1999~2005 YZF-R6 and 2004~2005 - Technical Bulletin - Bulletin Number M2006-003
1999~2005 YZF-R6 and 2004~2005 FZ6 Drive Sprocket Retaining Nut and Lock Washer Replacement
Technical Bulletin
Symptom: In some cases, the drive sprocket
retaining nut lock washer can allow
the nut to rotate just enough to
reduce the clamping force resulting
in fretting the drive sprocket retaining
nut and lock washer.
Remedy: Replace the drive sprocket retaining
nut and lock washer on all units
in the affected range regardless
