Daytona 900 running problems
Hi!
Newbie here with a 1994 Daytona 900. Great bike apart from a small running problem which has me baffled. It runs absolutely fine apart from when the throttle is held open at around 7000 revs at which point the bike seems to lose fuel and slowly cuts down to either run on one if I'm lucky or to completely cut out. When working it up and down the box, there are no problems whatsoever - literally just when sitting at higher speeds on motorways etc.
So far, I've checked all the pipes from the tank and the tap. I've also replaced the vacuum pipe as the old one seemed to tend to go soft but nothing has done any good so far.
Has anyone experienced similar problems or can advise as to the next steps to fault finding? I've tried to book in for a dyno diagnostic but cant get it until the end of May!
Many thanks in advance.
