British Motorcycle Gear
Go Back   Sportbikes.net > Topic Discussions > On The Track > Track Time-101
Track Time-101 Information and advice on all things related to getting on a road course yourself
BluTek HelmetsJardineProducts.comBikeBanditGravesMotorsportsBritish Motorcycle GearCycleGear.comMotorcycle.com Classifieds!AdvanstarMotorcycleShowsSoupy's PerformanceSee your ad here!
Closed Thread
Old 03-29-2006, 09:59 PM   #1 (permalink)
GSXR RACER MIKE
Roadracer since '96
GSXR RACER MIKE's Avatar
Casino Cash: $30211
Sportbike: 2002GSXR750 1999GSXR600 1996GSXR750
GSXR RACER MIKE is on a distinguished road
Default Basic bike prep for the track
Basic bike prep for the track is not that bad, actually it's alot easier than many may think and is something you can do in a relatively short period of time. The main purpose of prepping a bike for the track is to increase safety by preventing fluid leaks, stopping things from coming loose (especially things that become an immediate safety concern if they loosen or come off), and minimizing debris in the event of an incident. The following is advice based on the race and track day organizations I personally have dealt with so make sure and check with the specific organization(s) you will be dealing with to verify what their specific requirements are (or lack of) for getting on the track with them.
The debris that is of specific concern is the various lenses on a bike, from the headlight, to the tail lights & turn signals, to the lenses over your gauges. Any of these lenses can break into many pieces in the unfortunate event that you find the contact patch of your bikes tires no longer touching the ground. Lens fragments have the potential to rupture a tire or cause loss of traction momentarily if another bike runs over them, also of concern is the Corner Workers getting cut by them as they hurry to clean up any debris on the track - often times while the bikes continue to go by. To try and prevent this situation many Track Day Organizations require you to remove or tape over ANY lenses you have on the bike, race organizations will most likely want or prefer all lenses off the bike (except for the guages). The tape will help to keep any broken lenses stuck together and minimize any pieces from ending up on the track. The lenses over the guages should be taped over leaving only the number portion of the tachometer, the temperature guage, and any 'idiot lights' able to be seen. Your speedometer is more of a hindrance than a help and should be covered completely, the distraction of looking to see how fast your going can take valuable focus off the track and in some cases cause you to go faster or slower than you should be based on how fast you 'THINK' you should be going at that time.
Anti-freeze (Ethylene Glycol) is one of the slipperiest substances known to man, for this reason almost everyone (Track Day or Race) will be required to remove all of it from their bikes cooling system (including the reservoir). The exceptions to this rule will probably be limited to 1st timers on the track in the beginner group or possibly some riding schools. The specific requirements of each Track Day or Race Org will determine if you can use anything other than straight water in your bikes cooling system, when using water in your bike without any additives USE DISTILLED WATER! Anti-freeze serves multiple purposes, it increases the boiling point of water, it stops freezing down to a certain temperature, acts as a lubricant for your water pump, and helps to stop corrosion in your cooling system. Tap water has minerals and such in it that can cause problems in your cooling system over time, distilled water has most impurities removed and will help to keep cooling system corrosion to a minimum. Additives like Water Wetter are designed to be added to your cooling system to act as a lubricant and help increase the boiling point of water, these additives are approved for use by most of the track day and race org's - but check with them directly about the specific type you may want to use. If you do go with water as your coolant - MAKE SURE AND DRAIN ALL THE WATER OUT OF YOUR BIKE OR ADD ANTI-FREEZE BEFORE WINTER! I race with CCS and we are allowed to use a high tech coolant that is called 'Non-Aqueous Propylene Glycol', this coolant is run straight with absolutely NO water in the system what-so-ever. The big advantages of this coolant is it's non-toxic (you could actually drink it - though highly NOT suggested), it's not near as slippery as Ethylene Glycol (but it's still a water pump lubricant), it doesn't allow corrosion, it doesn't freeze till all life on Earth has ceased, it doesn't begin to boil till 370*, it's a lifetime coolant - meaning it NEVER has to be replaced, and it transfers heat better than most anything else out there! The $25 per gallon price scares some people away from using it, but when you only need a gallon or two for a bike it's really not that big of an investment and the stuff is truely amazing.
