OPP Racing
Sponsored by Arnott Air Ride
OPP RacingNice CycleJazzMotorsports.comCheapCycleParts.comBikeBanditSuperbikeToyStore.comAnnitori DistributingSportbikeTrackGearWilzGarageGravesMotorsportsSportbikeTrackGearAmericanMotorcyclistAssociationArnottAirRideSoloMotoPartsSee your ad here!
Old 11-01-2004, 12:07 PM   #1 (permalink)
jluu6r
SBN's Slowest Member
jluu6r's Avatar
Casino Cash: $8735
Sportbike: 2000 CBR 929RR
jluu6r is on a distinguished road
Default paint in my gas tank
i just noticed my painter got some paint inside my gas tank. this cant be good for my bike. im gonna try to put some gas in it and swoosh it around. then dump out the gas.
anyone have a better idea?????
/////////////Believe nothing you hear and half of what you see///////
jluu6r is offline   Reply With Quote
Old 11-01-2004, 12:09 PM   #2 (permalink)
Baldman
Baldman's Avatar
Sportbike: '00 Honda CBR929/54 Y/B
Baldman is on a distinguished road
Take it back to him so he can finish the job properly.
Baldman is offline   Reply With Quote
Old 11-02-2004, 02:49 PM   #3 (permalink)
hybrid
RESIDENT ASSHOLE
hybrid's Avatar
Casino Cash: $450
Sportbike: too many to list
hybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond repute
You can use lacquer thinner if its not that bad. More than likely its over spray and not really fused to the metal very well. If the gas and or the lacquer thinner dont work I wouldnt really worry about it. You have a fuel filter for a reason and it will do its job. Anything that makes it past that should burn or be ejected out of the motor anyways.
The reason for the cap area not being sprayed is that he probably wanted to make sure the tank had even coverage and no seam where gas could get under the new paint. Some tanks are hard to find a place to seam it so gas will get under the paint and cause peeling and once it starts to lift its all over but the crying. I usualy just use a plug for my tanks but you never know what each painter has experienced. Fuel is a nasty thing to protect against.
www.walmartmovie.com
hybrid is offline   Reply With Quote
Old 11-02-2004, 08:04 PM   #4 (permalink)
Grashopr
Fumes Kill Brain Cells
Grashopr's Avatar
Casino Cash: $10124
is it paint, or is it sealer? If it's the color of the outside of your bike, without clear on it, that's PAINT. If its a grey, or a black color, it's most likely sealer. Sealer is impervious to gas, or SHOULD be (see the paint thread), paint however gets EATEN by gas, and will allow gas to run under the clear, above the sealer, all the way down the side of the tank.
I would say take it back to the painter and see what he says. Take pics and throw them up if possible.
CCS GP #303
Got Broken/New Plastics? Need them painted? $245 for two peices reapaired/repainted, full paintjobs starting at $475. Look HERE.
<<< Contact me on Yahoo Messenger (TSRGrashopr)
My Riding Resume
Grashopr is offline   Reply With Quote
