Power commander faceplate buttons
After getting my power commander installed, I was trying out the faceplate buttons.
I depressed the three faceplate buttons to enter button mode (per the instructions) and nothing happened. The first time I tried this, the bike was turned off and the 9 volt battery was hooked up. The power commander came to life but the LED stayed at the bottom.
So I fired up the bike and same thing.
Both times I held the buttons down for different lengths of time (5 seconds then 10) and then attempted to click each of them a few times, but the LED stays on the bottom.
I thought you could adjust the PC without a computer?
Or else I permanently locked in super lean?
The PC did fluctuate when the bike was fired up when I touched the throttle but other than that it stayed put.
And yes I did make sure all three buttons were held down simultaneously when attempting to enter button mode. If it is a safety feature to make sure the buttons don't accidentally get bumped when you are just riding around that is fine. Just want to know.
