K6 1000 will not idle - Sportbikes.net
Go Back   Sportbikes.net > Sportbikes > Suzuki Sportbikes
Suzuki Sportbikes GSX-1300R - Hayabusa, GSX-R1000, GSX-R750, GSX-R600, TL1000R/S, Katana, GS500F, Bandit, SV Series, RG500
Old 09-06-2012, 09:40 PM   #1 (permalink)
killa79
Gameroom cash: $515
Sportbike: 2006 GSXR 1000
killa79 is on a distinguished road
Default K6 1000 will not idle
Whats up everyone. I got a k6 1000 that will not idle. it ran fine and one day the clutch cable snapped. well I was sitting on the hydraulic setup for 2 years and finally decided to put it on. While at it decided to have the cam chain replaced at the same time. The bike has been put back together but for some reason will not idle. for some reason it is running rich at idle. I have tested the tps sensor, iap sensor, the timing is dead on. at first i thought a vacuum leak. checked all vacuum hoses and they are all good. if i disconnect three of the vacuum lines to the throttle bodies and only connect the remaining throttle body to the iap sensor the bike runs and idles fine. but when I hook them back up like it should be it wont idle. It is driving me nuts at this point. you can smell the extra fuel the ecu is dumping at idle and the plugs are black. Anyone else experience an issue like this. any help is appreciated.
killa79 is offline   Reply With Quote
Old 11-05-2012, 07:16 PM   #2 (permalink)
indianaroadracer
SBN Newb
indianaroadracer's Avatar
Gameroom cash: $859
Sportbike: 08 Triumph Sprint, 98 GSXR 750, 94 XJ600
indianaroadracer is on a distinguished road
Did you figure out this problem? I would be curious if its running on all four cylinders when its idling rough.
indianaroadracer is offline   Reply With Quote
Cold idle good / Warmed idle bad: Help pls NJGSXR600 Help Me Fix It 6 02-01-2012 04:46 PM
'06 GSXR 1000 lag just off idle joshmentzer Help Me Fix It 19 08-07-2006 01:49 AM
bad idle, off-idle stumble aberrant Honda Sportbikes 0 06-30-2004 04:27 PM
1988 FZR 1000 bogs off idle ! coolatula Help Me Fix It 7 04-17-2003 04:32 AM
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
