BluTek Helmets
Motorcycle.com Classifieds!Tuck & Run Clothing CoCycleGear.comAdvanstarMotorcycleShowsBritish Motorcycle GearGravesMotorsports
Allstate
McCoyMotorsportsSee your ad here!
Old 11-20-2006, 10:24 AM   #1 (permalink)
kawirider23
Sportbike: 2003 kawasaki zx-7r
kawirider23 is on a distinguished road
Default front end problems
i have a 2003 zx7r and i recently got run off the road by another driver, anyway when i went down my left side handle bar got bent. To make a long story short i got the parts and fixed it. I took it around the block to make sure that everything was ok. my front tire was not lined up with the handlebars. the bars were off to the right a couple of inches. anyone have any kind of help for me. i think my forks might be bent but i would like some more input.
thanks all
kawirider23 is offline   Reply With Quote
Old 11-21-2006, 12:06 PM   #2 (permalink)
zx7Ryder
zx7Ryder's Avatar
Casino Cash: $554
Sportbike: 2003 ZX-7R
zx7Ryder is on a distinguished road
Make sure your forks aren't twisted in the triple trees. You'll need to loosen the upper and lower clamps in order to realign them. If you can lift the front end, that would make it easier. I use a rear stand and wood blocks under the header. If the problem persist, you'll need to pull the forks and have them inspected.
www.detroitsportbikes.com
zx7Ryder is offline   Reply With Quote
Old 11-21-2006, 12:53 PM   #3 (permalink)
hybrid
RESIDENT ASSHOLE
hybrid's Avatar
Casino Cash: $3557
Sportbike: too many to list
hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute
can someone explain why there is some crazy assed myth that you can "twist" forks in the clamps?
Hello?
The bottom of the forks or the "inner tubes" are free floating and can rotate 360 degrees independant of the upper tubes..............you cannot twist forks.
Check your handle bar..........the stock one has a bolt that locates it if I remember correctly and you may not have it lined up.
Other than that youre looking at either a bent triple clamp (top, bottom or both) or a bent fork leg.
kaw has always been over kill in strength..........so Im guessing your bars are just not on right.
www.walmartmovie.com
hybrid is offline   Reply With Quote
Old 11-21-2006, 12:56 PM   #4 (permalink)
RedRidingHood
Superbike Champion
RedRidingHood's Avatar
Casino Cash: $758
Sportbike: vtr1k,750k6x2
RedRidingHood has disabled reputation
Hello?
not everyone has graduated mmi, mr helpful now get back to work on your windscreens
“Paradise is surrounded by what we dislike; the fires of hell are surrounded by what we desire.” -Rumi
"An artist is a dreamer consenting to dream of the actual world." -Santayana
wu wei
RedRidingHood is offline   Reply With Quote
Old 11-22-2006, 11:52 AM   #5 (permalink)
zx7Ryder
zx7Ryder's Avatar
Casino Cash: $554
Hello?
I did not mean the fork themselves can twist. What I meant, was the bottom triple is not aligned with the upper triple. Out of curiosity, how does a triple clamp bend? I am trying to picture that.
Old 12-02-2006, 09:28 AM   #6 (permalink)
bds740
Sportbike: 92 ZX-7
bds740 is on a distinguished road
I had the same thing happen to my old 6. I was told by the local Kawi mechanict to bang the front tire against a tree and knock it back in place. It did work, although it was a odd way to fix it.
bds740 is offline   Reply With Quote
Old 12-04-2006, 11:41 PM   #7 (permalink)
wolfman
wolfman's Avatar
Casino Cash: $23704
Sportbike: 1995 ZX-7, 2003 CBR 954RR, Next on the list, 2006 Warrior
wolfman is an unknown quantity at this point
I would definately find yourself another mechanic!!!
The early bird may get the worm, but the second mouse gets the cheese in the trap.
Thought of the day: How much deeper would the ocean be without sponges?
wolfman is offline   Reply With Quote
A guide for learning wheelies. Justin726 Stunterz Corner 176 10-20-2009 02:44 PM
Read This Before You Ask Questions snigg Stunterz Corner 3 06-23-2007 02:23 PM
***NWS*** The front end of the GSXR came up going over a hill and BAM!!! OFFICER737 Open Forums 39 07-19-2006 04:14 PM
Front End "Heavy" Rattle Meantown Help Me Fix It 7 06-27-2006 09:09 PM
RS front end rebuild question Hams51 Triumph 0 11-27-2005 06:47 PM
