CycleGear.comAdvanstarMotorcycleShowsSportbikeTrackGearSoupy's PerformanceTuck & Run Clothing CoMcCoyMotorsportsAnnitori DistributingSee your ad here!
Old 09-01-2009, 11:03 PM   #1 (permalink)
chidarste
Casino Cash: $309
Sportbike: 2007 Suzuki GS500F
chidarste is on a distinguished road
Red face 2007 GS500F Engine rework
Hello all -
I'm new to this forum, joined not too long ago and did some light reading on here but now dire circumstances unforutunately have me both regretting and looking forward to this post. I regret what I did, namely run my GS500F without the magical elixir oil, so I'm pretty sure something froze. I removed the spark plugs so there was no compression, put the bike in 5th gear while on the center stand, and the rear tire did not move when I tried to rotate it. Description of breakdown upon request..
Ignoring the typical "what an idiot move" comments - which I can vouch I've given myself way too much since this happened - I've decided to turn this into a learning experience. What better time to spend opening up the engine to find out what's wrong? I'd call myself technically competent and handy at following service manuals, but without having done it I'm worried about pitfalls and missing things the first time around.
Basically, I'd like a discussion regarding what goes into an engine rebuild, from valve clearances to replacing gaskets to "don't forget to empty the oil before opening it up" to what's important in setting up a backyard open air area to work in.... Bullet points would be handy, and descriptions of what to look for when assessing a seized engine would be extremely valuable.
This isn't a how-to, so hopefully I don't have to screen it, but if there's any additional knowledge I can garner prior to opening the engine then it'd be much appreciated. I ain't skeered, I got the service manual, but the pics are fuzzy at best ;)
Thanks for any and all input!
chidarste is offline   Reply With Quote
Old 09-01-2009, 11:25 PM   #2 (permalink)
boner
Halfsharkalligatorhalfman
boner's Avatar
Casino Cash: $45368
Sportbike: Ducati s2r1k, old honda cb400t
boner is on a distinguished road
i don't have much advice, other than package and label parts and hardware as it is removed and lay the parts out on a big table. once tear down is complete you have to assess the situation and decide if you want to reassemble.
i have done one tear down on an oil starved motor (honda f4i) and it was trash once we tore it down. the cylinders, crank and cam bearing surfaces were deeply scored. it was cheaper to pick up a used motor than to even think about sourcing parts to repair it.
...Until we see each other once more on the path along the way
boner is offline   Reply With Quote
Old 09-02-2009, 12:50 AM   #3 (permalink)
YZFHEFF
YZFHEFF's Avatar
Casino Cash: $21027
Sportbike: YZF750 & 1000RR
YZFHEFF is an unknown quantity at this point
If you ran it long enough w/o oil for it to seize then you might as well just start looking for a replacement.
Go ahead and tear down the one you've got while you're waiting on the replacement, for the experience. You'll probably find all kinds of galled-up parts like main/rod bearings.
How in the hell did you manage to run it w/o any oil in it? What a shame.
Best of luck with it.
When in doubt gas it
YZFHEFF is offline   Reply With Quote
Old 09-02-2009, 05:03 PM   #4 (permalink)
YZFHEFF
YZFHEFF's Avatar
Casino Cash: $21027
Suzuki GS500 GS 500 ENGINE MOTOR TRANNY VIDEOS 3084 MI:eBay Motors (item 370254134589 end time Sep-08-09 18:45:00 PDT)
Old 09-03-2009, 01:12 AM   #5 (permalink)
chidarste
Casino Cash: $309
First off, I realize now this is the How-To section: eek! Help me Fix It is where I wanted to put this, musta posted this late at night If this can be moved due to the responses, great; I can delete and repost also if such is the convention.
Thanks YZF for the tidbit of info. The reason it didn't have oil is, typically, user error, and it's embarrassing. That's why I'd like to learn from the mistake, rather than pump a bunch of money into it (and then not pump oil into it later due to ignorance). The more comfortable around a bike, the more likely I'm able (and willing) to perform basic maintenance on it. The GS500F is not a complicated bike by any means, but it's an introduction to self-maintenance of a machine... if given the chance.
When you say galled-up parts, what exactly is a give-away? From random reading I've gathered scorched marks, dark marks like oil burnt on the metal, etc... Oh yeah, lack of movement on hinges What is a good guide when disassembling an engine for filtering out which pieces are still good and which should be replaced?
Also, the ebay post was nice - I'd seen a craigslist ad for $600 dollars in SanFran for an engine which was the same year and less miles... Unfortunately I'm on the opposite coast I'm going to be looking, but if there's a chance to fix this under or close to the cost radar of a new engine I'm damn well going to do it. Getting back to riding is a priority, but understand a larger bike is definitely where the road is leading.
-d
Old 09-03-2009, 01:55 AM   #6 (permalink)
YZFHEFF
YZFHEFF's Avatar
Casino Cash: $21027
You'll find discolored metal and lack of tolerances. Crank/rod bearings etc may be fused together. I tore apart an old RM125 engine once that had revved out on it's side 'til it died and the crank and rod were fused into one piece.
The cylinder walls will likely be scored all to hell too.
I'd bet you'd likely spend two or three times as much as a used engine to rebuild yours. On just the parts.
Then a couple of special tools will be required like a dial indicator, mics, and a good torque wrench or two.
I'm not trying to discourage you from rebuilding just because. I really believe it would be a much more expensive, not to mention headache-filled proposition.
