take your final drive gear ratio (probably 16/45 or something similar). divide the # of teeth on the front sprocket by # of teeth on the rear sprocket. this will give you a small number (0.3556 if you use my example). now do the same thing for your new gearing (15/45). divide again and you get 0.3333. now divide the new number by the old number.... you get 0.937, or 93.7%. so that means your top speed will be 93.7% lower. multiply this by your current top speed... probably around 180 (it will indicate higher than what it actually is). so you get 168.66 for your new top speed. make sense?
ASMA amateur #121
GF&T wrecking ball
If you don't eat your meat, you can't have any pudding.
