Go Back   Sportbikes.net > Sportbikes > Yamaha Sportbikes > YZF-R6
YZF-R6 We started out to give the 2005 R6 more horsepower and a new fork, and wound up engineering a nearly new motorcycle.
MotoGiya.comChainDrain.comMotorcycleToyStoreAdvanstarMotorcycleShowsSumOfAllParts.netSportbikeTrackGearCheapCycleParts.comSpringfield ArmoryKomodoGear.comRacerPartsWholesaleNice CycleBazzaz PerformanceJazzMotorsports.comSee your ad here!
Old 03-31-2005, 09:29 AM   #1 (permalink)
badboys21
Sportbike: yamaha yzf r6
badboys21 is on a distinguished road
Question Problem with chain on 520 conversion..help...
I just did a 520 conversion 2 weeks ago, I live in Ohio so the weather just finally broke this past week. I have taken my 6 out 2 times this past week and I have noticed that my chain slaps really really bad when I am riding. The top of the chain tracks fine, but the bottom half of the chain slaps up and down pretty bad. I put my bike on my rear stand and measured the chain, i have 1.2 inches of slack, which is in spec. BUT, when i roll the wheel forward a few inches the chain tightens to 1/2 inch, i roll the wheel forward more and it slacks back to spec, then i roll it forward and it goes back to 1/2 inch. There must be some tight spots on the chain, my question is this, Is the chain ruined and I need a new one? Or is there a way to loosen the chains tight spots? The chain is brand new, its an RK Chain XSO520 gold. Any help would be appreciated please....
badboys21 is offline   Reply With Quote
Old 03-31-2005, 09:34 AM   #2 (permalink)
BluFireF4
Superbike Champion
BluFireF4's Avatar
Sportbike: 00 Honda F4
BluFireF4 is an unknown quantity at this point
id say just tighten the chain. Mine was the same way when I got my new chain.
2003 Honda CBR 600RR
+ Puig Race Screen - Dark Smoke
+ Clear Alternatives Integrater - Smoke
+ Scotts Damper
+ GPR Full Ti Exhaust
+OEM Rear Cowl
+PCIII
BluFireF4 is offline   Reply With Quote
Old 03-31-2005, 09:57 AM   #3 (permalink)
badboys21
i should have said this also, I tighten it to 1/2 inch slack, still slaps bad, loosen it to 1.2 inch slack, does the same thing, I am baffled. Actually I am pissed cause I can not figure this out. Tight or loose, same slapping...aarrrggggg!!!!!!!!!!!!!!!!
Old 03-31-2005, 09:58 AM   #4 (permalink)
RhythmsDJs
RhythmsDJs's Avatar
Sportbike: 2001 Yamaha R6 Cobalt Kandy Blue/Orion Silver
RhythmsDJs is on a distinguished road
I suspect a couple things. First, have you made sure that your rear wheel is in alignment? If not, your sprocket could be out of line with your front sprocket causing your chain to bind. Also, the chain may be defective. Pull the chain away from the back of the rear sprocket, on the point that is furthest away from the front sprocket. If it pulls away from the sprocket more than a couple tenths of an inch, then your chain could be bad. Are you measuring your slack at the midpoint between the front and rear sprockets, on the bottom travel of the chain, from however far down the chain hangs to it's upward most point when you push up on it? That should be roughly and inch or so. I would adjust the alignment, adjust the tensioners, and try it from there. You will also probably want to lube the chain and make sure all the rollers are fine. Once you have put about 20 miles or so on the chain, make sure you readjust the tension.
SBN Super Moderator
If you have any questions or problems, feel free to PM me and I'll be happy to help.
Check out the Annual WI Memorial Day Charity and Benefit Ride
Official "Memorial Day Ride" Website
Ride for you, not anyone else.
Check out the new paint and Artistimo's awesome work
RhythmsDJs is offline   Reply With Quote
Old 03-31-2005, 10:24 AM   #5 (permalink)
badboys21
Default Problem with chain on 520 conversion..help...
Old 03-31-2005, 10:33 AM   #6 (permalink)
Eyespy
Some assembly required
Eyespy's Avatar
Location: Native New Yorker residing in Southern California
Sportbike: 2004 Silver R1 (x2), 2000 Red R1, 1987 FZR 1000, 2002 XR400, 2002 XR50 (x2)
Eyespy is on a distinguished road
The sprocket may be out of round. Which sprocket set did you purchase?
