old 09-10-2007, 12:19 AM   #1 (permalink)
Racer78
Casino Cash: $888
Sportbike: 2008 ZX14
Racer78 is on a distinguished road
Default Chain slack - conflict between owners to shop manual
The owners manual says 30-35mm 1.2 - 1.4"
repair manual says 35-40mm (1.4-1.6") with exceptable range 30-45mm (1.2-1.7")
Which is correct?
Thanks
Racer78 is offline   Reply With Quote
Old 09-10-2007, 01:08 AM   #2 (permalink)
mandrex
Superbike Champion
mandrex's Avatar
Casino Cash: $856
Sportbike: 07 R1
mandrex is on a distinguished road
I keep mine somewhere between 1.25 and 1.5" (probably closer to 1.5") - it's not an exact science - sort of like nuclear weapons - close is good enough.
mandrex is offline   Reply With Quote
Old 09-10-2007, 10:12 AM   #3 (permalink)
OreoGaborio
Cheap Bastid
OreoGaborio's Avatar
Casino Cash: $18516
Sportbike: See sig.
OreoGaborio is on a distinguished road
both... it doesn't have to be exact. Anywhere between 30-45mm of slack is fine.
-Pete Gaboriault
LRRS/CCS Expert #187 and Instructor for Tony's Track Days
New England Street Riders, SV Racer Forums
My "Resume"
The Garage - '03 Aprilia Tuono (Street Hooligan) | '02 KX250 (Dirt) | '06 SV650 (Race)
OreoGaborio is offline   Reply With Quote
Old 09-10-2007, 01:28 PM   #4 (permalink)
lecchilo
lecchilo's Avatar
Casino Cash: $16379
Sportbike: 2007 Kawi zzr600
lecchilo is on a distinguished road
haha well you just added a couple thousand miles to my riding time without adjusting chain
it started at around 33-34, and now, after ~ 1900 miles, it's up to 38ish
-Ivan
LUSTR Auto Detailing
lecchilo is offline   Reply With Quote
Old 09-10-2007, 06:21 PM   #5 (permalink)
RD-350Jim
RD-350Jim's Avatar
Casino Cash: $1234
Sportbike: 2007 Kawasaki ZZR-600
RD-350Jim is on a distinguished road
IMHO, the adjustment called for in the owners manual is the wrong way to adjust the chain.
They give a measurement with the bike on the side stand.
The problem with that is not all bikes will have the same shock extension at that point, some will be topped out, some (like mine) which have had the spring preload backed off will not be. Your shooting at a moving target if you do the adjustyment this way.
When I adjusted the chain like this I found it basicly had no slack at the middle of the shock travel. You don't want to have no slack, it will strech the chain, and wear the sprockets out much faster. It will also bind up the suspension.
A better way is to sit on the bike, compress the suspension as much as you can (ideally you should get it to mid travel-try bouncing on the seat, or find a fat friend to sit on it, or sit on the pasenger seat), so the chain is a tight as it can get, and measure the travel - you want maybe 1/2 or 3/4" or so. It is better to have too much slack than not enough, BTW.
RD-350Jim is offline   Reply With Quote
Old 09-10-2007, 06:55 PM   #6 (permalink)
OreoGaborio
Cheap Bastid
Casino Cash: $18516
Sportbike: See sig.
well said, Jim
-Pete Gaboriault
My "Resume"
New Rider and Chain slack too loose joe2tiger Ninja 250R 2 08-07-2007 07:34 PM
Proper way to check Chain Slack? FIZZER6 FZ6 12 06-07-2007 11:27 PM
DuPont Teflon Chain Lube PCHbreeze General Sportbikes 38 06-02-2007 11:06 PM
Owner's Manual massR1 ZX-6R 4 02-16-2007 11:33 PM
Shop manual and jack-up plates for 02 F4i jesseh CBR600F Series 5 08-08-2004 02:05 PM
