07-09-2004, 01:20 PM
#1 (permalink)
Sportbike:
Ignition Advancer
What is the difference between +2, +4, +5, and +6 degree ignition advancers?
07-12-2004, 06:05 PM
#2 (permalink)
Sportbike:
Does anyone have any idea? I want to pick one up, but I don't know what to go with.
07-12-2004, 06:23 PM
#3 (permalink)
Casino Cash: $552
Sportbike: 01 Kaw ZX7R
I have a +4 on mine now not really sure if it did anything, i think i havent road it enuff since i put it on so, well when i did ride it, it kinda seemed like the throttle was a little quicker so yeah it does help out on the bike but like i said i havent raod it enuff since i put it on but one guy on here says he got it and it was worth the $ thats why i got mine so go ahead and get one, i got mine from http://www.denniskirk.com/jsp/produc...n&m myId=5059 but you will need to go back and change the year of the bike cause the page i put up is for an 01, but i think its a good thing to buy cause i felt some differance but i just need to ride it more, and im not sure what the differance is between the degrees
07-12-2004, 06:37 PM
#4 (permalink)
Sportbike:
'99 and '01 should be mechanically identical, right?
07-12-2004, 06:45 PM
#5 (permalink)
Casino Cash: $552
not sure about that
07-12-2004, 07:25 PM
#6 (permalink)
Capo di tuti Capi
Casino Cash: $377
Sportbike: 1999 ZX-7R
Yes. Nothing has changed mechanically from 1996-2003, other than graphics.
Stone
07-12-2004, 07:41 PM
#7 (permalink)
Sportbike:
Just as I had thought. Do you know much about ignition advancers, stone?
07-12-2004, 07:58 PM
#8 (permalink)
Capo di tuti Capi
Casino Cash: $377
Yes and no.
I am thinking about doing one myself. My interpretation is it is like a mechical advance on a distributor (since our distributors cannot be adjusted). You can "advance" the timing in a sense (+2,+4, etc.). The thing is picking the right "advance" you want or that will work for your bike. I am sure other variables must come into play (full system vs. slip-on, is the bike jetted, etc.) to be able to choose the right advance.
Is too much advance a bad thing too? Does +4 change bottom end or mpg?
Are you looking at the Factory adjustable Ignition Advancer?
I am apprehensive on buying a fixed advancer (say, just +2). I do not want to be stuck with the wrong one.
Stone
07-12-2004, 10:03 PM
#9 (permalink)
Sportbike:
I wish I had a clue...
I can't find anything on the net to really explain it.
07-12-2004, 10:40 PM
#10 (permalink)
Casino Cash: $552
the place i bought mine from says this about the advancer
Provide quick performance increase
Boost top-end and mid-range power
Sharpens low-end throttle response
Easy installation
Used by many AMA/WERA race teams
Toll-free customer support from Factory: 1-800-869-0497
07-12-2004, 11:50 PM
#11 (permalink)
Casino Cash: $62460
Ignition timing is matched to piston rise, octane and compression. The idea is to have the fuel/air charge complete ignition of the charge in sequence as the piston moves down from Top Dead Center on the power stroke. So timing is "advanced" to light the charge prior to the piston topping out. The advance is measured in degrees BTDC (before top dead center.) A four degree advancer moves the ignition four degrees farther BTDC than stock.
If the charge burns too soon the result is a loss of power due to the charge expansion fighting the upward movement of the piston. If the charge is not completely burned during the power stroke the result is loss of power due to the incomplete use of fuel/air.
If you have modified your head by porting or shaving, you may need to advance timing to meet the ideal burn completion point since a bigger or more compressed charge burns slower. This is why higher compression engines require higher octane (faster burning) fuel.
Otherwise, timing advancers generally do not improve the burn. In any event, you can't know if the mod improves horsepower without a dyno. An ignition that is too advanced can lead to pre-ignition and holeing the piston. The expanding charge pushes against the rising piston to the point of failure. Buyer Beware.
07-12-2004, 11:57 PM
#12 (permalink)
Casino Cash: $552
So your saying not to buy it unless you do engine work?
07-13-2004, 12:08 AM
#13 (permalink)
Casino Cash: $62460
Yes, I'd skip it.
07-13-2004, 12:13 AM
#14 (permalink)
Casino Cash: $552
well i got mine last week and its already on, but on the info it gives on the site dont say nothing about what you said
07-13-2004, 11:12 AM
#15 (permalink)
Sportbike:
Of course not, because they want everyone to buy one, whether it's needed or not.
| Thread Tools |
| Display Modes |
Linear Mode
