Go Back   Sportbikes.net > Topic Discussions > Sport-Touring
Sport-Touring Information on Sport Touring throughout the world. Tank bags, Gear, saddle bags, Camp sites. Share your information here!
Motoworld Inc
Allstate
CycleGear.comMotorcycle.com Classifieds!BikeBanditSoupy's Performance SportbikeTrackGearJardineProducts.comSee your ad here!
Old 07-02-2008, 12:19 PM   #1 (permalink)
Xtremjeepn
Casino Cash: $6820
Sportbike: 07 R1,Speed Triple, FZ600
Xtremjeepn will become famous soon enough Xtremjeepn will become famous soon enough
Default Pelican case hard saddle bag pannier project for 07 R1.
Not sure the pictures will show up here so here is the original link in the R1-Forum.
Pelican case hard saddle bag pannier project for 07. : Yamaha R1 Forum
I know some of you track junkies won't approve but ....
I have been riding a long time and really enjoy a pure sports bike. I also love doing a little power commuting on it and some SPORT touring.
No one makes real hard luggage for pure sports bikes. The ones that do want a small fortune for it. So I decided I could have my cake and eat it too by making myself some commuting luggage.
I am only partially into this project so bare with me here.
-I started with two Pelican 1430 top load cases. These things are light and nearly indistructable. They are also totally water tight (untill I started drilling holes in them:dundun.
I wanted to take advantage of the bikes natural weight bearing points and try to avoid having huge racks hanging on the bike at all times.
So here is what I came up with so far.
The front edge of the case has a some metal square stock attached to the bottom of it. This just slips over the passenger foot peg. Not as secure of a point as I would like so I may change this around a bit so that it actually uses a quick release pin to take the peg off and pin in the bag where the peg goes. I figure if a 120 passenger can stand on this peg 10-15lbs max of pannier can ride on it.
Then I made a simple double "L" bracket that bolts to the exhaust hanger under the seat and sticks out between the exhuast and body work. (no trimming at all, forgive the loose bodywork it is just sitting on the bike for picture reference sake).
There is a hole in the side of the Pelican case that the bracket simply bolts to. The plan is to weld a bolt to the bracket, the case slides over the bolt and secures from inside the case with a wingnut. This keeps the case locked on as long as you have a padlock on the case. Simple one nut removal of the case so that you can ride it to work and carry the case inside just like a breifcase.
The only issue at this point is that the exhaust mounts are rubber mounted so it allows movement in the case. Tonight I will build a cross truss under the seat to tie the left and right side toghther so there is zero flex. The whole system will still only be held on with two bolts and no trimming. So in theory when I am done I could take this to a shop,jig it and make more if there was enough interest. This is all the same underseat structure designed to hold the weight of the passenger.
When the bags are off the bike all you will see is a small bracket sticking out above the exhaust. So for the most part you keep the sleek lines of the bike when you don't have luggage.
One case will hold my laptop and stuff for work. The other will have the foam removed to hold files, jacket, etc.
Xtremjeepn is offline   Reply With Quote
Old 07-02-2008, 12:29 PM   #2 (permalink)
SloppyJoseph
Swollen Member
SloppyJoseph's Avatar
Casino Cash: $17358
Sportbike: 2002 SV650S
SloppyJoseph is on a distinguished road
Pelican cases rock. I got one i keep my uhhhh..... stuff in.
****R.I.P. KH****
SloppyJoseph is offline   Reply With Quote
Old 07-05-2008, 01:40 AM   #3 (permalink)
clutchdemon
Casino Cash: $2369
Sportbike: 06 ninja 650, 01 yz426
clutchdemon is on a distinguished road
bravo!
I'm currently welding up a bracket for my ninja650, sort of like a luggage rack for the rear, and this gives me some new ideas! hats off to you partner!
Can i ask - how much are those pelican cases going for?
Awesome job!!
Clutch
clutchdemon is offline   Reply With Quote
Old 07-05-2008, 01:43 AM   #4 (permalink)
wired_af
Political threads FTL
wired_af's Avatar
Casino Cash: $18893
Sportbike: '06 Z1000 ♥
wired_af is on a distinguished road
Your porn stash?
Those Pelican cases could prob double as frame sliders if need be.
wired_af is offline   Reply With Quote
Old 07-05-2008, 09:27 AM   #5 (permalink)
Grusome
Grusome's Avatar
Casino Cash: $37995
Sportbike: '01 Suzuki GSX-R600
Grusome will become famous soon enough Grusome will become famous soon enough
Seems like a great idea to me. Pelican cases are very sturdy. I'd be interested in more detailed pictures of the parts you made to mount them.
