officer 737 already made an article about this topic (he even has the same bike as me), but i'll post up my little project as well. i bought the shogun frame sliders, bar ends, swingarm spools and a pit bull rear stand. alright, here goes.
1st picture: my bike, finally outta the shop.
2nd pic: bolt that the frame slider will go on the right side of bike, no modification needed. just pull that one out and put frame slider and bolt in.
3rd pic: right side with slider on.
4th pic: another pic of right side with slider on.
5th pic: left side of my bike. as you can see, there is no exposed bolt to put the slider in. so, cuts have to be made to the fairing.
**(please don't reply to this thread until i am finished, there are about 20 pictures to load up, so around 4-5 pages, thanks guys)
ASMA amateur #121
GF&T wrecking ball
If you don't eat your meat, you can't have any pudding.
6th pic: left side of my bike, NAKED!
7th pic: bolt that will come out for the frame slider.
8th pic: laser level (with dot) to mark the spot on my fairing.
9th pic: red laser dot lined up in center of bolt.
10th pic: fairing back on. other people have mentioned using masking tape to keep the paint from chipping. it also makes it easier to see the red dot, which doesn't show up well on shiny black paint. now make a dot with a marker.
ASMA amateur #121
GF&T wrecking ball
11th pic: i just drilled the fairing out using a 1" bit (not really a drill bit, has the sharp point and sharp edges, i'm sure someone can help me out on it). then i just used a dremel tool to clean it up.
12th pic: there's basically the end product. not the cleanest hole ever (and i've seen some very nice holes, but that's a different discussion! ). it'll be covered by the slider anyways, so it doesn't have to be perfect.
13th pic: there's the end product for the right side.
14th pic: project done, took maybe an hour. easy as hell guys, i just wish i would have had them on before my wreck! so use me as an example. if you don't have sliders on your bike yet, do it! its easy and it can save you a lot of money.
ASMA amateur #121
GF&T wrecking ball
__________________ William (Will) SBN
R.I.P. Krazy Hawaiian-you will be missed brother!!
SUPER MODERATOR
Questions, Concerns, Issues please PM me!
Bike Mods:CarbonFreak Windscreen, Power Commander, Galfer Superbike Brake Lines, Carbone Lorraine Brake Pads, BMC Air Filter, Motovation Frame Sliders, Redlinestands Swingarm Spools.
WERA #951
NESBA #951 www.dropthehammerracing.com Hemmet-cam LEO-LEESTA!!!
Audentes Fortuna Iuvat!-Virgil
POLICE K9: GO AHEAD AND RUN, IT'S YOUR ASS!
SHUT UP!! I can only listen to one person lie to me at a time!!-Officer737
2006 Graduate of the Kevin Schwantz Suzuki School (race school)
"Putting my foot in your ass since 2005!"
Joe My Resume
Need a better riding position? Check out www.convertibars.com. They are great!
Past bikes: '82 Yamaha Maxim 750, '89 Kaw. ZX7, '94 Kaw. ZX9R, '01 Yamaha FZ1, 04 Kaw. EX-250 ~ over 12 years & 90,000miles of riding experience.
Dont use speedbore bits on hard brittle plastics. The best thing to use is a hole saw. But use the drill in reverse, it will "melt" the hole out, perfect circle with no burrs and very clean and smooth. Make sure you start drilling on the exterior or the plastic, and make a pilot hole first to ensure you will have the drill in the right spot and to help guide it in. This is the best way to cut holes for sliders.
Dremels are probably the worst thing to use to cut holes, you will never get a clean circle and you run the risk of slipping and seriously scratching up your bodywork.
yeah man, like i said i just used the dremel to clean up a bit. there was some melting using the wood bore bit (thank you kevinwilly). however, it just broke off, then the dremel comes in to clean it up.
ASMA amateur #121
GF&T wrecking ball
