i hit 226 last week in traffic for about 10mins dead stop...almost. It was about 108 out..
1st Mar Div
USMC irrrrr
Bike - 2006 Kawasaki ZZR600 - SilverGoodies - Yoshimura RS-3 Stainless Steel Oval Bolt-On with Race Baffles exhaust, Goodridge Stainless Steel Front Brake Lines, Factory Pro Ignition Advancer 4 degrees, KN&N Performance Air filter, R&G Frame Sliders, R&G Racing Slider Bar Ends, Zero Gravity Dark Smoke Double Bubble Windscreen, MOTOTECK undertail with intergrated LED amber turn signals, MOTOTECK Flushed front LED turn signals, LED Brake Lights,
When its 65-75 degrees outside, my bike runs in the area of 160's. A hot day like today when it's in the 90's my bike runs in the 180's area. Sitting still at lights, it never gets over 210. The fan on these bikes rock.
My bike has seen 235 sitting in traffic for about 45 mins straight.. It was about 85-90* out then.. Man did that suck in full gear..
<3 california's lane sharing, i swore when I got here I would never do it.....WRONG!
1st Mar Div
USMC irrrrr
With water wetter, ethylene glycol AF and water mine runs in the 160-170 range at speed when it is 90+. It climbs steadily at red lights, but drops quickly when I get moving again. WW certainly helps.
+1
1st Mar Div
USMC irrrrr
I shut it off and pushed it today waiting to cross the Canadian border when it was reaching upper 230's and my temp warning light went off.
Last week I'm pretty sure I hit 242 or 243 before I turned it off for fear of my engine melting. I don't even live in cali or anything... Buffalo, NY. It was 90-ish both days. I also had on a leather jacket and jeans both days
They say that if you shake it more than twice, you're playing with it...
I say... what's wrong with playing with it?
Was your fan on? I haven't had mine go above the 228 mark yet. Of course I think I've only been out while it was 90+ once and I didn't get stuck in traffic for long. Usually my fan comes on and it drops 3-6 degrees almost instantly.
Right, Thats what happens, but 5-6 cycles later, the temp stops dropping and the fan just stays on..
I wish lane sharing was legal here...
__________________ Car ~ 2003 Honda S2000 - Stock - Black - 9K RPM
BEATER ~ 1992 Honda Civic LX ~ *fixed* axle, Bad Idle, Burnt 4th Gear Synchro - White
Bike ~ 2007 Kawasaki ZZR600 - Black
Goodies - Yoshi can, K&N Filter, DynoJet Stage 1 Jet Kit, Factory Pro Ignition Advancer, Galfer Brake Lines, Flush mounts, Swingarm Sliders, Pazzo Levers, Grip warmers, n CarbonFreak Windscreen 99.63 WHP
