Originally Posted by heffay
what kind of carb synch did you get?
I don't know, but it's dangerous as all hell, and looks like something you'd find in a high school science lab from the 50's.
First, I actually had to pour the Mercury into this reservoir, in which these 4 long plastic pipes stick into. The pipes are like 24 inches each, attached to this white metal backing with benchmark ticks every inch or so. Pouring in the Mercury was fun, had vinyl gloves on, and did it REAL SLOW, sometimes, drop by drop, as Hg, even if your skin touches it, stays IN YOU FOREVER, and is cumulative.
You then attach these clear vinyl-like rubber hoses to the top of each pipe, and stick the other end into the vacuum port...
What gets me is the Hg reservoir, it's plastic, and the hole you pour the Hg into is covered by this crappy rubber plug, that doesn't really give you a whole lot of confidence, such that I wrapped a piece of electrical tape around the whole reservoir, covering the plug just in case...
You get what you pay for I guess, it was like $60 at the local shop... Don't think it's a "name" brand either... lol
