I believe the exup valve is located in the mid-pipe so if it is a full system, it should be history. this is what I would do at this point. I would go to this website and get a servosub. look and see if you still have a servo, if you do not you will have this display. you could put another motor on, but it would probably be easier to put a servosub on instead.
www.samannasystems.com
hope this helps and shoot me a PM if you got more questions. I can find out the answer to just about anything if I don't know it already.
