GoFreeCreditReport
GravesMotorsportsCycleGear.comAnnitori DistributingAdvanstarMotorcycleShowsMotorcycle.com Classifieds!BikeBanditSportbikeTrackGearSee your ad here!
Old 08-11-2004, 10:51 PM   #1 (permalink)
Tiamat
Sportbike:
Tiamat is on a distinguished road
Default 520 vs. 530 final drive weight difference
This is kinda a re-hash of an older thread regarding gearing and the benefits (if any) of switching to a light chain and sprocket set.
I recently purchased a 520 RK lightweight chain and sprocket set for my 7R, and decided to weigh both it and the original 530 stock parts for comparison using my kitchen food scale (accurate to within 1 gram). I just thought some of you would be interested in this. Note that the RK set uses an aluminum rear Vortex sprocket and the front sprocket is a 15 tooth vs. the stock 16 tooth. Here's the numbers:
Stock 530 set:
front sprocket = 225g
rear sprocket = 1042g
chain = 2102g
total weight = 3369g or 7.41lbs
RK 520 set:
front sprocket = 164g
rear sprocket = 350g
chain = 1868g
total weight = 2382g or 5.24lbs
difference in weight = 986g or 2.17lbs
Difference in weight is the 520 set is roughly 29% lighter than stock.
Tiamat is offline   Reply With Quote
Old 08-11-2004, 11:00 PM   #2 (permalink)
Zippy
Casino Cash: $918
Sportbike: 2003 ZX7R
Zippy is on a distinguished road
530? Are you sure? My chain has 525 stamped on it.
I think most of the weight savings are due to the aluminum rear sprocket.
Zippy is offline   Reply With Quote
Old 08-11-2004, 11:09 PM   #3 (permalink)
Tiamat
Sportbike:
you may be right. my chain was in too bad a condition to read any of the side plates, but the manual does say 525. that would mean an even larger difference between a 530 and a 520.
