Originally Posted by azzazel_99
yea i have done carbs on dirtbikes and other small engines. I need to get the shop manual and a carb sync tool.
the kicker is that you'll also need the kawasaki special pilot adjuster tool (the motion pro doesn't work on my 7r carbs) or the morgan carbtune adjuster tool. tack on another 70 or 80 bucks for that tool alone. tack on another 70 or 80 for the sync tool.
but, if you're nice i could copy the carb section from my shop manual.
back to the pilot adjuster... you need one w/ long screwdriver bits since the pilot screw is WAAAY up there inside the slot for the screw.
just google morgan carbtune pilot adjuster and look at the pics and you'll see the type of tool you're looking for.
