Originally Posted by Mad Max
What about the gyroscopic effects?
I thought part of the reason a 250 could out corner larger bikes is because of the fact that there is less of a gyroscopic effect from the motor.
Also, 250's have much smaller wheels and tires which also have less of a gyroscopic effect.
Ahhh, we delve deeper... Two strokes and smaller 4 strokes have less internal rotating mass in general.
Gyroscopic effect comes in to play primarily when we make side to side transitions... in the essess and chicanes!
Look at the new ZX10R...
Same weight as the 600SS bikes. But it's crankshaft is much heavier and has far greater
inertia,
or gyroscopic effect. Oh yeah, it's flickable! Just not as much as it's 600SS league weight would have you think!
On to smaller wheels, tires and brakes.
Brakes make up a large portion of unsprung weight and rotational inertia.
Not to bore you with mathmatical formulas here, but as that additional wheel weight rotates it gains significant inertia.
This 'gyroscopic' effect coupled with larger width wheels and heavier tires will cause a noticeable
slowdown in side to side handling. Along with slower braking and acceleration to some extent.
The Honda 954 had HUGE rotors. Where are they now on the latest SS bikes?
Gone! Replaced by more efficient radial mount calipers on smaller rotors.
The smaller wheels and tires on 250 and 125 GP bikes do not hinder lateral grip at operating lean angles at all!
The contact patch,
when leaned over , is quite similar between a 140 series and a 190.
The larger tire offers a larger patch and more grip under power when standing upright.
In summary, the lighter bikes have an inherent advantage in a curve.
With two bikes of equal mass, the one with less
gyroscopic intertia will have the advantage in side to side chacane transitions.
Look at the GSXR750 whoop up on the literbikes on tighter tracks. And 600s too!
Sorry for the Blog! Kevin Cameron is one of my heros.