Fluid leaks are of major concern with motorcycles, many race organizations now require 'fluid retaining lower fairings' on all race bikes, these have the ability to hold the fluid contents of your motor and radiator in the event of a catostrophic failure. Track Day org's generally won't require a fluid retaining lower except for possibly the advanced group - which will be mainly comprised of alot of racers anyways. Make sure that your radiator cap fits correctly and that your overflow line is connected to the overflow resevoir, also check to make sure all fluid carrying lines are connected with some type of retention device whether its radiator clamps, pinch rings, safety wire, or etc. and that they are fastened firmly and correctly. Though I don't believe any Track Day org's require it, Race organizations will most likely also require a 'catch can' of some designated minimum volume to be used as well, this container is used to capture any fluid overflow from ANY fluid overflow lines on your bike. There are actual 'catch cans' out there, but many people just use a sports drink type plastic bottle with a screw on cap that fits securely (CCS says you have to have a container which is heat resistant - so it basically just can't melt from overflow from the engine). You can drill holes thru the cap, stick the overflow lines thru the holes, poke a piece of safety wire thru the sides of all the overflow tubes under the cap and twist the ends of the wire to itself creating a loop (to stop the tubes from falling out). Make sure there is a vent hole or tube on the overflow container so any overflowing fluid being fed into it isn't trying to be forced into a sealed container (which won't work). The vent hole or tube from the catch can should be at the top of the container and should route to the airbox for your engine. If you don't use a catch can you need to route all overflow lines to the engines airbox so fluid will be burned by the engine (as per CCS rulebook).
The purpose of safety wire is usually to stop things from unscrewing and is available thru your local automotive supply or motorcycle shop in small spooled cans, if they don't stock it, they can get it. Since a can of it may last you for the rest of oblivion you could just ask if they would give you some of their's because your such a great customer - even offer to bribe...oops...I mean...pay them a couple dollars if you have to (you should only need several feet of it - so if you get 10 feet of it that will last you a while). This wire is very durable and is designed just for this purpose, I would highly suggest using actual 'safety wire' over something else. I won't go into the depths of safety wiring since there is info out there on how to do it, I will probably make a subject on it in the near future in this section as well. What I will say here is that you basically drill a small hole (apx 1/16" to 3/32") thru the head of a bolt or screw and a nearby tab or bracket, then insert a piece of safety wire thru the hole in the bolt head till there is a little length of it on each side of the bolt, now wrap one end of the safety wire around the outside of the head of the bolt till it comes back to meet the other end of the safety wire (not over the top of the bolt head), now twist the two together (not too tight) until you have enough twisted length that it's almost to the fixed object you also drilled, insert 1 end completely thru the fixed object, continue twisting the two ends of the wire together on the other side of the tab or bracket for another inch or so, now cut off the excess. The wire should be somewhat tight so as to not allow the bolt to unscrew during intense vibration from high RPM's. I realize this may be somewhat difficult to visualize, but I'm without a digital camera currently so I can't get any pic's to show an example, search the web if you need more info immediately. The main bolt you will need to safety wire is the oil drain plug under the engine, if you have a water drain plug that will need it as well. The Oil filter is also required to be safety wired usually, this is done by getting a radiator clamp from an auto parts or hardware store that is big enough to go around the filter, just tighten the radiator clamp down firmly around the oil filter over a piece of safety wire and wire it to a fixed object as described previously to stop the filter from coming unscrewed. Another requirement is to safety wire the oil filler cap, some race org's require the radiator cap as well. WERA race org in particular is known for having a shopping list length of things you need to safety wire in order to race with them, though that can be somewhat time consuming, it ultimately is for your safety. Something else that will probably be required to safety wire is the kick stand if you don't remove it, I probably don't have to describe to you how bad it would be if your kick stand flopped down during hard braking and when you went to turn the kickstand pivoted on the pavement instead.
Lastly you want to have some general maintanence things up to par as well. Your chain should be adjusted properly (check your owners manual), a chain that is too tight will inhibit swingarm and suspension travel, if it's too loose it has the potential to come off or skip teeth under hard acceleration. Make sure that you have plenty of life left on your FRONT brake pads as well, minimal friction material on the pads will transfer heat into your calipers and brake fluid quickly and can boil your brake fluid much quicker causing loss of braking performance. There are many aftermarket tires available, but the main thing to just get out on the track is to have tires that are in decent shape, you really don't want tires that are 'flat spotted' in the middle of the tire from street riding, this causes poor handling when you transition from verticle to leaned over. Street tires will definately begin to slide sooner (when pushed hard) than actual performance tires, but street tires should be fine when 1st getting out on the track for a track day (unless your an ultra-fast street rider). An advantage track/performance tires have is in the construction and orientation of the belts in the tire, race tires are designed for cornering where as street tires are generally designed for comfort while riding vertically, high cornering loads are not the focus of many street oriented tires. Frame sliders could also be some cheap insurance to help limit or reduce damage to your bike in the event of a "whoops", but they are not require to the best of my knowledge.