The Liberal Meltdown has begun
*Given the controlled conditions of temperature, pressure, and atmospheric composition, the organism does whatever the hell it pleases.
*There are only two types of riders in this world: Those that divide the world into two types of riders, and those that don't.
*There are only two things that are infinite: Stupidity, and the Universe. And I'm not so sure about the Universe.
*Give Natural Selection a chance. It works.
*All bleeding eventually stops.
MTC Track Day, "For a fun day at the track"
My Bikes Website
2004 Red/Black/White R1 (track)
2000 Red/Black/White R1 (track)
2004 Silver R1 (street)
1987 FZR 1000 (street)
2002 XR400 (dirt trail)
2002 XR50 (x2)
Eyespy is offline   Reply With Quote
Old 03-31-2005, 10:48 AM   #7 (permalink)
badboys21
I bought the Vortex front and rear sprocket. I bought a set, the chain and sprockets. Its wierd, I counted on both sides and the marks in the swingarm are the same distance. when i put it on the rear stand and put it in gear and watch the tracking of the chain, there is no wobble or any unusal tracking issues I can see, I look at the chain from behind the bike, but when I look at the bike from the side watching the chain go around, i see the chain shake up and down in certain spots, if i give the bike gas, the chain shakes in spots faster obviously.
Old 03-31-2005, 11:15 AM   #8 (permalink)
Eyespy
Eyespy's Avatar
Perhaps the installation was faulty and the master link is binding. Does the tight spot coincide with the master link? Rivot or clip master link?
My Bikes Website
2002 XR50 (x2)
Old 03-31-2005, 12:05 PM   #9 (permalink)
andrew_02
andrew_02's Avatar
Casino Cash: $5129
Sportbike: '01 6r
andrew_02 is on a distinguished road
That sounds really wierd to me. A new chain shouldn't have tight spots that early.
I've never heard of anyone loosening the tight spots.
The only thing i can think of is, are you sure that your rear wheel is aligned right, I wonder if that would effect the chain.
andrew_02 is offline   Reply With Quote
Old 03-31-2005, 12:58 PM   #10 (permalink)
LifeLiberty
LifeLiberty's Avatar
Sportbike: KZ750 KZ550
LifeLiberty has disabled reputation
alignment was first thing I though of. measurement of chain is a tightest spot. maybe warped sprocket? you changed both sprockest and chain right? i would recheck/remounty everything.
Kawasaki KZ750 twin, KZ400
LifeLiberty is offline   Reply With Quote
Old 03-31-2005, 01:19 PM   #11 (permalink)
badboys21
thank you all for giving me suggestions. The chain was full of this white waxy looking sh&^%t, very hard to get off your hands and anything esle you get it on!!!...I just spoke with the place I bought the kit from and he said they had a bad batch of rear sprockets from Vortex and if my sprocket has the same part number as the bad batch, he will send it out tomorrow. Would a bad sprocket cause that binding issue?...
Old 03-31-2005, 01:20 PM   #12 (permalink)
badboys21
Old 03-31-2005, 02:15 PM   #13 (permalink)
LifeLiberty
yep, especially if it is out of round and more of an oval shape or if all the grooves between the teeth are not all the same. or if it is warped like a rotor gets warped
Old 03-31-2005, 02:39 PM   #14 (permalink)
Süsser Tod
Urban Guerrilla
Süsser Tod's Avatar
Casino Cash: $6199
Sportbike: 2005 Yamaha XT660R - 2005 Yamaha RXZ-135
Süsser Tod will become famous soon enoughSüsser Tod will become famous soon enough
Well, if the sprocket is bad, yes. That kind of behaviour is only seen on old chains, and there is no way to fix the tight spots.
Süsser Tod - Ich bin der ungelebte Traum
Süsser Tod is offline   Reply With Quote
Old 03-31-2005, 02:49 PM   #15 (permalink)
RhythmsDJs
RhythmsDJs's Avatar
Never trust the markings on the swingarm, there's no room for accuracy. Always use the string method or measure to the center of the axle from the swingarm pivot point.
SBN Super Moderator
