Go Back   Sportbikes.net > Sportbikes > European Sportbikes > Triumph > Speed Triple
Speed Triple To become a true icon is no easy feat. But from its very first incarnation over a decade ago the Speed Triple assumed just that status, mixing a primal three-cylinder core with sporting ability and an aggressive, stripped-down stance.
Allstate
British Motorcycle GearTuck & Run Clothing CoMcCoyMotorsportsGravesMotorsportsJardineProducts.comBikeBanditBluTek HelmetsSee your ad here!
Old 05-19-2007, 02:07 PM   #1 (permalink)
PUDDLE PIRATE
PUDDLE PIRATE's Avatar
Casino Cash: $350
Sportbike: 2001 Triumph Speed Triple 955i
PUDDLE PIRATE is on a distinguished road
Thumbs up Idle too high?
This is my first post so Hello.
I recently sold my Buell firebolt and acquired a 2001 S3. It outperforms the Buell in every aspect so far. I think the idle may be too high though because the transmission feels a bit clunky when switching from neut to first. I looked everywhere is there an idle adjustment screw somewhere?
PUDDLE PIRATE is offline   Reply With Quote
Old 05-19-2007, 08:05 PM   #2 (permalink)
g®eg™
Moderator
g®eg™'s Avatar
Casino Cash: $12826
Sportbike: 08 Moto Guzzi Norge 96 Triumph Sprint, 04 Honda XR 650-L
g®eg™ is on a distinguished road
welcome!
no screw, it's controlled by the computer.
the transmissions on Triumphs are a bit clunky until they break in (10-15,000 miles). You might want to check that your clutch is disengaging / is properly adjusted.
08 Moto Guzzi Norge
04 Honda XR 650-L
96 Triumph T3 Sprint
SBN Euro Bikes Moderator
Greg's Web
MSF Rider Coach
g®eg™ is offline   Reply With Quote
Old 05-19-2007, 08:10 PM   #3 (permalink)
kevinwilly
former murder victim....
kevinwilly's Avatar
Casino Cash: $83676
Sportbike: None! Sold it!
kevinwilly will become famous soon enough kevinwilly will become famous soon enough
Total Awards: 4
what speed is it idling at?
All my bikes (same engine/tranny as you have) go into first without much of a clunk.
What kind of oil are you using? When was it last changed? Is your oil level correct with the bike upright? Is your clutch adjusted properly?
Old 05-20-2007, 10:13 AM   #4 (permalink)
User Name
Spiderman
User Name's Avatar
Casino Cash: $16473
Sportbike: 2003 Hayabusa 2006 Speed Triple
User Name will become famous soon enough User Name will become famous soon enough
Check the throttle cable, that could be too tight and causing the high idle. Mine idles at just over 1k RPM, which seems pretty normal.
Not all who wander are lost
User Name is offline   Reply With Quote
Old 05-20-2007, 01:31 PM   #5 (permalink)
PUDDLE PIRATE
Casino Cash: $350
Thumbs up
Hey thanks for the responses. Mine idles about 2k at cold start and drops to about 1500 after a couple minutes or so. Odd that I dont get much of a clunk when I shift into first from here. By the time I hit the first stop light, the idle is hanging around 11-12k. I need to change the oil because the previous owner did nothing with the bike. Who knows what he used?? I plan on purchasing a service manual at the dealership today (thank God I am done with HD dealerships!!!) Oh and tI have about 7,200 so far so thats a ways away from 15k. Other than this, this bike is awesome I am glad I found this before buying a monsterbike.
Oh, are there anyothr S3 forums you recommend?
Old 05-20-2007, 01:38 PM   #6 (permalink)
kevinwilly
kevinwilly's Avatar
Casino Cash: $83676
Total Awards: 4
triumphrat.net
When you start the bike, it should go up to 2k for a couple seconds and then return to about 1100 rpm.
check your throttle response... if you blip the throttle, does it go RIGHT back to idle, or does it slowly go back down?
Check the throttle adjustment. With the bike off, open the throttle ALL the way. You should hear the throttle bodies click against the stop. Then let go of the throttle, and they should click against the other stop. If there is no click, you need a little more slack in your throttle cable.
I had this problem with my bike last weekend. It was annoying, but does not take long to adjust.
Old 05-20-2007, 01:43 PM   #7 (permalink)
PUDDLE PIRATE
Casino Cash: $350
I see where you are gong with this, I think a good cable lube is on order today (clutch and throttle) aswell. Hopefully they have that manual.
Old 05-20-2007, 01:56 PM   #8 (permalink)
kevinwilly
kevinwilly's Avatar
Casino Cash: $83676
Total Awards: 4
they usually have the manual- but it's like 85 bucks.
The haynes manual is pretty darn good for these bikes, and is only 35
So how much electrical power do we have? fishchoke FZ6 Mods 17 10-24-2007 12:54 AM
'89 Suzuki Katana 600 High Idle Issue Genken Help Me Fix It 10 04-18-2007 10:54 PM
High Idle revs on my Bandit el_bandito Help Me Fix It 3 04-12-2007 04:32 PM
high idle issue jay1227 ZZR-600 22 03-12-2007 10:43 AM
1988 cbr 600 high idle codyisbad Help Me Fix It 1 03-06-2007 12:15 PM
