Nice Cycle
Go Back   Sportbikes.net > Sportbikes > Suzuki Sportbikes
Suzuki Sportbikes GSX-1300R - Hayabusa, GSX-R1000, GSX-R750, GSX-R600, TL1000R/S, Katana, GS500F, Bandit, SV Series
ArnottAirRideAdvanstarMotorcycleShowsChainDrain.comRacerPartsWholesaleSumOfAllParts.netJazzMotorsports.comWilzGarageSpringfield ArmoryMotoGiya.comKomodoGear.comCheapCycleParts.comSportbikeTrackGearSee your ad here!
Old 11-17-2006, 08:22 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
jk750
Moderator of Stuff
jk750's Avatar
Casino Cash: $9601
Sportbike: '04 GSX-R1000 - '02 GSX-R600 Track
jk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond reputejk750 has a reputation beyond repute
Default FI Codes
GSXR Fuel Injection Code List -
To read your code you will need to go into Dealer Mode. Don't panic, it's easy. The dealership has a 'special tool' for this but you can easily make your own.
Take off the front seat. Behind the battery you will find a white open ended 6 pin connector (might be 10 pin for k6?).
If it has a cap take it off and as you are looking at it jump the right wires top and bottom with a paper clip.
Turn the key to the ON position and you will see on your dash a C code where the temp would be.
(or C00 if you have no codes. This is often the case when the SET valve is the problem as the computer resets it if you turn your bike off, otherwise it would be C46)
It should be a 'C' with a number, like one of these >>>
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR
jk750 is offline   Reply With Quote
Old 08-17-2007, 09:57 PM   #2 (permalink)
kalikaputra
Sportbike: GSX R 600 K7
kalikaputra is on a distinguished road
What can these codes be used for?
The daily world exists because we know how to hold its images' consequently,if one drops the attention needed to maintain those images, the world collapses!!!!!!
kalikaputra is offline   Reply With Quote
Old 08-18-2007, 09:14 PM   #3 (permalink)
jk750
Moderator of Stuff
jk750's Avatar
Casino Cash: $9601
They can slice, they can dice. They can even julian.
Seriously, I don't understand the question. Obviously if your bike is running poorly, you can check to see if there is a code showing. The code might shed some light on where the problem is.
Old 08-21-2007, 05:04 AM   #4 (permalink)
kalikaputra
I know it was a numnut question,but I never do this deep level of service on bikes myself just the basic stuff. Learn stuff daily
Old 10-08-2007, 09:17 AM   #5 (permalink)
IanAnthony
Spoken in the FutureTense
IanAnthony's Avatar
Casino Cash: $931
Sportbike: 2007/Suzuki/GSX-R750
IanAnthony is on a distinguished road
This is perfect timing, I had the FI light come on two days ago. I only have 2,000 miles on her so far. I would much rather delve into it myself than take it to the dealer. Thank you for this thread!
IanAnthony is offline   Reply With Quote
Old 11-13-2007, 11:02 AM   #6 (permalink)
Zice
Status
Zice's Avatar
Casino Cash: $5117
Sportbike: 2006 GSXR 600
Zice is on a distinguished road
Just curious, do you know if this trick works for say a ZX6? My buddy has one and his FI light just came on...
Zice is offline   Reply With Quote
Old 02-06-2008, 03:43 PM   #7 (permalink)
synspeed
Casino Cash: $451
Sportbike: 2006 GSX-R1000
synspeed is on a distinguished road
Most bikes have a diagnostic plug, and often they are configured the same way. Don't go jumping wires until you know for sure, though.
synspeed is offline   Reply With Quote
Old 03-04-2008, 08:46 PM   #8 (permalink)
wowiamanewb
Casino Cash: $356
Sportbike: 2007 yamaha fz6
wowiamanewb is on a distinguished road
hello my buddy has got his 2000 gsxr 750 in my garage with a fi code but we can not find the plug u talk about is there one on this bike or is it in a different place
wowiamanewb is offline   Reply With Quote
Old 05-19-2008, 04:33 AM   #9 (permalink)
Hotboi
Hotboi's Avatar
Location: stationed in Germany but from Jonesboro,GA{What up 770,404?!
Casino Cash: $665
Sportbike: 04 Suzuki GSXR 600
Hotboi is on a distinguished road
Default The best post yet!
Brother! Thanks for this post, you just don't know how you've helped me out and I'm sure others.I've got the ol' FI and red light on on my 04 Gsxr 600 and been really wanting to take her to the shop but not if I good fix it myself.This sheds some light on dark areas.Thanks alot my hats off to you!
Hotboi is offline   Reply With Quote
Old 05-19-2008, 03:36 PM   #10 (permalink)
jk750
Moderator of Stuff
jk750's Avatar
Casino Cash: $9601
Glad I could help!
And welcome to SBN!
Old 09-01-2008, 12:35 AM   #11 (permalink)
orgAn.D0nor
orgAn.D0nor's Avatar
Casino Cash: $1301
Sportbike: 2007 Suzuki SV650S
orgAn.D0nor is on a distinguished road
Troubleshooting and the good 'ole tps mod or should I say 'adjustment'.
What what?
In the butt.
orgAn.D0nor is offline   Reply With Quote
LinkBack to this Thread: http://www.sportbikes.net/forums/suzuki-sportbikes/349798-fi-codes.html
Suzuki Sportbikes - Sportbikes.net This thread Refback 09-18-2007 05:09 PM
motor codes? twocannons Suzuki Sportbikes 2 04-03-2007 02:28 AM
Bulb codes in U.S.A.? koris66 FZ6 0 03-12-2007 07:11 PM
FI Codes jk750 SBN Suzuki Paddock 0 11-17-2006 08:22 PM
Color codes Karoshi FZ6 4 07-08-2004 10:40 AM
