Motorcycle.com Classifieds!
Sponsored by Arnott Air Ride
SportbikeTrackGearCheapCycleParts.comGravesMotorsportsKomodoGear.comCycleGear.comBikeBanditWilzGarageChainDrain.comOPP RacingSoloMotoPartsNice CycleAnnitori DistributingAdvanstarMotorcycleShowsSuperbikeToyStore.comSee your ad here!
Old 06-13-2008, 08:04 PM   #1 (permalink)
haknslash
haknslash's Avatar
Casino Cash: $4733
Sportbike: VTR1000 SuperHawk
haknslash is on a distinguished road
Default Motrax LED "Arrow" signal install *pics*
Stopped by Cycle Gear on my lunch break today looking for some parts. I currently have the "frisbee" flushmounts with a incadesent bulb. I've felt that cars might not be able to see these as well from the front since they sit flush. You can see them, but not nearly as much as you can from the side. So I have been wanting to switch that out for a stalk style LED to seperate the turn signal a little form the bike. Opposite of what most people do as they generally want flushmounts and discard their stalk stockers LOL.
While in CG I saw a few LED front designs I liked from both Lockhart Philips and Motrax. The Motrax are all E-code which is a higher lighting standard than here in the states. I decided to go with the Motrax "LED Arrow" lights with the short stalk.
Like most bikes, there is a big ass hole left in the stock fairing when you remove the turn signals. I didn't see any adapter plates while at CG so I shrugged it off and decided I'd make my own from some ABS sheets I have lying around in the garage. I had to make a front plate and a rear backplate.
For the front, all I did was trace the outline of my old frisbee turnsignal as that resembles the stock Honda hole fairly close. I trimmed up a piece of ABS roughly to the shape desired. I'll go back and smooth the edges with sand paper using multiple grit until I get a nice clean edge. For now, it's fairly rough as I'm still test fitting everything.
For the rear I did a similar method, only I had nothing to use as a pattern to trace out for my shape. I started with a rectangular shape of ABS I cut up. After test fitting the general shape and trimming a few times, I finally got it to a shape I wanted. The first problem I encountered was the SH has a very contoured surface both on the outside and inside of the fairing side. Thise poses an issue for bolt clearance of the turn signal as it wouldn't allow me enough space to get the retaining nut started on the threads of the turn signal. So....I then grabbed my trusty old heat gun and took the backplate I trimmed up and placed it on the garage floor to heat it thoroughly. Once hot as hell, I grabbed it with some oven mitts and then took it over to the bike where I then placed it how I wanted on the inside of the fairing and then press formed it to mold it to the contours of the fairing. This free'd up a good bit of space but I still wanted some more just for a good initial bite on the threads. So I then took a dremel sandstone grinding bit and made a countersunk area since the ABS is 1/8" thick. I removed maybe a 1/32" of material and this allowed the nut to get a good initial bite.
Now all that is left is to finish the edges of the front plate to give it a finished look. I might even go by some rattle can in red to blend the plate in a little bit better. Although the contrast of black on red works for my bike, so I may leave it black. I'm undecided at this point.
Enough rambling, here are some pics of the turn signal mod....
Old frisbee flushmounts (OFF)
Old frisbee's (ON)
Here is one Motrax LED Arrow installed with the custom plates....
A few close-ups opf them both off and on....
haknslash is offline   Reply With Quote
Old 06-13-2008, 08:05 PM   #2 (permalink)
haknslash
haknslash's Avatar
Casino Cash: $4733
Comparison of the frisbee and the LED Arrow....
Old 06-13-2008, 08:16 PM   #3 (permalink)
haknslash
haknslash's Avatar
Casino Cash: $4733
Here is the molded rear backplate...
Old 06-14-2008, 10:35 AM   #4 (permalink)
Fast Glass
Fast Glass's Avatar
Casino Cash: $3551
Sportbike: 2005 GSX-R 750
Fast Glass is on a distinguished road
Nice bike and nice signals.
Good job.
Eric
"A bad day racing is better than a good day working."
