Sponsored by Arnott Air Ride
Bazzaz PerformanceMcCoyMotorsportsLevel One RacingBritish Motorcycle GearSportbikeTrackGearSoupy's PerformanceMotorcycle.com Classifieds!CycleGear.comSee your ad here!
Old 07-21-2006, 01:02 PM   #1 (permalink)
BadBoyBilly
BadBoyBilly's Avatar
Casino Cash: $461
Sportbike: 2006 GSXR 750 Blue/White
BadBoyBilly is on a distinguished road
Default Instructions on using seafoam.
It's getting close to changing the oil in my bike and I've heard about seafoam a bunch of times and I've seen clips on the net about how it makes a smoke show, lol.
Well I was on seafoams website reading over the instuctions on how to use it. Now I know my basics of a bike engine but the things they described I'm not too sure on.
Here's seafoams instructions:
With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
Now here are my questions:
1) It says to pour through carb or throttle body throat. Where exactily do I pour it into the carb??? The only thing that is open that you can pour it into is the velocity stack on top of the carb (with tank off). Is that where they want me to pour it into?
2) Where is the throttle body throat located?
3) What do they mean by port injected? Fuel injected?
BadBoyBilly is offline   Reply With Quote
Old 07-23-2006, 03:52 PM   #2 (permalink)
C_J_GO
C_J_GO's Avatar
Casino Cash: $100
Sportbike: 2001 Honda CBR F4i
C_J_GO is on a distinguished road
I have never used it on my bike as I have heard that running it may foul your plugs. The stuff works great on my car, but I juat had to change the plugs. I have always just added it to my gas tank when close to emty. I figure it will suck it up no matter what. I have also ran it in my oil within a few miles of changing the oil. The easiest way to find your throttle body is to take the tank and airbox off and twist your throttle. You will see the four doors (butterflies) open and close on your carbs..
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- "WOW--what a Ride!"
C_J_GO is offline   Reply With Quote
Old 07-24-2006, 10:16 PM   #3 (permalink)
Notalent
Notalent's Avatar
Sportbike: 2006 Yamaha R6
Notalent is on a distinguished road
I would scratch pouring it through your carb/tbt and actually put it in your gas tank. It will have the same effect. I use it in my boat, car and truck. I have also used it in my Dirtbikes. It works great. Dont waste your money on the other junk like Zmax whom is getting sued for alot of money for there false claims.
Notalent is offline   Reply With Quote
Old 07-24-2006, 10:16 PM   #4 (permalink)
Notalent
Notalent's Avatar
R6 Fork Mod Instructions Revived FAZR6 FZ6 Mods 449 03-15-2010 04:59 PM
I seem to remember step by step instructions for Laser Quad install... qualdoth FZ6 6 09-17-2005 01:00 PM
Any interest in detailed instructions for pod running light mod? qualdoth FZ6 10 09-07-2005 01:14 PM
Laser Xtreme Owners: Instructions? IronChefCJP FZ6 9 04-28-2005 06:19 AM
Need instructions to do a valve adjustment on a 1988 Ninja 750 njdjh2o General Sportbikes 8 02-25-2005 08:45 AM
