Go Back   Sportbikes.net > Sportbike News > SBN Articles > SBN Gear Testing
Motorcycle.com Classifieds!McCoyMotorsportsBikeBanditSportbikeTrackGearJardineProducts.comCycleGear.comAnnitori DistributingSoupy's PerformanceBritish Motorcycle Gear
Allstate
See your ad here!
Old 05-22-2006, 01:35 PM   #1 (permalink)
Lewd Ferrigno
Casino Cash: $23176
Sportbike: 2008 KTM Super Duke
Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future Lewd Ferrigno has a brilliant future
Default Alpinestars Supertech boots race tested
Alpinestars was kind enough to provide me with a brand new pair of 2006 red and black Alpinestars Supertech boots to test while racing at Daytona and Blackhawk Farms. The boot has a separate inner “bootie” which has to be put on before stepping into the main outer protective boot. This inner liner is extremely comfortable and easy to put on thru a flap that opens at the back of the outer boot. After you put the liner on you simply pull the laces that criss-cross over the back flap tight by using a pull attached to the end of the laces. Once the laces are tight you slide a cinch lock (permanently mounted on the laces) up against the boot to keep the liner fitting snugly, then the pull at the end of the laces attaches to a Velcro patch at the top of the boot to stop it from falling into the main boot when you put it on. The bootie has a plastic structure which covers the entire bottom, sides, heel, and ankle area of the foot with a rubberized surface that stretches the entire length to stop the liner from sliding around inside of the outer boot.
The upper portion of the liner has a plastic support section that's about 1/8" x 1" x 4" that pivots to allow natural movement. This structure gives a real feeling of protection and doesn't prevent natural movement of your foot at all
The outer main boot is a collection of different materials with flexible plastic sections covering over 1/2 of the outside of the boot. Something I noticed immediately was how flexible the overall boot was, this was obviously because the protective structure was incorporated onto the inner liner. The upper portion has an air gap between it and the inner portion of the boot with a mesh material inside allowing air to flow out of the boot. The tongue on the front of the boot is made of a material which allows good air flow. The bottom of the boot is made of a tough rubber like material and has a good heel portion on it as well. The back of the heel has a replaceable slider attached by 2 Allen head screws, the outside toe portion has a toe slider that locks in at 2 points very firmly, but does not require any tools to replace it.
I found these boots to be very comfortable and actually fit me and held the fit, they were a Euro size 45 - USA size 10.5. I normally wear a 10 to 10.5 USA size shoe depending on manufacturer and have wide feet as well. My large, muscular calve muscles (Ladies?– Ed.) have always been a problem for me with boots, most of the time the boots will loosen up by the time a race is over due to the Velcro not having enough surface area to hold when opened up large enough for me. The strap across the back of this boot solves that issue for me, even though there still is not a lot of Velcro engaged over my large calve muscles in these boots as well. After the races I found that they were still fitting as well as when I 1st put them on, I was very impressed by this since it's been a problem for me for the entire time I have raced. I was also very impressed by the soles, they offered great grip and 'feel' and don't show any signs of wear at all (even though I have relatively new heavily knurled foot pegs on my bike). Another thing I noticed was the cooling capability of these boots, even though they are not the model with the perforations in the leather. I normally want to get out of my boots ASAP after a race because my feet will have formed small puddles of sweat, but in these, my feet were comfortable after all the races I ran. Once in these boots I felt protected, combining the inner liner and outer shell gave me a confident feeling yet still allowed easy range of motion.
A few observations about these boots, when sliding my liner covered foot into the outer shell I encounter some resistance before my heel 'pops' into position. This was bad enough the 1st time I put them on to think I had the wrong size boot, but once my foot was in the boot it was comfortable. Due to my large calves, I encountered some resistance when zipping up the boot, but again once zipped the boot was comfortable in that aspect. The 1st time I went out on the track wearing these I noticed that due to the ankle protection the boots are slightly wider than what I have used in the past, though not a problem at all I had to slightly change the positioning of my foot when I shift. The only real complaint I have with these boots is a slight tightness on the top of my feet due to my feet being wider than most, not that this was to the point of causing a problem, but noticeable none the less. I have noticed that each of the minor issues I had with fit are getting better as I wear the boots more, I would imagine after a few more races none of these things will even be an issue and the boots will be fitting great then.