What ever you choose to do (track day or race) make sure and have fun, that's what being on the track is all about!
"ON THE TRACK" forum MODERATOR
GSXR RACER MIKE is offline
Old 04-02-2006, 11:04 PM   #2 (permalink)
endoracing
I ride.. competitively.
endoracing's Avatar
Casino Cash: $469
Sportbike: 01 CBR f4i
endoracing is an unknown quantity at this point
where can you find this "Non-Aqueous Propylene Glycol"? And is it legal at all tracks that CCS runs at ?
CCS MW #121 - Retired, WERA NC #121
Race bike; 01 CBR f4i
I found god ... he has a #46 on his bike.
endoracing is offline
Old 04-02-2006, 11:14 PM   #3 (permalink)
GSXR RACER MIKE
Roadracer since '96
Casino Cash: $30211
It's legal for CCS, I don't know of any tracks that prohibit it's use.
It's made by Evans, they have different types of coolant, but you definately want the NPG which uses absolutely no water (not NPG+). Here is a LINK to the motorcycle section of their site. If you want to read some really interesting stuff about how and why this stuff works so well read the technical section on that site, lot's of great information there that will most likely change your opinion about water based coolants.
Old 04-02-2006, 11:18 PM   #4 (permalink)
badgixxer
Combat Marshmellow
badgixxer's Avatar
Casino Cash: $55382
Sportbike: Retired
badgixxer has disabled reputation
i use water wetter in both the race and street bikes with no problems...
ASMA AM #75
GF&T Racing - Ultimate Imports, ECS Dyno, Stalemate27 Custom Paint, ASMA Trackside Support
badgixxer(3), Philbie(4), TSAVO5150(4), ur2ez(1), Faster Sissy(2), Sometime Racer(12), kz2zx(3), MO(1), FWrider(6), pbandj19(5), gixerking(1), SilentR1(3), Jordan121787(4) toyotapower(9 and counting ), GoSlow&Crash(1), Zach (1)
Arroyo Seco, Firebird, HPT, MAM, JenningsGP, MMP, Hallett, Putnam Park.....
badgixxer is offline
Old 04-02-2006, 11:29 PM   #5 (permalink)
GSXR RACER MIKE
Roadracer since '96
Casino Cash: $30211
I have heard many people say that very thing about Water Wetter and similar products, I'm certainly not saying there is anything wrong with them. But if you have never read what the benefits of Non-aqueous Propylene Glycol are I would highly encourage you to at least read about it, it's used in everything from Nitro-Methane 1/4 mile drag cars to high mileage semi fleets (both of which need to cool down intense heat). The capability of this stuff to remain in direct contact with metal up to higher temp's and transfer heat much more efficiently is what makes it so great. I have run this in my last 2 race bikes without a fan and have had great results with it, you never hear my bikes cooling system hissing after a race and neither bike has ever boiled over since I started using it. This is just my personal experience with the stuff, so everyone should take it as only that.
Old 04-02-2006, 11:32 PM   #6 (permalink)
badgixxer
Combat Marshmellow
badgixxer's Avatar
Casino Cash: $55382
Sportbike: Retired
never had any experience with it but if it works as well as you say i may have to give it a try next time i flush the cooling system on the race bike - i also run without a fan and the ambient temperature in the summer is pretty high in the southwest so i worry alil when i have to sit on the line too long...
thanks for the info
btw - excellent write up
ASMA AM #75
Old 04-02-2006, 11:38 PM   #7 (permalink)
endoracing
endoracing's Avatar
Casino Cash: $469
seems like a lot of money is my only problem ... 32.50 a gallon plus 28.xx a gallon for the prep stuff ...
Not to mention you have to get the engine up to temp about 3 seperate times in the flush process which can't be great on the plugs (mine are barely hanging on as it is from a few test rides) and a set of plugs is about 50 bucks for the f4i ..
Old 04-02-2006, 11:47 PM   #8 (permalink)
GSXR RACER MIKE
Roadracer since '96
Casino Cash: $30211
As I said the price scares many, apparently it went up since I bought mine. What I did is buy 4 gallons at a discounted price, flush the system with water thouroghly, emptied as much of the water out of the system as I could, then used a sacrificial gallon as a flushing medium. After using that I drained it but kept it and marked it "for flushing only", then used the same stuff to do a freinds bike so we split the cost of the flushing gallon. After popping the freeze plugs in my '96 GSXR 750 when I forgot to drain the water out of the bike at the start of the winter I figured the cost was insignificant, but I feel your financial pain! Another issue was at the events where it was getting really cold over night, like at Road America so many times, guys were having to drain the water out of there bikes to stop from popping their freeze plugs, with this stuff you never have to worry about it again!
