WilzGarage
Go Back   Sportbikes.net > Topic Discussions > Help Me Fix It > Service Bulletins and Recalls > Yamaha Line
Yamaha Line Listed Recalls and Bulletins for the Yamaha Line Motorcycles.
Bazzaz PerformanceBazzaz PerformanceSumOfAllParts.netSixty61JazzMotorsports.comSportbikeTrackGearNice CycleArnottAirRideAvonTyresD2MotoSee your ad here!
Old 12-13-2006, 12:25 PM   #1 (permalink)
Fred
Chief Booty Knocker
Fred's Avatar
Casino Cash: $13407
Sportbike: 2007 GSX-R600 Race / 2003 GSX-R750 Street
Fred will become famous soon enoughFred will become famous soon enough
Total Awards: 4
Default 2004 YZF-R1 Upper Engine Mount Loosening - M2004-005
Symptom: The upper engine mount bolts could
loosen over a period of time on some units in the
affected range.
Cause: There is a foil-backed rubber insulation
sheet below the air box. During assembly at the factory,
the outside edge of this sheet may have fallen
between the engine and the upper engine mount
(frame-to-cylinder head mount) and become
pinched.
Remedy: Check to see if the insulation sheet is
pinched between the engine and upper mount on
both sides according to instructions in this bulletin. If
the insulation sheet does not appear to be pinched, check the mounting bolts to confirm proper torque.
If the insulation sheet is pinched on either or both sides, follow the procedure in this bulletin to remove
the bolts, pull the insulation sheet out of the way, and then reinstall and torque the bolts.
Fred
SBN Administrator & Webmaster
Sportbike - 2007 Suzuki GSX-R 600 Race Bike / 2003 Suzuki GSX-R 750 Street | Cruiser - 2006 Harley Davidson Street Glide
Sportbikes.net Online Store - Videos, Undertails, T-SHIRTS, etc..
Fred is offline   Reply With Quote
Used motorcycle evaluation guide Rascus General Sportbikes 10 06-05-2008 06:09 PM
Warm engine/weather - better gas mileage Jimundascores FZ6 26 05-05-2006 09:53 AM
Holy F*ing Super-Light, Huge HP, New Engine Design. Grashopr General Sportbikes 22 01-14-2006 09:32 AM
