Originally Posted by OreoGaborio
For the sake of clarity, if you're talking about rigging it up so the clutch switch is always active, then yes, I wouldnt' do that.
but if you're talking about just intentionally disabling it, then the clutch switch is a fail safe system. If it fails it doesn't start if it's in gear or if the clutch lever is pulled in. So simply disabling it wouldn't create the scenario you brought up.
huh?
I only use the brakes so I can xZeler8 all over again...