Old 04-02-2006, 11:52 PM   #9 (permalink)
badgixxer
Combat Marshmellow
badgixxer's Avatar
Casino Cash: $55382
Sportbike: Retired
when it come to the race bike you can't scrimp....you get what you pay for...
ASMA AM #75
Old 04-03-2006, 09:10 AM   #10 (permalink)
endoracing
endoracing's Avatar
Casino Cash: $469
it seems like they want you to run a full system of the prep stuff before using the coolant itself ... thats what I dont like. would 1 gallon of the prep stuff be sufficient and then just the coolant needed to fill the system ?
Old 04-03-2006, 10:43 AM   #11 (permalink)
GSXR RACER MIKE
Roadracer since '96
Casino Cash: $30211
The prep stuff is apparently new, they didn't have that before. I only needed 1 gallon to fill the system, so 1 gallon to flush with was plenty for my GSXR's. If you REALLY don't want to do the flushing stuff you could use water like I did, then take off the lower radiator hose and have someone help you tip the bike way over to try and get as much of the water out as possible. Then with it leaned over take an air gun with compressed air and blow out the cooling system by covering the radiator fill with a rag and sticking the nozzle thru it, just be careful that it's not sealed off some way and building pressure in the cooling system. This will get most of the water out of the system and the water that's remaining should boil off over time. It may not be the correct way to do it, but I think it would work fine in my opinion. The main thing the flushing stuff does is to dillute any remaining water in the sytem so when you drain it the little bit of fluid in the sytem is mostly NPG.
Old 04-09-2006, 09:03 PM   #12 (permalink)
endoracing
endoracing's Avatar
Casino Cash: $469
so.... say it does get "contaminated" with water .. what is the worst that would happen?
I only ask because I just changed over my bike and it seems like it should have taken a lot more fluid than it did, leaving me to believe it has a lot of water/prep fluid still in it ..
Old 04-09-2006, 11:49 PM   #13 (permalink)
GSXR RACER MIKE
Roadracer since '96
Casino Cash: $30211
Well, they say not to pressurize the system by closing your radiator cap all the way to the full locked position as well, but you can and it won't hurt either way. What will happen with either scenerio is that the water will reach a point where it will begin to boil and eventually steam out of the system, there certainly won't be enough water in the system to cause problems if it gets cold at the upcoming Road America event either. I know for a fact that there was a little water in both my bikes when I did mine, but it hasn't been a problem and I would imagine it was boiled off after the 1st event where I got the bike hot.
Another feature of NPG is that it stays in contact with the metal till 370* so the overheating temp on your temp guage is no longer accurate. The guage is based on a water based coolant which will boil around the cylinders much sooner and cause hot spots in the motor, with NPG the temp on your guage is much more accurately telling you the actual temp thruout the entire engine.
Old 04-09-2006, 11:53 PM   #14 (permalink)
AnKleBiTer
Nurse Nymphette
AnKleBiTer's Avatar
Casino Cash: $8073
Sportbike: HondaCRF 50 <smirk>
AnKleBiTer is a jewel in the rough AnKleBiTer is a jewel in the rough AnKleBiTer is a jewel in the rough
Total Awards: 4
WOW great post Mike!
Diana AKA ANKLEESTA
Proud member of the Pussy Posse 2005
Just call me Head Nurse...
I adore Chicago. It is the pulse of America.
- - - Sarah Bernhardt
My Old Avatar Was Courtesy of Shawn "Krazy Hawaiian" McCallister. RIP My Friend, I'll be thinking of you...
AnKleBiTer is offline
Old 04-10-2006, 12:08 AM   #15 (permalink)
GSXR RACER MIKE
Roadracer since '96
Casino Cash: $30211
If you REALLY want to get any remaining water out of the NPG that was already put in your bike you can drain all of it out of the bike and either boil it or freeze it to seperate the water from it. Boil it only if you have the capability to do it in a safe place (not in your house!) and freeze it inside of a container that won't contaminate any food also in the freezer (like a sealed container or wrap the hell out of it with plastic wrap). After it freezes lift the chunk of ice out of the still liquid NPG or you should be able to pour out the NPG and let it drain thru a filter if the water didn't freeze into a solid piece but instead froze into crystals.
Closed Thread
