Motorcycle.com Classifieds!
Allstate
GravesMotorsportsMcCoyMotorsportsBikeBanditAnnitori DistributingSoupy's PerformanceTuck & Run Clothing CoMotoworld IncCycleGear.comBritish Motorcycle Gear See your ad here!
Old 07-21-2007, 06:21 PM   #1 (permalink)
posite
i7
posite's Avatar
Casino Cash: $24479
Sportbike: 07 zzr 600 ebony
posite is on a distinguished road
Default oil change problem
So I went to change my oil as I have done on this particular model bike 5-6 times now... this is my switch to synthetic at 1500 miles and I was wrapping everything up and fired it up and had to burp it as usual. This time when I went to burp it very little oil at all is coming out from around the filter and in fact you can literally take the entire filter off while the bike is running and you will see little more than a very small stream of oil coming out of the bike. I had the bike warmed up decent before the oil change, it drained completely, I filled the new filter up and put it on just like I always do. Any ideas?
The bike has been tilted pretty much all the way to both sides and still no luck. Also tried removing the filler cap for a second and the oil sight glass is pretty much perfect... also the filter still appears to be almost full. bike is an 07 zzr600 with 1500 miles.
posite is offline   Reply With Quote
Old 07-21-2007, 06:31 PM   #2 (permalink)
dubbs693
Making Horizons Vertical
dubbs693's Avatar
Casino Cash: $14849
Sportbike: 07 Kawasaki ZZR600
dubbs693 is on a distinguished road
I'd fill the filter up a little more and try it again..
Is the oil light still on and can you hear the valves chattering?
Had the same thing with mine on the last oil change, seems I didn't pre-fill the filter enough..
Car ~ 2003 Honda S2000 - Stock - Black - 9K RPM
BEATER ~ 1992 Honda Civic LX ~ *fixed* axle, Bad Idle, Burnt 4th Gear Synchro - White
Bike ~ 2007 Kawasaki ZZR600 - Black
Goodies - Yoshi can, K&N Filter, DynoJet Stage 1 Jet Kit, Factory Pro Ignition Advancer, Galfer Brake Lines, Flush mounts, Swingarm Sliders, Pazzo Levers, Grip warmers, n CarbonFreak Windscreen 99.63 WHP
dubbs693 is offline   Reply With Quote
Old 07-21-2007, 07:17 PM   #3 (permalink)
posite
i7
posite's Avatar
Casino Cash: $24479
yep valves are chattering and i just went and bought a kawasaki filter and drained all the oil and refilled and same thing with no luck... first time was with the bosch filter i've used on mine twice before and on my friends several times. there is still very little to no oil on the filter side of the pump
Old 07-21-2007, 08:34 PM   #4 (permalink)
posite
i7
posite's Avatar
Casino Cash: $24479
It took a while but for anyone that is searching for a resolution to this, here is what i did.
As well as using the burping method... I propped the front of the bike up, i usually just use the kickstand, to attempt to fill up the space between the filter and pump with oil as on a level surface it seemed to be draining out. I filled the filter up once or twice doing this and when I fired it up it was good to go. Oil changes on this bike have never been this much of a pain since burping it usually is a very quick fix.
This may have been such a pain because since i was transitioning to synthetic i made sure every last drop of oil was out. Honestly I have no idea if propping the front up makes mechanical sense but it worked for me this time.
btw thanks for the post dubbs
Old 07-22-2007, 12:47 AM   #5 (permalink)
zokalr13
Casino Cash: $550
Sportbike: 2004 zzr600
zokalr13 is on a distinguished road
Exclamation
shouldnt you switch to synthetic oil after about 5000 miles? 1500 miles the motor hasnt even been worn-in...anyone else out there agree? or am i a non-engineer/dinosauripod?..
zokalr13 is offline   Reply With Quote
Old 07-22-2007, 01:08 AM   #6 (permalink)
06_ZZR_600
risk taker
06_ZZR_600's Avatar
Casino Cash: $11202
Sportbike: 00 Honda 929 Fireblade
06_ZZR_600 is on a distinguished road
funny, I drain my oil, put on a dry filter, and it never has a problem. And my oil light goes off after like 2-3 seconds after I change oil.
