06-08-2007, 08:11 PM
#1 (permalink)
ZX10R FTW
Casino Cash: $1300
Sportbike: 2006 ZX10R FTW
520 conversion.
I just ordered a 520 conversion. It is 14 front and 40 rear, so that makes it -1 in the front.
Has anybody done this conversion? I just want to know how much -1 will effect my Speedo, and RPM's when cruising in 6th.
I refuse to live life carefully just to arrive safely at death
___________________
CHROMELEESTA
06-08-2007, 11:12 PM
#2 (permalink)
Casino Cash: $8624
Sportbike: 2006 Kawasaki ZZR600
mm explain this a bit more for me i'm a bit unfamiliar still with what it is, and how much it cost u/where?
1st Mar Div
USMC irrrrr
Bike - 2006 Kawasaki ZZR600 - SilverGoodies - Yoshimura RS-3 Stainless Steel Oval Bolt-On with Race Baffles exhaust, Goodridge Stainless Steel Front Brake Lines, Factory Pro Ignition Advancer 4 degrees, KN&N Performance Air filter, R&G Frame Sliders, R&G Racing Slider Bar Ends, Zero Gravity Dark Smoke Double Bubble Windscreen, MOTOTECK undertail with intergrated LED amber turn signals, MOTOTECK Flushed front LED turn signals, LED Brake Lights,
06-09-2007, 09:25 AM
#3 (permalink)
ZX10R FTW
Casino Cash: $1300
Basically all it is, is a chain conversion from our stock 530 chain to a 520 for a little bit of wieght reduction. and they normally come with a -1 front sprocket the rear stays stock.
The price wasnt to bad it was 164 for the chain and sprockets. I ordered it from dennis kirk.
I needed to replace my chain anyways it was stretched beyond adjustment.
___________________
CHROMELEESTA
06-09-2007, 10:47 AM
#4 (permalink)
Casino Cash: $663
Sportbike: 2005 kawasaki zzr600
our stock is actually 525
06-10-2007, 02:27 AM
#5 (permalink)
Kawi Rider
Casino Cash: $429
Sportbike: '06 ZZR600
Either way, lots of people do it to lose some bike weight. I don't think it's all that much, but i've never weighed both chains and sprocket setups.
I personally like the gearing our bikes have when it's stock. I haven't, and more than likely won't touch it.
2006 ZZR600:
Flushmount front signals, Integrated LED rear, Two Bros Titanium muffler, Factory Pro TI jet kit, Factory Pro 4* ignition advancer, BMC Street Filter.
102.8 RWHP <--Before 4* advancer.
06-10-2007, 11:15 AM
#6 (permalink)
Casino Cash: $663
Its not so much losing the overall weight... Its losing the rotating mass which allows the chain to spin faster sooner thus allowing increased accelerating. Prolly not incredibly noticeable but I havent done it so I really cant say.
06-11-2007, 04:50 PM
#7 (permalink)
ZX10R FTW
Casino Cash: $1300
Well i get it on Wednesday so i will let you know.
___________________
CHROMELEESTA
06-11-2007, 10:17 PM
#8 (permalink)
EET FUK
Casino Cash: $25590
Sportbike: 2007 KAWASAKI zzr600, 99 Husky Wr250 2smoker
are the speedos off stock from the factory? i feel like im going slower than 70 when im cruising and getting passed like im doing 25
06-12-2007, 04:53 PM
#9 (permalink)
ZX10R FTW
Casino Cash: $1300
If your running the stock gears it shouldnt be. If it is your speedo sensor could be going bad.
___________________
CHROMELEESTA
06-12-2007, 05:36 PM
#10 (permalink)
Cheap Bastid
Casino Cash: $18516
Sportbike: See sig.
The benefit is so miniscule, especially on a street bike, that the 520 conversion isn't really worth replacing a perfectly good stock drivetrain... unless your stock chain & sprockets need replacing anyway.
In fact, if you wanna get into the knitty gritty of it, going 1 down in the front will probably erase any benefit you get from the 520 conversion anyway beacuse it makes for a tighter radius turn.
It's like anything going around a corner, when you reduce the turning radius it takes more effort to make the turn at the same speed. So even though you reduced the weight of the chain, you're increasing the effort required to make it turn nearly 180 degrees around that smaller countershaft.
For this reason, it's always best to increase the size of your rear sprocket than decrease the size of the front.
But... with all that said, I don't think you'll notice much of a difference. If you feel anything, it'll probably just be a placebo effect.
06-12-2007, 05:41 PM
#11 (permalink)
Cheap Bastid
Casino Cash: $18516
Sportbike: See sig.
Actually, yes, speedo's are usually off from the factory. Stock bikes will give anywhere between an 8 & 12% speedo error depending on make & model. And speedo sensors don't slowly go bad or get worse, when it goes bad you'll just see 0mph all of a sudden.
06-12-2007, 06:19 PM
#12 (permalink)
ZX10R FTW
Casino Cash: $1300
When i first got mine, about three weeks later mine was doing the same thing. My speedo was reading in the 80's when i was doing only 40's. I took it back since it was still in the warrenty. they told me it was the speedo sensor.
as for my chain and sprockets. yep my chain was shot. Poor maintenance on it. It had a kink in it i couldnt get out so i ordered the 520 kit since i was going to get everything anyways.
___________________
CHROMELEESTA
06-12-2007, 06:23 PM
#13 (permalink)
Cheap Bastid
Casino Cash: $18516
Sportbike: See sig.
very odd.
06-12-2007, 06:29 PM
#14 (permalink)
ZX10R FTW
Casino Cash: $1300
Originally Posted by OreoGaborio
very odd.
I thought the same. I have had them go bad on other bikes at the shop, they do normally read nothing. I took it back figuering it was a internal issue.
___________________
CHROMELEESTA
08-31-2007, 11:17 AM
#15 (permalink)
Casino Cash: $255
Sportbike: .
520 Sprocket KITS?
Ok i am thinking about changing my Sprockets. What is a good was to go?
| Thread Tools |
| Display Modes |
Linear Mode
