tail light/brake light problem - Sportbikes.net
Suzuki Sportbikes GSX-1300R - Hayabusa, GSX-R1000, GSX-R750, GSX-R600, TL1000R/S, Katana, GS500F, Bandit, SV Series, RG500
User Tag List
post #1 of 5 (permalink) Old 07-28-2007, 05:49 PM Thread Starter
GIGGITY GIGGITY
Quoted: 0 Post(s)
Exclamation tail light/brake light problem
i got a problem on my '07 gsxr 750. when i apply the brakes on the lever/foot the brake lights don't go on. i checked the fuses including the main fuse. checked the connectors going to the rear lights and other harnesses/connectors. i thought it had something to do with the rear fender removed, but i connected it back and the brake light still doesn't work. i know it was working last week because i saw it reflecting on someone's car. any idea what the problem could be?
soobieajax325 is offline
post #2 of 5 (permalink) Old 07-28-2007, 07:16 PM
brent98rt's Avatar
Quoted: 0 Post(s)
did you check the bulb?
do your turn signals work?
2006 LTR450 #701 Firebird Cup Beg. class points leader
1997 CR125
1999 CR80(For Sale)
brent98rt is offline
post #3 of 5 (permalink) Old 07-30-2007, 06:52 PM
you smokin track?
singletrackmind's Avatar
Quoted: 0 Post(s)
I have both a 05 1k and a 05 600. the switch is the same for both and I beleive that the switch is similar for most suzuki's. check for the spring attached to the break pedal. there is a black housing that is normaly closed but opens to turn on the brake light. also make sure the switch is not stuck in any one position. my 6 has aftermarket rearsets and doesen't have a mount for the switch. the only time i use my rear is if I run off at the track so it not working is not a issue.
matt
you don't know when, you don't know where, but you will know why.
Rider Resume:
Tire mounting and balancing, small puncture repair, lighting, and scheduled maintenance. services available 24/7. I work for beer.610-299-4017
singletrackmind is offline
post #4 of 5 (permalink) Old 07-30-2007, 08:16 PM
RayOSV's Avatar
Quoted: 1 Post(s)
If the brake light works with the front brake, the problem is probably in the rear brake switch as posted above. If the brake light doesn't work with the front brake, check the bulb. Is it LED? If yes, could be the control board. Is it a dual filament bulb? If yes, does the tail light part of it work?
RayOSV is offline
post #5 of 5 (permalink) Old 07-31-2007, 03:33 PM Thread Starter
GIGGITY GIGGITY
Quoted: 0 Post(s)
matt
yup you were right about the spring on the brake pedal. i adjusted it and now it works fine again. thanks for all the help fellas. i appreciate it
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
im pissed Dont bake your tail lights !! RobTheGreat Florida 25 07-20-2007 12:48 PM
Tail light for '06? darkbluexplorer FZ6/FZ6R 2 06-21-2007 02:47 AM
01' F4i No Tail Running light suicidal Help Me Fix It 0 06-17-2007 11:13 AM
FZ6 LED light kit...no brake light GangstaSean676 Help Me Fix It 2 06-11-2007 05:18 PM
led tail light? xrookiex FZ6/FZ6R 2 03-21-2007 09:57 PM
You may post new threads
You may post replies
Refbacks are Off