06_ZZR_600 is offline   Reply With Quote
Old 07-22-2007, 02:03 AM   #7 (permalink)
dubbs693
dubbs693's Avatar
Casino Cash: $14849
Mine has issues randomly, I always prefill the filter.. sometimes the oil light goes out right away, other times I have to fill it up more, Strange if you ask me...
Old 07-22-2007, 12:38 PM   #8 (permalink)
UNDERTOW
Keyser Söze
UNDERTOW's Avatar
Casino Cash: $56301
Sportbike: 2007 Yamaha FZ1, 2007 kawasaki zzr600(sold)
UNDERTOW is on a distinguished road
Default Fill Up The Filter?
i do the same thing. i drain change filter then add oil. i have never put oil in my filter before i put the filter on. maybe that's you problem
UNDERTOW is offline   Reply With Quote
Old 07-22-2007, 12:45 PM   #9 (permalink)
dubbs693
dubbs693's Avatar
Casino Cash: $14849
Well since my first oil change in which I had the same issue with a dry kawi filter... I then started pre-filling.. I seem to have more luck pre-filling then not..
Old 07-22-2007, 02:17 PM   #10 (permalink)
daqq
Casino Cash: $854
Sportbike: 2007 Kawasaki ZZR600
daqq is on a distinguished road
The Service Manual makes no mention of pre-filling the oil filter. Anyone want to clue me in to why everyone is doing this?
Service manual says to drain the oil, remove the old filter and pour out the oil in the filter, put a small amount of oil on the new filter's gasket, put it on and torque to 19.5 ft-lb, and fill with 3.6L of SE, SF or SG class SAE 10W40, 10W50, 20W40, or 20W50.
daqq is offline   Reply With Quote
Old 07-22-2007, 02:18 PM   #11 (permalink)
daqq
Casino Cash: $854
ZX6R Service Manual says to add oil with dry filter. All it mentions is to put oil on the new filter's gasket.
Old 07-22-2007, 03:49 PM   #12 (permalink)
posite
i7
posite's Avatar
Casino Cash: $24479
Eh either way I have done it both ways and always had the problem with this bike (prefilling and not prefilling the filter)... either way the fix is typically very quick when you expect it and surprisingly not too messy. I switched my old ex250 to synthetic at its first oil change at 200 miles with no problems however everyone has their own opinion so no one and I mean NO one will ever get a definite answer. I decided to wait until 1500 miles based on the info that turned up while i was researching but honestly everyone had their own opinion so I just did what I wanted to do . It is working pretty well so far for whoever is curious.
Old 07-22-2007, 09:01 PM   #13 (permalink)
sar1372
Casino Cash: $456
Sportbike: 2006 ZZR600
sar1372 is on a distinguished road
i changed my oil yesterday and put synthetic in for the first time (2500 miles). I put a dry filter on and the oil light never came on at all.
sar1372 is offline   Reply With Quote
Old 07-22-2007, 10:08 PM   #14 (permalink)
daqq
Casino Cash: $854
I don't think a dry filter will ever hurt anything... but please make sure you are putting a little oil on the oil filter gasket (the, usually, orange ring on the side you screw on).
Old 07-22-2007, 10:11 PM   #15 (permalink)
xZeler8
xZeler8's Avatar
Casino Cash: $1161
Sportbike: 2005 ZZR600
xZeler8 is on a distinguished road
first off, i think you're switching to synthetic too soon in the engine life...like was mentioned you want to wait until atleast 5-6k miles (20-30k on a car)...as far as the other question about prefilling the filter, the reason people do it (including myself) is to ensure that there is oil pressure (hence oil available) on that first start after draining the oil, as you can imagine running the engine without oil weilds havoc on a motor even if it's just a second or two (this is especially important in turbocharged applications because starving any amount of oil from turbos can be dissasterous to the life of the turbo(s), but the same principle is applied for NA motors)...
I only use the brakes so I can xZeler8 all over again...
xZeler8 is offline   Reply With Quote
oil change HELP! Miniguinea1705 General Sportbikes 4 05-06-2007 12:43 PM
quick change oil places....pttf blueyes34 Open Forums 21 05-05-2007 06:41 AM
first oil change Jhid05 Performance and Customizing 5 05-01-2007 05:21 PM
First Oil Change NCGSXR CBR600RR 5 09-07-2004 11:47 PM
oil change hondaboy44709 General Sportbikes 20 07-08-2004 10:32 PM
