Penn Foster
Go Back   Sportbikes.net > Topic Discussions > Help Me Fix It > Service Bulletins and Recalls > Suzuki Line
Suzuki Line Listed Recalls and Bulletins for the Suzuki Line Motorcycles.
Springfield ArmoryMotorcycle.com Classifieds!Nice CycleAdvanstarMotorcycleShowsSoloMotoPartsWilzGarageSportbikeTrackGearChainDrain.comSumOfAllParts.netKomodoGear.comRacerPartsWholesaleMotoGiya.comSee your ad here!
Old 12-13-2006, 02:08 PM   #1 (permalink)
Fred
Chief Booty Knocker
Fred's Avatar
Casino Cash: $15907
Sportbike: 2007 GSX-R600 Race / 2003 GSX-R750 Street
Fred will become famous soon enoughFred will become famous soon enough
Total Awards: 4
Default GS/GSX/GSX-R#097: GSX-R750W Fuel Pipe Set
MODEL: GSX-R750W
SUBJECT: FUEL HOSE DISCONNECTED FROM FUEL PUMP
NEW FUEL PIPE SET (PN 15310-33E50)
REFERENCE: SERVICE MANUAL (PN 99500-37080-03E)
& SERVICE MANUAL SUPPLEMENT (99501-37200-03E)
NOTICE:
In certain regions of the country, the hose connecting the fuel pump to the fuel filter may
come off causing a lack of fuel pressure to the fuel injection system. The fuel pump will
operate normally when the ignition is turned on, but the engine will not start because fuel
is not pumped into the fuel injection system.
If you encounter this symptom, inspect the fuel pump output. If faulty, remove the fuel pump
assembly from the fuel tank and see if the fuel hose has come off the fuel pump or fuel filter.
If so, replace the hose and original clamps with a Fuel Pipe Set (PN 15310-33E50). The fuel
pipe set has a pair of hoses, new hose clamps, and a pipe/ bracket combination which will
secure the fuel pipe and hoses to the fuel pump bracket with screws.
Use a new Fuel Pump Gasket (PN 44596-02F01) and new Fuel Pump Mounting Bolts (PN
15211-02F00, Qty. 8) when reinstalling a repaired fuel pump into the fuel tank. The new
fuel pump mounting bolts have a different torque specification than the original bolts (see
page 4 of this bulletin).
AFFECTED MODELS:
Some 1998 GSX-R750W models may be affected. No action is required unless the
motorcycle will not start due to a lack of fuel pump output.
Fred
SBN Administrator & Webmaster
Sportbike - 2007 Suzuki GSX-R 600 Race Bike / 2003 Suzuki GSX-R 750 Street | Cruiser - 2006 Harley Davidson Street Glide
Sportbikes.net Online Store - Videos, Undertails, T-SHIRTS, etc..
Fred is offline   Reply With Quote
Octane for Ducs jk750 Ducati 9 05-27-2006 11:04 PM
Interesting take on 9/11 events Chillerguy Politics & Religion 112 03-09-2006 08:42 AM
hydrogen fuel cell question Darkstar Open Forums 20 02-17-2005 01:14 PM
How-To's: When you first get your Pocket Bike Mr. Lesbian Pocketbikes 0 08-31-2004 04:21 PM
