R#108: GSX1300RX Fuel Hose Routing
MODEL: GSX1300R Hayabusa
SUBJECT: FUEL HOSE ROUTING
REFERENCE: GSX1300R SERVICE MANUAL - 99500-39180-03E
NOTICE:
When connecting the fuel feed hose or fuel return hose, or performing periodic maintenance
with the fuel tank lifted up, make sure the fuel hose routing is correct. Improperly routed fuel
hoses can restrict fuel flow. Restricted fuel flow can cause operational problems, such as hard
starting or uneven idle. Use the diagrams in this bulletin and the service manual to make sure
fuel hose routing is correct when you replace the fuel tank, any fuel hose or perform service
on a GSX1300R.