Ron Ayers $
CRANKSHAFT - $485.19
ROD ASSY, CONNECTING - $65.54 (x2)
PISTON SET - $80.37 (x2)
PIN, PISTON - $8.68 (x2)
etc., etc. just on the bottom end. Then there's the head.
Keep your eye open for wrecked ones too. Perfect application of a titleless or salvage bike.
Cheers
Old 09-03-2009, 01:59 AM   #7 (permalink)
YZFHEFF
YZFHEFF's Avatar
Casino Cash: $21027
P.S. - Things like this are why everybody needs at least two ready-to-go bikes in the garage.
Old 09-03-2009, 02:00 AM   #8 (permalink)
SqDancerLynn1
Casino Cash: $18766
Sportbike:
SqDancerLynn1 is on a distinguished road
Finding a used engine and even adding the cost of shipping would be cheaper than a complete rebuild
SqDancerLynn1 is offline   Reply With Quote
Old 09-05-2009, 02:31 PM   #9 (permalink)
chidarste
Casino Cash: $309
qft
I am about to drop the engine (going to need to do that regardless of whether it's getting fixed or replacing it, so figured it's a good step going forward) and ran into a bit of a snafu. It looks like the radiator is attached to the engine, and the permanent part of the frame, which doesn't get lowered. However, nowhere in the service manual does it state whether to remove it from the engine or the frame; additionally, the pictures omit the bolts by the front tire which attach the frames together, which also happen to attach to the radiator. I think in order to save a bit of oil leaking I'm going to remove it from the frame - unless there's other sage advice?
There is a guy in Indianapolis that has some spare parts, all for the cost of a Jimmy John's sammich! He doesn't have all the parts, but may provide a cushion to the cost of repairing it meself.
Thanks again for the feedback!
-d
Old 09-05-2009, 03:04 PM   #10 (permalink)
boner
boner's Avatar
Casino Cash: $45368
radiators are fragile. i would drain all fluids, and remove the radiator first before dropping the engine.
Old 09-05-2009, 03:55 PM   #11 (permalink)
ghostriders999
ghostriders999's Avatar
Casino Cash: $24812
Sportbike: 07 GSXR1000, 06 600Katana, 05 Ninja500R, 03 Buell Blast
ghostriders999 is an unknown quantity at this point
Those motors are relatively cheap and if im not mistaken fits several years back,, so it should be cheaptr to replace
STRICKLY BUSINESS
ghostriders999 is offline   Reply With Quote
Old 09-06-2009, 08:01 AM   #12 (permalink)
YZFHEFF
YZFHEFF's Avatar
Casino Cash: $21027
The radiator you're referring to is actually an oil cooler. I know, a radiator for oil, just semantics.
It would be a toss-up I guess to remove or leave attached. It's got to come off at some point so I would probably just drain the oil and take it off first. I think it would get damaged less this way. I can just see it flailing around and banging into stuff while you're wrangling the engine out. If you do leave it attached I would tape flat cardboard cut to fit on both sides to protect the fins.
That Jimmy Johns dude sounds like he's selling all the bad parts. Why would you want?
Have fun with it and watch your knuckles. ;)
Old 09-06-2009, 08:42 AM   #13 (permalink)
LDS
Unregistered User
LDS's Avatar
Casino Cash: $31583
Sportbike: 05 FZ6, 99 SV650, 01 EX250
LDS is on a distinguished road
I have a partially disassembled GS500 motor in my garage. It burned the valves on one cylinder due to the previous owner not checking the valve clearance.
It could be yours for $250 plus shipping.
I too, have nothing of value to add to this thread...
LDS is offline   Reply With Quote
Old 09-08-2009, 12:43 AM   #14 (permalink)
chidarste
Casino Cash: $309
GS500E or F? How many miles does it take for a valve clearance to rear its ugly head? /curious
PS -> Update since I'm responding anyways... The piston rod is fused to the crankshaft. When the shit hit the fan, the oil light had came on and my buddy dropped by after to gave me a couple quarts... engine started up and I decided to drive off, being hawked by a cop causing a traffic scene and all... seems that was a mistake, things didn't cool off, and the fusion happened. (Why can't we harness it for science, dammit!) Regardless, it was definitely an experience opening up the engine and spotting the blackened metals. I might even add pics Particularly because the head of the pistons were black... and the conical portion I can understand, but shouldn't the liner be somewhat clear?
LDS - Lemme know what can be salvaged (sorry, I'm a noob) and maybe there's a way to get the most out of the least effort.
-d
Old 09-08-2009, 01:30 AM   #15 (permalink)
Nightfall
DISCOTRASH
Nightfall's Avatar
Casino Cash: $29946
Sportbike: '99 Suzuki GSF600S Bandit
Nightfall is on a distinguished road
Originally Posted by chidarste View Post
GS500E or F?
Same engine in both bikes, E & F just refer to the naked and faired versions of the bike.
Nightfall is offline   Reply With Quote
06 covers on 05 engine WillWorkForGrapeFanta FZ6 Mods 1 04-24-2008 08:10 PM
Engine Popping On Deceleration... Gimpdiggity General Sportbikes 27 04-15-2008 03:41 PM
Engine temperature / cooling fan DavidHopkins FZ6 13 04-27-2007 03:41 PM
Future of BMW Motorrad and the Boxer Engine R1100S-Rider BMW 3 04-16-2007 07:27 AM
FS: 2000 Yamaha R1 Builder Engine merdoc Parts For Sale 0 11-08-2004 12:09 AM
