Having worked in an aluminum foundry once upon a time as a quality assurance inspector, you'd DEFINITELY reduce the structural integrity of the swing arm by drilling a hole in it. These days they are vacuum drawn & lost foam mold cast to rather tight tolerances allowing for minimal material yet good structural rigidity. A hole will deform that very quickly and develop cracks as stresses attempt to go around the new hole and welding does require some specialized equipment to do properly, as well as some skill. Welding the cracks isn't very doable as the heat from the weld only weakens the surrounding area even more, with more cracks showing up later. The powered aluminum alloy once cast is heat treated to give it certain strength characteristics that the welding undoes.
Stay away from the drilling and welding, the danger isn't worth it.. You could go with some stainless steel Galfer lines and dress it up nice. They even have some colored ones.
Patrick (Janir) Waldoch - Local BOfH
I hate computers.... (sigh)