Overall I would highly suggest these boots to anyone looking for comfortable protection while riding or racing!
For more info go to www.alpinestars.com
- GSXR Racer Mike
Lewd Ferrigno is offline   Reply With Quote
Old 05-23-2006, 07:02 PM   #2 (permalink)
Sibling
#1 Pedrosa Fan
Sibling's Avatar
Casino Cash: $0
Sportbike: 2004 SV650S Blue
Sibling will become famous soon enough
Hey.... your back... good stuff
Originally Posted by TheSollyLama
hoisting a gixxer 600 is about as impressive as killing a rabbit with a 155mm howitzer.
Sibling is offline   Reply With Quote
Old 06-05-2006, 11:31 PM   #3 (permalink)
mikem317
You got that right.
mikem317's Avatar
Casino Cash: $18219
Sportbike: Honda CBR600 F4i *sold*
mikem317 will become famous soon enough
Green Token: Green SBN Token - Issue reason:   Yellow Token: Yellow SBN Token - Issue reason:
Total Awards: 2
Who did the testing? Fargin or Mike?
Anyway, thanks for the input! I'm debating between a pair of those A* boots or some Sidi Vertigos.
Regards,
Mike
mikem317 is offline   Reply With Quote
Old 06-05-2006, 11:32 PM   #4 (permalink)
Lewd Ferrigno
Casino Cash: $23176
Mike did it. I did the Sidis.
Old 06-25-2006, 11:33 PM   #5 (permalink)
whitman
RACE FORUM MODERATOR
whitman's Avatar
Casino Cash: $1591
Sportbike: 95ZX6R track HO....
whitman is on a distinguished road
Default nice review .............................................
that boot looks cool, and welcome back fargin
RACE MOD.........ANY QUESTIONS JUST PM ME.....
On the GAS past GOD, Brake when you see the DEVIL
BUWAHAHAAAAAAAAAAAAAAAAAAAAAAAAAA devil
LIVING LIFE ONE APEX AT A TIME..........
whitman is online now   Reply With Quote
Old 07-23-2006, 11:30 PM   #6 (permalink)
GSXR RACER MIKE
Roadracer since '96
GSXR RACER MIKE's Avatar
Casino Cash: $30311
Sportbike: 2002GSXR750 1999GSXR600 1996GSXR750
GSXR RACER MIKE is on a distinguished road
Here I am at Heartland Park putting these boots thru the paces (CCS - June 2006). I have found that even on the hottest humid days these boots allow my feet to breathe and I no longer have socks that are absolutely soaked after a hot race. The fit is excellent now, I still notice they can be a little firm when inserting your foot into the boot, but once on they are very comfortable.
"ON THE TRACK" forum MODERATOR
GSXR RACER MIKE is online now   Reply With Quote
Old 09-05-2006, 12:00 AM   #7 (permalink)
kl3640
Sportbike: 2006 GSX-R750, 2005 K1200S...and lots of non-sportbikes :)
kl3640 is on a distinguished road
I purchased these about a month ago and have used them at the track a couple of times. Not at all to my surprise, they are extremely comfortable. Getting the EXACT right size helped (since they sell in Euro sizes, I can actually get a 12.5, which you typically don't find 1/2 sizes over 12 in the States). I knew that the inner boot concept would work because I have their Tech 10 boots, which I use for off-road racing, and they work great.
People often think that they will be uncomfortable because when you put them on, you don the little inner boots first, and then getting your foot in to the main outer boot can be a bit of a challenge. But once you've figured out the trick of how to push down at just the right time and in the right way, you can get your foot in, no problem.
After that, they are so comfortable that I actually stopped wearing my AlpineStars Roam street boots and just wear these now for serious street rides. They also breathe really well. You're feet will still sweat in them, but they won't be soaked at the end of a long, hot track day or race.
I do admit though that I got the boring all black version
kl3640 is offline   Reply With Quote
Old 10-29-2006, 05:20 PM   #8 (permalink)
Lewd Ferrigno
Casino Cash: $23176
Thanks for the contribution.
Old 10-05-2007, 04:04 AM   #9 (permalink)
volki
volki's Avatar
Casino Cash: $6716
Sportbike: yamaha 2006 fz6n
volki is on a distinguished road
I wear Alpinestars smx-3 for more than a year.My size is euro 49 usa 14.And i am very happy with them.
volki is offline   Reply With Quote
