07-03-2009, 01:16 AM
#61 (permalink)
Casino Cash: $21328
Sportbike: 1993 Yamaha FZR600
Originally Posted by porky786
No on the shelf snake oil does what leaded race fuel will do
Thx, but Ill stick with KNOWN results , your not the first to doubt, its cool!
But I wouldnt waste my time and money with it, if I didnt see the results, and thats the simple truth , it too much trouble otherwise.
I once had a bike that had carbon buildup up in the exhaust a screen required to be cleaned every 11k , ran half a tank of leaded race fuel, under the lead oxide powder was shiny clean metal. That screen completely decarboned
Which on the shelf snake oil will do that?
Yes...argue with a racer.....(Lewd)
leaded race fuel is for tards who want to waste fuel and foul plugs
07-03-2009, 01:34 AM
#62 (permalink)
Casino Cash: $46688
Sportbike: 2000 Speed Triple, 2009 Daytona 675
Plugs hell. You should have seen the build up from running 93 without the tune for it on the back of my valves. There was some seriously crusty shit going on back there....the pistons weren't looking to hot either.
About 6 tanks of FI cleaner later they were all pretty again.
Luckily the Triple has no emissisions shit on it.
Thought for the day: There is more money being spent on breast implants and Viagra today than on Alzheimer's research. This means that by 2040, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
Old sig wasn't big enough.
07-03-2009, 02:06 AM
#63 (permalink)
Casino Cash: $16972
Sportbike: 2006 vfr 800
Tards and fouled plugs?
Lets clarify for the inexperienced,
out of the few hundred thousand miles on a leaded diet , I've had zero plug issues as a result of leaded fuel race fuel. Quite the opposite
Those that have issue with fouling plugs, are running fully undiluted on bike that isnt jetted for the fuel or cant use the octane level
My use for the lead is quite different, its only a supplement for decarbonization and upper cylinder lube, and it relatively small quantiy per tank.
Bashing something one has zero long term experience with , is much more retarded than a 25 cent cup of leaded race fuel as a supplemental diet.
I get a kick out of these threads though , you talk great, but you know nothing.
07-03-2009, 10:39 AM
#64 (permalink)
Casino Cash: $21328
can lead a horse to water..,
07-03-2009, 11:24 AM
#65 (permalink)
Casino Cash: $23176
Sportbike: 2008 KTM Super Duke
I haven't had a fouled plug since 1988. No races gas needed.
Also, no need for additives.
Ran most of my race bikes on pump fuel. Ran all of my street bikes on pump fuel.
Was it magic?
Plus, new bikes don't foul plugs like old bike did.
07-03-2009, 12:06 PM
#66 (permalink)
Casino Cash: $16972
(((((I haven't had a fouled plug since 1988. No races gas needed.)))))))))))
Lewd
And you shouldnt, Spark plug fouling has nothing to do with the leaded diet I run, nor creates it. But spark plus do recieve geogous decarbonization with my diet.
You are right though , you can run straight pump and have long life, I've not said you cant and most routine cases I have to go several tanks without my diet till I get back to the garage. I run the leaded race diet cause I see the benefits with emaculate decarbonization, and less valve recession.
really it only takes a couple cups,every other tank, to maintain and recieve the benefits.
I dont have to run it, like you, but I do , it acually runs me around $55 for five gal and lasts about 6 month, or 16 cups per gallon.
07-03-2009, 12:17 PM
#67 (permalink)
Casino Cash: $16972
Lewd
In my racing days , I never saw much value in racefuel either as far as performance on a stock bike. If id ran it long enough however, I may have noted, the beneficial power valve and exhaust decarbonization, which would have been a benefit.
Only when I started pressing solely on the street, in trying to prevent valve recession in small motors, did I dicovered these key side benefits.
Sorry to create all the conflict, your avenue and mine are different, but altleast we share for alittle amusement.
07-03-2009, 12:59 PM
#68 (permalink)
Casino Cash: $23176
That's a negatory that I said that. I see benefit in racing fuel and ran it during my race days.
My NOT seeing a benefit in race fuel on the street is directly related to a friend who builds motors for a living. He has won AMA nationals. He did my 675 and we had 2 tunes for it. Street and race. Street made 121RWHP and Race made 125RWHP.
07-03-2009, 04:06 PM
#69 (permalink)
It wasn't me
Casino Cash: $30917
Sportbike: '02 Honda VFR800
Originally Posted by yjsjin
on my kawi manual it said put 90+ octane one time i tried regular gas 85 octane and it seemed like it was harder to start and had less power now im using 91 octane only
Well that was pretty stupid wasn't it? But you corrected it properly. There is not universal octane for bikes just like there isn't for cars. You just go by what the manual says.
07-03-2009, 06:56 PM
#70 (permalink)
Casino Cash: $16972
Lewd,
I have a motor tuner friend also, and he only runs leaded race fuel on all his bikes, street or otherwise, also dumps the $15 oil after every ride. Which I think is a little nuts on the expense. But he isnt riding all the time either.
Was your set up between pump and racefuel ?
seems like a 3% difference on performance
07-03-2009, 08:05 PM
#71 (permalink)
Casino Cash: $13461
Sportbike: Custom framed Benelli 900 Sei, Norvil Commando 1k, Gilera Quattro Bulloni 500, a few other oddballs
All this talk about CR and nobody mentions flame path. Motorcycles have relatively small cylinder bores (usually less than 100mm) and modern, more efficient combustion chambers compared to cars. The flame path is generally much shorter than car engines.
AMA Superbikes and FX machines were running CR above 14.5:1 and guess what octane they were running...
VP MR9 fuel used until 2005 is about 87+93/2 = 90 octane.
VP MR11 fuel used up thru 2008 is about 90+96/2 = 92 octane.
Both contained lead.
Sunoco 260 GTX currently used in AMA Superbike is 98 octane, unleaded. Probably higher than needed, 260 GTX was an off the shelf unleaded racing fuel not specifically developed for Superbike engines. In fact, 260 GTX was developed for NASCAR engines in 2006. Thank Roger Edmondson for that little tie in. Betcha didn't know that!!!
07-03-2009, 09:00 PM
#72 (permalink)
Casino Cash: $16972
In fact, 260 GTX was developed for NASCAR engines in 2006. Thank Roger Edmondson for that little tie in. Betcha didn't know that!!!))
I knew they did away with the lead, still havent heard the real scoop on whether its been a positive or not for the motors.
I've seen nothing posted related to it anyway
07-03-2009, 09:22 PM
#73 (permalink)
Casino Cash: $23176
Lewd,
The bike was an AMA FX spec bike. 3% makes a difference at that level.
| Thread Tools |
| Display Modes |
Linear Mode
