Idiotís Guide to Securing Your Motorcycle - Sportbikes.net
User Tag List
post #1 of 3 (permalink) Old 07-09-2006, 04:17 PM Thread Starter
You got that right.
mikem317's Avatar
Quoted: 0 Post(s)
Motorcycles are an attractive target for thieves. They are comparatively small compared to their four-wheeled counterparts and have a high value to weight ratio. A machine can often be disassembled to the frame by the experienced in a matter of hours. So how do you mitigate this risk of theft?
• There are several different types of locking mechanisms. Most are inexpensive and can be stored in the pillion compartment or tank bag. There are disk locks, wheel locks, and U-locks. Some riders implore the use of chains. Chains can vary in girth and resistance to chain cutters. There are motorcycle anti-theft specific chains that can be purchased and typically retail for over $100. If you are going to use a chain, the front or rear wheel should be wrapped around the frame and then attached to a fixed object like a lamp post or grounded anchor. This will prohibit a thief from moving the machine.
• Lock your forks. It’s free. Check your motorcycle owners’ manual for details on how to lock your forks. Flip your engine run switch from “run” to “stop” when parking your ride. If the front end can’t be turned, it will be a very difficult machine to steer.
• There are several manufacturers of motorcycle alarms. They can range in price from $50 to $400, varying in features. Most of these alarm systems can be installed in less than an hour and come with a remote to activate/deactivate the system. Some of these features include ignition kill switches, motion detectors, tilt sensors, and auxiliary batteries. If a thief tries to pound a screwdriver through the ignition, the alarm will sound. Thieves embrace conspicuity and do not want others to be alerted.
• Where do you store your machine? They can’t steal what they can’t see. Store your machine inside! If you don’t have the use of a garage, an outdoor shed will be acceptable. If that’s not a possibility, consider using a conventional motorcycle cover. Provided that it doesn’t violate any state or municipal fire safety codes, store your machine inside! Your GSX-R will complement your nightstand nicely.
• Install a vehicle recovery system (e.g. LoJack). You may qualify for a discount on your insurance policy if you have one installed on your ride. Although not really a “preventative” measure to reduce the likelihood of theft, a vehicle recovery system increases the odds that you will recover your machine and can expedite the vehicle recovery turnover process. These systems are more expensive than an alarm and chain/lock combination.
• Insure your motorcycle from theft! If you’re financing your machine, you probably already have full insurance (this should include a provision for theft of the machine). If you have the title to your machine, and depending on state law, you may have the option NOT to purchase an insurance policy. However, this is the ONLY sure way that you’ll recover the value (or a portion) of the machine in the instance that it is not recovered by the police.
• If a thief wants your machine, they’ll take it. If you have your machine chained, locked, alarmed, LoJack-ed and stored in your secured garage, chances are that the thief will look for an easier target. And if it’s insured against theft, you’ll recoup some or all of the value of the machine.
Remember, rubber side down, shiny side up!
Regards,
Mike
mikem317 is offline
post #2 of 3 (permalink) Old 04-09-2007, 10:07 AM
SBN Newb
Quoted: 0 Post(s)
Smile
Adding an alarm is a MUST. It also keeps away kids that will scratch your paint!
Bring a chain, esp. if you park your bike to the same place, leave the chain there, attached to some unmovable post. To protect against thieves cutting the chain, make sure the chain does NOT touch the ground when it's wrapped to your rim. (they cannot get leverage to use a chain-cutter).
This protects you against a truckload of people coming and lifting your bike to the truck (happens often!)
Park your bike where it will be visible (i.e. under a streetlamp). they will think twice before fiddling with a bike with a blaring alarm where there are others that can see it.
If you use a disc lock, attach a WIRE to it, and route the wire to your handlebars.. It's very easy to forget a disc lock and start the bike ("clunk!"). You'll see the wire and remember the lock. It also deters the thieves thinking it's a fancy alarm
Have fun,
-turgut
Izmir, Turkey
Hyosung GT250R
tkalfaoglu is offline
post #3 of 3 (permalink) Old 03-30-2009, 01:42 AM
Quoted: 0 Post(s)
As a personal note, I have a 2way Scorpio alarm and a Kryptonite Fahgettaboudit chain wrapped around the front tire tethered to a parking structure pole at my apartment complex.
For those that have a smaller budget, you can get a chain and an alarm and is relatively safe. You're covered against people getting close to it, starting it, or tilting it with the alarm... and if they get around that, then its still tethered to the parking structure.
But as you read above... if they want your bike bad enough, they'll get it. The key is to deter them enough to look for someone elses. Hope this helps from the perspective of an apartment dweller for those in similar situations!
jgruberman is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
GIs on Motorcycles SnapRolls Military Forum 58 09-14-2010 12:46 PM
Hurt Report Summary segue00 FZ6/FZ6R 21 07-05-2006 10:09 PM
Motorcycle Accident Cause Factors. Bomb300 General Sportbikes 9 04-29-2006 04:41 PM
wives/women VS. motorcycles fengler General Sportbikes 16 07-05-2005 10:34 PM
Oil KawZX7R ZX-7R 9 06-07-2005 01:14 AM
You may post new threads
You may post replies
Refbacks are Off