Grusome is offline   Reply With Quote
Old 07-05-2008, 11:34 AM   #6 (permalink)
Xtremjeepn
Casino Cash: $6820
Well, I worked on them a bit yesterday. (pictures to follow).
The bracket had too much flex in it for me. So I welded an angle iron cross brace together. Links the left and right sides under the seat. Strudy as hell now!!!....and it remains a bolt on item so that if you wanted to remove it you can.
I thought the idea of just slipping a tube over the rear foot peg would be great but it just does not secure the bottom of the case enough.
I think I am going to order some Pannier loops and mounting kit and go all out on the Pannier mount. I wish I could keep the biker mostly bracket free but to really make them secure I don't think it is going to happen. I may try to make a single link bracket that doubles as the rear foot peg first to see how that goes.
The 1430 Pelican cases were $87 each locally here with the foam. I have found them several places on line for less, and less if you don't get the foam. But once you include shipping they are about the same. (plus I was in the guys shop 4 times taking measurements before I bought them so I figure I owed him the courtesy of purchasing through him)
Old 07-15-2008, 10:43 AM   #7 (permalink)
lharrellr6
Casino Cash: $14358
Sportbike: 2002 R6
lharrellr6 is on a distinguished road
Keep us updated on this project. I'm contemplating trying to outfit some GIVI hardbags on my 02 R6. I just don't know if it would be worth the hassle. I'd really like to see detailed pics of the brackets as well.
Lucas
lharrellr6 is offline   Reply With Quote
Old 07-15-2008, 11:07 AM   #8 (permalink)
SloppyJoseph
Swollen Member
Casino Cash: $17358
Originally Posted by wired_af View Post
Your porn stash?
Green stash.... almost smell proof.
****R.I.P. KH****
Old 07-16-2008, 12:44 PM   #9 (permalink)
Xtremjeepn
Casino Cash: $6820
Lucas
I will. I just took a break from it. Need to order some "hoops" and mounting pieces. Not the route I really wanted to go, but it must be done to make them right.
Old 07-17-2008, 10:56 AM   #10 (permalink)
lharrellr6
Casino Cash: $14358
Sportbike: 2002 R6
The plan I had in my mind was to by a used givi kit on ebay. Basically all I want is the hoops. I will grind off all the brackets, so I just have the bare hoops. Then I can bolt brackets to the bike, start shaping and grinding them until I get them the right size and length to mate up to the hoop. Then hold the hoops in place and tack weld everythink up. Next, remove everything, final weld, cleanup, and paint. Like I said before, just not sure if it will be worth all the hassle.
currently I have Nelson Rigg's soft pacs on the back, and they are great, but hard pacs would be the tit's.
Lucas
Old 07-17-2008, 03:51 PM   #11 (permalink)
Xtremjeepn
Casino Cash: $6820
I found pre-made hoops for $39 and bag mounting kits for $69. I will find the link when I get home and post it.
Old 07-17-2008, 06:09 PM   #12 (permalink)
Xtremjeepn
Casino Cash: $6820
Moto-Sport Panniers*** World Class Motorcycle Luggage
Old 07-30-2008, 01:49 PM   #13 (permalink)
stevo_x
stevo_x's Avatar
Casino Cash: $38555
Sportbike: 07 Kawi ZX6-R
stevo_x is on a distinguished road
I finally found this thread again! I want to do something like this. Good link for the mounting kit!
Get tha Nannys!
some people have feelings that get hurt easily. I simply say it may be a case of sandivaginitis.....go to the doctor. It sounds like sound paper when you walk.
stevo_x is offline   Reply With Quote
Old 07-30-2008, 03:17 PM   #14 (permalink)
Xtremjeepn
Casino Cash: $6820
Still a work in progress. Have been too busy to work on it.
Old 08-09-2008, 10:14 PM   #15 (permalink)
Xtremjeepn
Casino Cash: $6820
Okay! So here is a little update.
Got my "Motor-Sport Panniers" Universal mounting hoop kit.
I am not a big fan of their mount set up, but the hoop was a must need.
Hoops were $39 and the mount plates were $79. (buy the hoops, not the plates, you can make something cheaper)
These photos are not totally finished. Wanted to ride with them for a bit before having the mounts powder coated. So all the rack is still raw steal and needs cleaned up. (Forgive the dirty bike and garage)
These things are rock solid.
Saddle bags and tail bag f/s - SOLD! TRaGiK NC Local Classifieds 25 06-21-2007 10:09 PM
Nelson Riggs expandable tank bag review. Justin726 Performance and Customizing 2 01-10-2005 04:43 PM
Tail Bag, Rack, or Saddle Bags - How do they effect the ride? krbprogrammer Riders Gear 2 07-05-2004 08:50 AM