Fast Glass is offline   Reply With Quote
Old 06-16-2008, 10:15 AM   #5 (permalink)
kcallahan
Casino Cash: $6830
Sportbike: 2006 600rr
kcallahan is on a distinguished road
Cool. There has got to be a product out there that would be semi-flush, seen from the front and side, and also be bright. (have found nothing as yet)
Are you sure it's legal?
I don't know. It sure is fun though!
I should be locked up.
kcallahan is offline   Reply With Quote
Old 06-16-2008, 05:09 PM   #6 (permalink)
Tuffguy #2
Speed Racer
Tuffguy #2's Avatar
Casino Cash: $7261
Sportbike: '02 F4i, '99 VFR, '99 1100xx
Tuffguy #2 is an unknown quantity at this point
So are they bright enough to be seen well during the day?
Ron Paul supports the John Birch Society
Video of RP talking at the JBS 50th anniversary. http://www.jbs.org/index.php/about/jbs-50th-anniversary
Advocating personal responsibility and less government for decades, with no political affiliation.
www.jbs.org
http://www.takeyourmoneyback.com/
Tuffguy #2 is offline   Reply With Quote
Old 06-16-2008, 05:24 PM   #7 (permalink)
Delrone
Delrone's Avatar
Casino Cash: $11157
Sportbike: 2007 Honda CBR 600
Delrone is on a distinguished road
I agree i would like to see that also. THat's the particular thing that attrach's me to flush mount so i can be seen from all sides. yeah ok if you can't see my head light a signal isn't going to do much for me. I am going with the smal stalks on the back though when i get my fender eliminator.
Delrone is offline   Reply With Quote
Old 06-16-2008, 05:50 PM   #8 (permalink)
aaron6301
Superbike Champion
aaron6301's Avatar
Casino Cash: $9302
Sportbike: vroom
aaron6301 is on a distinguished road
Protons or Watsen Design. They aren't exactly flush but they are they aren't stalks either. A lot of people swear by them. Although, they are a bit on the pricey side.
aaron6301 is offline   Reply With Quote
Old 06-16-2008, 09:00 PM   #9 (permalink)
Gimpdiggity
Valiant Poultry
Gimpdiggity's Avatar
Casino Cash: $60358
Sportbike: '02 Ninja 250 with More $ in Mods Than I Care to Admit
Gimpdiggity has a spectacular aura aboutGimpdiggity has a spectacular aura aboutGimpdiggity has a spectacular aura about
I like them, but I think the old ones actually looked a little bit cleaner.
Too bad there's nothing that is "best of both worlds."
In Life, Try To Be The Kind Of Person Your Dog Thinks You Are...
Colts, 49ers, Lions, 2008 Stanley Cup Champion Red Wings, Tigers, Pistons, MSU Spartans, USC Trojans, LSU Tigers
2008 SBN CBS Sportsline Fantasy Football League Champion
2002 Kawasaki Ninja 250--SV-650 rear shock, Sonic Springs .80kg/mm front springs, ZX-2R graphics, flush mount front signals, tail pod rear signals, Kerker 2-1 race pipe, Factory Pro Stage 3 jet kit, UNI pod filters, ZG Double Bubble, Custom Creations soft vinyl seat cover, Kawi Green rim stripes, carbon brake fluid cap, carbon control levers, No Rear Fender, Yamaha R1 Style Mirrors, V-LEDs.com H4 HID Kit, Nelson Rigg Silver Streak Mini Saddle Bags, Rapid Transit Recon Tank Bag, Various Manufacturers Decals
Gimpdiggity is offline   Reply With Quote
Old 06-17-2008, 04:02 PM   #10 (permalink)
haknslash
haknslash's Avatar
Casino Cash: $4733
Yeah Protons and Watsens are some of the pricier ones that give great brightness with great visibility. The Protons can be seen from any angle I believe and they have a nice 3-mode option where they can strobe, flash, or steady. I agree the old ones looked cleaner because they sat flush but they have that dated frisbee style that I'm not a fan of. Just wanted to change it up a bit and get something a little newer on there while still being bright. I'll probably go with the flush Protons and sell these later on.
