Originally Posted by 001438
That is just the problem. I don't see a mark on the casing for the marks on the timing wheel to line up with. I guess that the easiest way for me to make sure the number 1 piston is at TDC is to check with a dial indicator. It would be so much easier for me to have a mark on the case. After bolting everything back down, I plan to rotate the engine twice to make sure everything lines up from where I started.
The way that you are describing to adjust the valves, sounds like you think that there are rocker arms with adjustable screws. Maybe I am wrong, but when you say to get number 1 up and then adjust those valves, then adjust two valves on the other 3 cylinders, that is where you loose me. I can't adjust mine like that. I have to rotate the cams so that the valves are closed for a particular cylinder, then measure the valve lash with feeler gauges. After checking each cylinder, I have to remove the cams and replace the shim with the appropriate thickness in order to bring the lash within specs.
I think what I am going to have to do is make sure that number 1 piston is at TDC by using a dial indicator and mark the case and timing wheel myself. Then set the cams with the marks lined up on the top of the head. Install the chain and tensioner, rotate the crank two turns, and check to make sure everything is lined up still.
I am really still interested to know if there is a mark and where it is. I would like to know if it was even set correctly the last time it was supposed have been adjusted at my 500 mile check up.
There has to be a mark on the engine case right behind the timing rotor. It may only be a small raised ridge on the engine casting someplace, but I am sure its there. No I know quite well that the late model ZX motors use shim under bucket adjusters. The bucket is still called a cam follower though. I went back and re-read my post I meant to say measure, instead of adjust the valve clearance. I am sure that sounded confusing. I'll go back and edit it in a while. So anyway the way it works out is that you measure the clearance on all 4 valves on 1 of the cylinders then 2 valves on 2 other cyliders. Rotate the crank one full turn and do the other 8 valves.
Also if the cams were out of time you bike would be running like crap if not bending valves. I really suggest forking out the $$$ and get the factory manual. Its pretty darn decent.. Also you can go to
www.buykawasaki.com and look at the parts diagrams if need be..
This is what you want your cams to look like when #1 cylinder is at top dead center and you ready to do the first measurement.. I was in the middle of degreeing my cams with the adjustable cam sprockets I had....
Heh I might be on #4 at the end of the motor though. In any case thats what they need to look like. Lobes up and away, heels toward the follower.
