Register Subscribe Casino Garage FAQ Members List Calendar Arcade Blogs Search Today's Posts Mark Forums Read
BluTek HelmetsMcCoyMotorsportsMotorcycle.com Classifieds!SportbikeTrackGearPartsPitStopSee your ad here!
LinkBack (5) Thread Tools Display Modes
Old 12-02-2007, 11:55 PM   5 links from elsewhere to this Post. Click to view. #1 (permalink)
94rf900r
Your mom goes to college
94rf900r's Avatar
Gameroom cash: $28714
Sportbike: 94 suzuki rf900r
Default How To Polish Aluminum
I started writing a how to a while ago and never finished it then i seen some guys asking how to polish shit so I went ahead and finished writing it. This is how I Polish and it gives me near chrome results. I'm sure other people will have suggestions and revisions so post em' up.
Materials Needed:
Sand paper (waterproof kind)
Bucket of water or a sink
Rags
Polishing wheel (I like the small spiral sewn wheels that fit in a drill)
Compound (some people use rouge but just about any metal polish will
work, some are better than others, I use Wenol, and I highly recommend it)
Lots of time, patience, and work
The object is to make the surface as smooth as possible. The reason polished metal shines is that there are no scratches in the surface so all the light hitting it gets reflected in the same direction creating a mirror effect. Rough metal reflects the light in different directions making the surface look dull.
I recently polished my forks so I’ll use them as an example.
Prep Work:
Remove paint with aircraft stripper, this can be purchased at pretty much any auto parts, or painters supply store, fine steel wool will also help with the stripping process. Oven cleaner will remove anodizing, so will sanding it will just take longer. Powder coating needs to be baked off using high heat, this is a specialized procedure.
It’s a good idea to remove bearings from wheels and swing arms so shit doesn’t get into them.
Step 1: First Grit
All sanding done is wet sanding, where you have a bucket or sink full of water that you are constantly dipping the sandpaper into to keep it clean.
In this step you want to get all the scratches, nicks, and left over paint off the surface of the metal. My forks had a few rough spots in the back so I had to use 150 grit on these spots to smooth them out. Next I went over the 150 spots and the whole rest of the fork with 240 until it was all uniform.
Getting into tight spaces can be a little difficult. I usually use something like a paint stick or an artist style paintbrush and just wrap the sand paper around the end to get into places my fingers can’t reach. Obviously you can use what ever you think will work the best these are just some suggestions.
Step 2: Second Grit
This should be a couple hundred grits finer. Try and use the highest grit that you can, just remember the object of this step is to erase the scratches from the previous step, so if you choose too fine of a grit you will either be there all day trying to sand out step one’s grit or you wont sand it out at all and the final finish will look like garbage. The quality of the final finish depends greatly on your patience, MAKE ABSOLUTELY SURE YOU SAND ALL THE PREVIOUS GRITS SCRATCHES OUT! For step 2 of my forks I used 320.
Step 3: Continue sanding
Repeat step 2 with another finer grit and continue doing this until you get to 1500 or 2000. On my forks the grit order went from 320 – 400 – 600 – 800 – 1200 – 2000. You can get away with skipping some of the grits if you take your time I just like knowing I completely covered the previous grits scratches.
Step 4: Polishing
Now just polish with metal polish or rouge. You will need to do this mechanically, by hand just wont get it good enough. The compound is actually a very fine abrasive that further smoothes out the surface and your arm and had just can’t move fast enough to do the job. I use a spiral sewn buff in a drill with Wenol polish. You can buy felt bobs for the hard to reach places, they are just small polishers that fit in a drill some are half circle or cone shaped, they are great for corners.
If you take your time, and it will take a lot of time to do it right, the final result will look like chrome. (If the results are less than satisfying try using a different compound, again I highly recomend Wenol it produces a very nice shine and protects the finish pretty well)
I have recently talked to a few different powdercoaters and they have told me that you can powdercoat over polished aluminum. they said that it will dull the surface slightly, i'm still looking into it and am going to have something done as a test to see how slightly dull it gets in the near future.
Heres some pictures, a before, halfway there, after, and a pic of a spiral sewn buff:
Originally Posted by Silic0nJ3sus View Post
If you want an absolute mirror finish, after you've hit it with varying degrees of sandpaper, use diamond paste. You can order it online, an no it's not very cheap. It is, however, the best way to get a true mirror finish. Diamond paste is used on aluminum blocks to produce a perfect mirror finish for use in high powered lasers because a standard mirror would be destroyed.
I wish my grass was emo so it would cut itself
LinkBack to this Thread: http://www.sportbikes.net/forums/how-tos-section/375072-how-polish-aluminum.html
How To Acura Rl Wheel Bearing Replacement, How To Change A Rear Wheel Bearing On A 1998 Dodge Stratus, Harley Wheel Bearings - Mahjongtitans This thread Refback 03-11-2009 05:34 AM
Painting UIM - Grand Am Owners Club Forums This thread Refback 12-13-2008 06:29 PM
Painting UIM - Grand Am Owners Club Forums This thread Refback 12-13-2008 06:25 PM
Painting UIM - Grand Am Owners Club Forums This thread Refback 12-13-2008 06:15 PM
How-To's Section - Sportbikes.net This thread Refback 12-03-2007 03:02 PM
How To Polish aluminum 94rf900r Performance and Customizing 35 03-30-2010 02:24 AM
What do I need to polish this rim? Cabanaboy Help Me Fix It 4 08-15-2007 01:31 PM
Polishing Aluminum Ernesto Performance and Customizing 0 09-16-2004 10:59 AM
Can you polish an exhaust can? Flash6R General Sportbikes 6 07-21-2004 09:25 AM
Clearcoat over polished aluminum? Joe Performance and Customizing 14 07-20-2004 08:35 AM
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