Tuffguy #2, they are bright but the LEDs deliver a direct beam rather than the regular bulb that directs light everywhere. They can be seen pretty well in the daytime from the front and a little bit of an angle. After that they are still bright but not as intense as from looking head-on.
Old 06-17-2008, 04:29 PM   #11 (permalink)
Royal Tiger
Love My Italian Mistress
Royal Tiger's Avatar
Casino Cash: $29877
Sportbike: 2003 Aprilia RSV 1000 Mille R
Royal Tiger is on a distinguished road
I like the "arrows" better. Visability is the main goal of signals.
Panzerkampfwagen VI Ausf. B Konigstiger {King Tiger}. Known as the "Royal Tiger" to the Americans.
If I was in Top Gun: "I feel the need; the need for Justice!"
SBN "Leesta" Name: Tigger!
Royal Tiger is offline   Reply With Quote
Old 06-17-2008, 04:59 PM   #12 (permalink)
CrazyBiker
Helpful Indian
CrazyBiker's Avatar
Casino Cash: $38844
Sportbike: Converted to 2007 FZ6 (Black/lue)
CrazyBiker is on a distinguished road
What a clean bike? How do you keep it so spanking new??
MODS 07 R6S Forks, Speedbleeders, F/R Galfer SS Lines, EBC HH Sintered Brake Pads | 15T Front, Speedohealer v3 | Laser Extreme Quad, CAT Elim, K&N, PCIII | Puig Light Smoke Racing Screen | TCP Seat Cowl | 06 FZ1 Bar | 07 Swingarm | 07 Speedo | 08 Bar Clamp | 08 Fairing | Pazzo Gold Shorty Levers | Top Saddlery Seat | Extended Frame & Motovation Swingarm Sliders | FAZR6 FE | Voltmeter, 12v Powerlet | Dual Headlight Mod (Xenon Super White HID) | F/R Flushmounts | Amber LED Pod Running/Signal Mod | Fiamm HB Lo Tone | Custom Yamaha FZ6 Reflective Wheel Stripes | Reflective Decals on Frame | Tankslapper 3M Protection Kit | Universal RAM Mount
ACCESSORIES Cortech Super Mini Tank Bag | Axio Carbon Fiber Tail Bag | Shad 50 Top Case
CrazyBiker is offline   Reply With Quote
Old 06-17-2008, 07:46 PM   #13 (permalink)
yzfkid
yzfkid's Avatar
Casino Cash: $2389
Sportbike:
yzfkid is on a distinguished road
Need to take those plates and sand it down so you cant see the cut marks and jagged edges...
Also when your done sanding paint it red or black so the sides where it was cut matches the top of the plates...the sides look gray now and the top black..just helping out bro...I used to be a custom audio and after market parts installer for dealerships .That wouldnt fly in our shop...Good your doing it yourself though..
Cage fighter extroirdinaire 4-1 MMA
myspace.com/yellowyzf
yzfkid is offline   Reply With Quote
Old 06-18-2008, 12:26 PM   #14 (permalink)
haknslash
haknslash's Avatar
Casino Cash: $4733
Thanks for your thoughts but please read over my post ;)
I mentioned these were not done and I was going to sand them and possibly paint them. I also used to do car audio installation when I was younger. And yeah this wouldn't of left any "shop" leaving like that. I'm still not done with the plates as all I have done is what you see (in progress). Haven't had time to finish them.
Thanks. She gets wiped down about every other day I ride. also helps that it's been well cared for by the P.O. and was garaged
Old 06-18-2008, 03:34 PM   #15 (permalink)
Black Snowman
Black Snowman's Avatar
Casino Cash: $9325
Sportbike: 2008 Buell 1125R, 2001 Suzuki SV650S
Black Snowman is on a distinguished road
Anyone looking to do something similar try pricing the LED rear turn signals from a 2008 Buell 1125R. They have three 3 watt leds and DOT legal difusers. They're bright as hell from 170* and don't look half bad. Noticably bigger than those however and longer stalks.
Here's a pic that shows them pretty well. Feel free to make fun of the trunk, but it's nice to not have to drive the F150 just to pick up a couple small things from the store.
Rear 3/4 shot of an 1125R
Black Snowman is offline   Reply With Quote
