questions about how to remove gas warning label to put on tank protector
Just bought a tank protector, and theres a bloody warning label encroaching on the area where I planned to stick the thing. with my experience of warning labels, they're usually sticky as hell and are atom bomb proof. any tricks to gettin it off without damaging the clear coat or leaving residue?
I used a few things in the following order and it did not leave a scratch... A hairdryer, credit card, Goo Gone, Microfiber cloth, and then some Plexus. It was still a pain
Casino Cash: $823
Sportbike: two: one green, the other blue
^ i used the same but didn't have any problem.
but making sure all the goo gone residue is wiped off and completely off can be a pain.
"Our Country! In her intercourse with foreign nations may she always be in the right; but right or wrong, our country!" - Stephen Decatur (1779-1820)
Goo Gone gel spray is the worst. That stuff leaves a terrible residue that takes forever to remove, it's almost as much of a chore as removing whatever you were in the first place.
The problem was, when I started to peel off the sticker only the clear top layer came off. The sticker itself was still on the tank. Since the top layer of the sticker was off, the bottom layer started to rip into a million little pieces everytime I'd grab a corner or portion. The process probably took me 30 minutes... Just for a damn sticker
I wished I would have read this sooner. The hairdryer and credit card would've been handy. I used simple green and peeled the sticker with my thumbnail. It took 15 minutes for both. Then I rubbed the hell out of it with a cloth and simple green. There was still a slight amount of sun baked residue stuck on there, and I used a clay bar with spray and shine instant detailer. The clay bar works!!!!!! Don't ask me how it works, but it did. I was just shooting in the dark on that one.
I consider myself lucky to have read this first before I tried to remove that damn sticker.
Here's what I did/used:
Hairdryer, credit card, simple green and microfiber cloth.
started with the hairdryer and warmed the sticker up then started at the edge with the credit card while continuing with the heat. After I got about halfway I was able to pull the sticker the off the rest of the way. Then I hit it with simple green and the microfiber cloth and with about 5min of elbow grease all traces of that sticker were gone and I was able to apply my tank pad where I saw fit.
thanks to all who posted before me made a world of difference.
