ArnottAirRide
Sponsored by Arnott Air Ride
WilzGarageSpringfield ArmoryAdvanstarMotorcycleShowsChainDrain.comAnnitori DistributingKomodoGear.comSportbikeTrackGearSportbikeTrackGearNice CycleSoloMotoPartsJazzMotorsports.comAmericanMotorcyclistAssociationSee your ad here!
Old 06-16-2007, 06:54 PM   #1 (permalink)
olds_cool
Hard rockin' all the way!
olds_cool's Avatar
Casino Cash: $14648
Sportbike: 2008 Hyosung GT250C
olds_cool is an unknown quantity at this point
Default Cutting plastic/fiber glass fairings
Hey, all:
I'm going for the cafe racer look on my 250cc commuter. I want to cut down the fairings so the they do not go below the bottom of the gas tank. My question is, what's the best way to cut them without ruining them? Has anyone out there done this before? I just wanna cut and run (hahahhah)!
Nuff said.
olds_cool
DON'T be a SQUIDIOT!
olds_cool is offline   Reply With Quote
Old 06-17-2007, 11:33 AM   #2 (permalink)
94rf900r
Your mom goes to college
94rf900r's Avatar
Casino Cash: $24408
Sportbike: 94 suzuki rf900r
angle grinder with a cutting wheel works or a dremel something like that good just be careful you dont start melting it cut a little and then let it cool for a sec then cut more
Old 06-19-2007, 07:28 PM   #3 (permalink)
olds_cool
olds_cool's Avatar
Casino Cash: $14648
Cool! I should be getting started tomorrow before work. We'll see how it goes....
Nuff said.
olds_cool
Old 06-23-2007, 12:06 AM   #4 (permalink)
rugger19
rugger19's Avatar
Casino Cash: $6177
Sportbike: 07 Yamaha R6S
rugger19 is on a distinguished road
Not sure if I would use an angle grinder. Those things are made to cut steel, not plastic. They spin at very high RPMs. Use a very fine tooth hacksaw blade or sawzall and cut just below the desired line. I know they make blades that are meant for plastic. They are 36 or 48 teeth. Then clean it up with a dremel.
You might want to do a test cut on part of the fairing that you want to get rid of just to be sure.
Post up some pics when you get it done!
rugger19 is offline   Reply With Quote
Old 06-23-2007, 05:48 PM   #5 (permalink)
94rf900r
94rf900r's Avatar
Casino Cash: $24408
i dont like using hack saws cause they always seem to cut sideways or something the grinder worked good for me because its so easy to control and cut fast. i use metal cutting blades because they are pretty skinny and can make a precision cut, use just the very tip of the wheel and you can go around curves easy. but like i said just be careful you dont start melting it cuase they do spin really fast just be careful.
Old 06-23-2007, 10:37 PM   #6 (permalink)
CBRAWR
CBRAWR's Avatar
Casino Cash: $2524
Sportbike: '96 CBR 600 F3
CBRAWR is on a distinguished road
use a dremel with reinforced cut off wheels, and you should also use painters tape or similar to mark out where you want to cut at, and this will also prevent the paint from peeling up while cutting
R.I.P Shawn "Krazy Hawaiian" McCallister
July 11, 1956 - July 23, 2007
We will miss you.
CBRAWR is offline   Reply With Quote
Old 06-24-2007, 11:51 AM   #7 (permalink)
94rf900r
94rf900r's Avatar
Casino Cash: $24408
+1 on the tape
Old 06-25-2007, 11:09 AM   #8 (permalink)
kjf45
Casino Cash: $12854
Sportbike: 94 kaw ninja
kjf45 is on a distinguished road
i just finished cutting my plastics up. i used a dremel with a cut off wheel and taped off where i wanted to cut. definitly take your time and make a couple passes so you dont melt anything. other than that it was pretty easy
kjf45 is offline   Reply With Quote
After market street fairings TennBoy ZX-6R 3 03-12-2007 08:18 AM
aftermarket fairings. derK General Sportbikes 10 10-12-2004 05:35 AM
The Cutting Edge koda General Sportbikes 15 10-09-2004 11:21 PM
Fairings Ghost GTO CBR600F Series 10 09-18-2004 11:23 PM
Cut those fairings Ceh!! freakinhungover RC51 13 08-13-2004 02:33 AM
