Originally Posted by acalliste
Is there any benefit to getting a power commander if you only have a slip-on?
Yes, absolutely. A PC is a 'jet kit' for fuel injected bikes. Bikes run lean from the factory even with stock exhaust. Adding a slip-on will usually allow the engine to run more lean, to some extent. Adding a full exhuast usually requires tuning from a PC, or similar device.
All bikes can benefit from proper tuning with a PC. Is it worth the cost on a stock bike? Probably not. On a bike with a slip-on? Maybe, one of mine is. Full exhaust? Yes.
