Originally Posted by GApump
Yeah, my budget is going to be around 2-3 1/2k, I've seen a lot of nice GS500's and Ninja 500's in that range so I think I'll be able to find something fairly easily. So I guess if it has all the service records I can check out the tires, chain, sprocket pretty easily, but I don't know about the other stuff really. Outside of just riding it, listening to it idle and the things I mentioned above.
Here is some of the things I was told to look for when looking at a bike. I am by NO means an expert on bikes, but just throwing this out there and hopefully some of the vets will chime in.
Tell seller to make sure engine is cold when you get there... you want to hear it start when its cold. You can put your hand on the engine block itself to verify... it should be cold, not hot or even warm.
make sure there is no backfiring, or excessive smoke - at idle and on throttle.
just run your hands on the upper portion of the forks, make sure they're not leaking.
check the rubber. If it's a low mileage bike and the rubber is not original (look up what the original was online or ask a buddy), its probably an indicator that the previous owner beat up on the bike pretty good and ate through the tire.
check the chain - make sure its not rusty. sprokets shouldn't be worn.
check the brakes... buddy of mine showed me what brand new brakes looked like on his....they were about the same thickness as the rotor - don't know if that applies to all bikes or not.
umm, also if you're looking at a bike that was claimed to not be dropped or laid down... not only look at the fairings, but check the handle ends, the foot peg ends, mirrors, corner lights if they stick out for scratches/scuffs.
also, i've heard/read take a flashlight with you and check inside the tank - make sure its not rusty... dont know how necessary that is though.
lastly, weigh any of the problems you find. Use them to either help you walk away, or use them as a point of negotiation. Also, I do know this with buying/selling cars - never fall in love with a vehicle before you buy it. It usually leads to bad decisions and/or overlooked problems.
anyway, thats about all that comes to mind at the moment...thats the kind of stuff i looked for when shopping around. hopefully the more experienced will correct me and/or add to the list.
hope that helped.
-mike
