McCoyMotorsports
Go Back   Sportbikes.net > Sportbikes > Kawasaki Sportbikes > Kawasaki Model Specific > ZX-12
BluTek HelmetsAdvanstarMotorcycleShowsAnnitori DistributingGravesMotorsportsCycleGear.comSportbikeTrackGearBritish Motorcycle GearMcCoyMotorsportsSoupy's PerformanceMotorcycle.com Classifieds!See your ad here!
Old 07-01-2004, 11:09 PM   #1 (permalink)
badasszx12r
badasszx12r's Avatar
Sportbike: 03 kawi zx12r
badasszx12r is on a distinguished road
Default is anyone else having this problem?
zx12r muzzy aluminum fans, muzzy billet reed block off plates, dynojet pc iiir, the bike dies at a stop after running for awhile and is warm. Could this be the throttle position sensor?
badasszx12r is offline   Reply With Quote
Old 07-06-2004, 08:37 PM   #2 (permalink)
blink
Sportbike: 2000 ZX12, 2001 F4i
blink is on a distinguished road
It is probably not your TPS. Try adjusting your idle speed up first, if that doesn't help you should consider re-setting the throttle (make sure you get 0 and 100) with your Power Commander software and then maybe try adjusting the fuel % in your map at 0 and 10% throttle position and at the lower rpm ranges. If your bike was running fine before your mods it's probably not your TPS. You didn't mention whether you have a full system or just an end can, simce you did the block off plates I assume you went with the full system. I don't think it is unusual for your idle speed to drop when the bike is warm and the weather is really hot.
blink is offline   Reply With Quote
Old 07-19-2004, 12:33 AM   #3 (permalink)
silverzx12r
Sportbike: 01'kaw.zx-12r,98'suk srad 750
silverzx12r is on a distinguished road
it's the muzzy pipe, I am always adjusting my idle to keep mine running, since I switched from the akro to the muzzy. My bike was dyno tuned wiht the pc3 and the tps has been set, throttle bodies have been synchornized, and I still have to play with the idle
Last edited by silverzx12r : 07-19-2004 at 12:34 AM. Reason: I can't spell......LOL
silverzx12r is offline   Reply With Quote
Old 08-11-2004, 05:28 PM   #4 (permalink)
Zang
Zang's Avatar
Sportbike: 2003 Kawasaki ZX something R
Zang is on a distinguished road
What did you do with your old Akro? ;)
Why on earth did you change it?
Zang is offline   Reply With Quote
Old 08-11-2004, 07:40 PM   #5 (permalink)
badasszx12r
Bet late than never to respond, just muzzy exhaust, w/ jardine rt1 slip on, gonna try remapping the bike with my buddy and let you know what happens, I live in hell and its hot here. LOL
I don't see where that is my problem!!
I make sound's only other FREAKS can hear!!
