SportbikeTrackGear
Sponsored by Arnott Air Ride
SportbikeTrackGearJazzMotorsports.comSportbikeTrackGearKomodoGear.comBikeBanditCycleGear.comGravesMotorsportsOPP RacingAdvanstarMotorcycleShowsArnottAirRideNice CycleAmericanMotorcyclistAssociationSee your ad here!
Old 07-28-2004, 02:41 AM   #1 (permalink)
King Cobra
King Cobra's Avatar
Casino Cash: $20449
Sportbike: 1997 Honda CBR F3
King Cobra is on a distinguished road
Default What is an ignition advancer?
I keep reading about these but I have no idea.
What you see, pleases.
Everyone deserves a ten.
But a more mundane bike may get ridden more. Or not.
King Cobra is online now   Reply With Quote
Old 07-28-2004, 02:55 AM   #2 (permalink)
ZXLNT
Kawpuke Extraordinare!
ZXLNT's Avatar
Casino Cash: $3908
Sportbike: ZX12.7R/ZX-14
ZXLNT is on a distinguished road
Its the timing rotor thats on the end of the crankshaft. As it spins makes the pickup coils send a signal to ignition box firing the spark plugs. With an aftermarket rotor some of them have the keyway offset by like 5 degrees or so to advance the ignition timing. Others are adjustable with an inner and outer piece that move independently to allow for precise adjustment instead of just fixed adjustment..
ZXLNT is offline   Reply With Quote
Old 07-28-2004, 12:09 PM   #3 (permalink)
jim schmidt
Casino Cash: $35859
jim schmidt has disabled reputation
Actually, an ignition advancer is a device, either mechanical (using centrifugal weights) or electronic (using an rpm pickup) that changes the ignition timing (to be more advanced) as rpm's increase. All bikes have them.
The things that are sold as ignition advancers are timing plates that change the range of advance by a fixed amount so the timing is always, say 4 degrees, more advanced.
jim schmidt is offline   Reply With Quote
Old 07-28-2004, 03:55 PM   #4 (permalink)
ZXLNT
ZXLNT's Avatar
Casino Cash: $3908
Semantics. Both you and I know what he is talking about.. My description is accurate enough for what he needed to know. When is the last time you saw a centrifugal advancer on a motorcycle??? As far as an electronic ignition advancer I dont belive thats really true either. Most ignition timing curves are fixed into either the ingitor box or a true ECU on a fuel injection bike. Never seen a stand alone electronic "ignition advancer"...
Old 07-28-2004, 04:01 PM   #5 (permalink)
2002 Busa SE
World Superbike Champion
2002 Busa SE's Avatar
Casino Cash: $755
Sportbike: busa
2002 Busa SE is on a distinguished road
what you forgot to add is for most bikes they are a waste of money. youll loose low end just for mabye 1 HP way up top.
2002 Busa SE is offline   Reply With Quote
Old 07-28-2004, 05:48 PM   #6 (permalink)
Bob H.
Void where prohibited
Bob H.'s Avatar
Casino Cash: $469
Sportbike: '02 CBR 954RR
Bob H. is on a distinguished road
Well for F3's they basically increase mid range/ throttle response, not necessarily total HP.
Bob H.
'02 954RR- stock(ish)
'98 Neon R/T- not stock
'07 Cannondale Rush Carbon - new baby
Bob H. is offline   Reply With Quote
Old 07-28-2004, 10:56 PM   #7 (permalink)
jim schmidt
Casino Cash: $35859
1. Didn't mean to get under your skin. 2. The late 80s although I'm sure there were some engines that had them well into the 90s. 3. My point was that it was based on rpm, not whether it was integrated into the ECU or not. But on carb'd bikes, you won't find an ECU, just an ignition control box.
Old 07-28-2004, 11:00 PM   #8 (permalink)
jim schmidt
Casino Cash: $35859
Right. At best, huh? Just as likely to cause an across the board loss.
Old 07-29-2004, 08:16 AM   #9 (permalink)
ZXLNT
ZXLNT's Avatar
Casino Cash: $3908
Oh you didn't But knowing there are very very few 80's sportbikes around anymore I figured he was talking about something more late model. In that context his use of the word "ignition advancer" was going to be the timing rotor was my point. And yes I know carb'd bikes don't have a an ECU.
