Originally Posted by pin8246
how long do the rear struts usually last for?
what weight is the rear spring adjusted for out of the factory?
do they make an upgraded (more stiffer)?
A rear "SHOCK" will last the lifetime of the bike, but it should be serviced every few years... new nitrogen, new oil.
Sportbikes are typically sprung for a rider between 140-160 lbs. I couldn't tell you what the ZX9 is sprung for. It very well could be 180.
Ohlins & Penske both make excelent shocks for this bike, but at 700-1200 bucks, they're a pretty penny.
A shock rebuild will probably cost a couple hundred bucks... cheaper if have the ability to take it off yourself & get it to a suspension specialist.
I use GMD Computrack for all my suspension needs. They're beyond excelent.
GMD
