GravesMotorsports
Go Back   Sportbikes.net > Topic Discussions > On The Track
On The Track Had a trackday, a good or bad day at the track? Want to get started racing? Just like racing? Cmon insde and post questions, results or comments.
Springfield ArmoryHardRacing.comSuperbikeToyStore.comCheapCycleParts.comAdaptiv Technologies LLCKomodoGear.comJazzMotorsports.comSportbikeTrackGearBazzaz PerformanceWilzGarageGravesMotorsportsNice CycleSportbikeTrackGearSumOfAllParts.netSee your ad here!
Old 07-30-2007, 11:54 AM   #1 (permalink)
EXTremist
Casino Cash: $252
Sportbike: 2007 Yamaha R6s
EXTremist is on a distinguished road
Default Help please - severe "chatter" under hard braking?
Hi Guys,
I'm not a racer but figured you guys might be able to shed some light on this phenomonon I experienced this weekend.
I had the opportunity to put about 15 laps on at a local 1/2 mile oval this weekend as part of a charity ride. I rode the track mostly in 3rd gear going down to second occassionaly when I needed to slow down for traffic.
The corners were high banked but the apex's fairly flat. I ride a stock 2007 R6s.
Several times under hard braking I would get the sensation and noise that the bike was severly chattering (felt almost like the fornt end was bouncing slightly) it was scary and dangerous feeling. I would let off the brakes slightly and pull in the clutch to get it to stop. Once or twice I slightly skidded the back tire. I just don't know what to make of this...the bars felt tlike they were jumping a bit in my hands and it seemed like it would escalate until I let off and pulled in the clutch.
What was I doing wrong, or what could this have been? Any ideas?
Thanks!
EXTremist is offline   Reply With Quote
Old 07-30-2007, 03:29 PM   #2 (permalink)
Mantis
Go #214!!!!!!!!!!!!!!!!!!
Mantis's Avatar
Casino Cash: $6166
Sportbike: 02 GSX-R600 Telefonica, 00 SV650 (race, supersport), 02 SV650 (race, superbike), TL1000R, DRZ400SM
Mantis is on a distinguished road
How hard were you downshifting? I would experience the rear wheel skidding if I downshifted without matching revs or just downshifting to the wrong gears. I don't understand completely, is it the front or rear wheel "chattering"? If you pulled in the clutch and it stopped you weren't matching revs or just downshifting into too low of a gear.
GO #214!!
CCS/ LRRS Expert #214
Mantis is offline   Reply With Quote
Old 07-30-2007, 09:33 PM   #3 (permalink)
GSXR RACER MIKE
Roadracer since '96
GSXR RACER MIKE's Avatar
Casino Cash: $15313
Sportbike: 2002GSXR750 1999GSXR600 1996GSXR750
GSXR RACER MIKE is on a distinguished road
Sounds like rear wheel hop to me as well (like Mantis said) by the info you've provided so far.
If it truely were front end related it could be from low tire pressure or improperly set fork damping (I would guess compression damping too stiff/slow).
More info please.
"ON THE TRACK" forum MODERATOR
GSXR RACER MIKE is offline   Reply With Quote
Old 07-31-2007, 12:23 PM   #4 (permalink)
Mmelmann
I beat air to submission
Mmelmann's Avatar
Casino Cash: $756
Sportbike: GSXR 1000 K6
Mmelmann is on a distinguished road
It sounds like your suspension isn't set up properly to me. I used the specs off of sportrider.com under their tech/suspension section as a base line setting. I then visited a suspension guy to fine tune my settings... and there is still room for improvement. If you really want to learn about your suspension, I'd recommend reading Twist of the Wrist or Total Control. They are both pretty dry reading material, but it helps if you actually want to learn how to setup your suspension to meet your weight and riding style requirements. A street setup will obviously be different than a race setup.
NESBA I #55
Mmelmann is offline   Reply With Quote
Old 08-01-2007, 03:02 PM   #5 (permalink)
EXTremist
Casino Cash: $252
Thanks Guys!
It sounds as if the rear tire skipping is the most probable explanation, althought I seemed to feel it heavily in the front as an effect.
Thanks for the suspension setup site tip/s etc. It's a bit overwhelming with all the adjustments. this track I was on had tons of rubbber laid down from car racing on it and was extermely grippy so I could see how engine braking combined with a heavier foot would make the rear tire skip rather than just slide.
Do most of you machine/alter your rear brake to make it less effective/prone to locking the rear up? I always adjust my rear lever downward on a new bike so it takes more effort to apply the rear.
Any other tips are greatly appreciated.
Thanks again!
Old 08-01-2007, 03:14 PM   #6 (permalink)
Mantis
Mantis's Avatar
Casino Cash: $6166
Originally Posted by EXTremist
Thanks Guys!
Thanks again!
I'll put some air in the rear brake, but to be honest I never touch it when racing unless I'm in off the track in the grass
GO #214!!
Old 08-01-2007, 11:13 PM   #7 (permalink)
GSXR RACER MIKE
Roadracer since '96
Casino Cash: $15313
I've never used my rear brake while racing. Something I was told is always keep the original rubber brake line on the rear brake because it will allow some expansion of the brake line, that way the rear brake isn't quite as sensitive as a braided line would make it.
Old 08-01-2007, 11:20 PM   #8 (permalink)
Luvin' Twins
What did I do?
Luvin' Twins's Avatar
Casino Cash: $10585
Sportbike: No bike now, only my getaway sticks
Luvin' Twins is on a distinguished road
I took mine to the same specs as a baseline. This winter may be a time to go through the suspension and get it set up for me. When I got the bike initially, I felt the same kind of hop or almost chatter, it did feel like the front end to me and tire pressure was fine.
Originally Posted by Anonymous Harley Rider View Post
With all the money Harley invests in R&D these things should still have wooden wheels.
Army Veteran 1995-2004
Luvin' Twins is offline   Reply With Quote
Old 08-02-2007, 11:24 AM   #9 (permalink)
Mmelmann
Mmelmann's Avatar
Casino Cash: $756
Agreed. I don't use the rear brake at all... even on the street. Unless you are riding a 2-stroke, the engine will provide most, if not all, of the rear braking forces that you'll need. My rear will dance around a little bit and basically act like a rudder to keep the bike in line when I'm braking at full force when entering a corner... so applying the rear brake isn't going to do anything but make matters worse off... possibly giving you a high side. Try to focus on solely using your front brake and keeping your body weight as low and aft as possible... focusing on sqeezing the tank with your legs and keeping as much weight off the handlebar as you can. Thighmaster workouts for the win. j/k
NESBA I #55
My newbie question: braking and cornering morrison New Rider Forums 12 06-18-2007 02:27 AM
Response to safer group street riding, decent read: "The Pace" OldSkoolFool General Sportbikes 3 05-08-2007 04:03 PM
the pace ped FZ6 9 01-23-2007 03:00 AM
Lookin For Some People To Do Some Real Riding KEVCBR97 Florida 18 07-24-2006 11:55 AM
With all this talk about braking i have an article... freakinhungover Las Vegas 0 01-03-2005 02:40 PM
