Motoworld Inc
Motoworld IncSoupy's PerformanceJardineProducts.comTuck & Run Clothing CoMcCoyMotorsportsBluTek HelmetsAnnitori DistributingBritish Motorcycle Gear
Allstate
SportbikeTrackGearSee your ad here!
Closed Thread
Old 03-20-2006, 10:01 PM   #1 (permalink)
madman748
madman748's Avatar
Casino Cash: $1599
Sportbike: '99 748S; '00 GSX-R750; '03 749R
madman748 is on a distinguished road
Default Cleaning and lubricating your chain.
Here's a basic procedure to clean and lubricate your chain:
1. Get a plastic spray bottle from the hardware store and fill with kerosene.
2. As you rotate the wheel, spray the kerosene on the chain. Concentrate mostly on the rollers.
3. Rotate the wheel for a minute or two to work the kerosene into the rollers. Remember with o/x-ring chains, you are mainly concerned with the rollers.
4. Take a clean dry rag and rub down the chain until clean. If the chain has excessive grime, use an old toothbrush or a Grunge Brush. Once done the chain should shine!
5. As you rotate the wheel, spray a quality chain lubricate (NOT WD-40) on the inside of the chain, specificaly the edge of the rollers. Note that not all lubricates are applied in the same fashion. Follow the instructions for application on the back of the product.
6. Apply a light coating of chain lubricant to the outside of the chain. Remember, it's all about the rollers, the outside only needs a protective film for rust protection.
7. Take another clean rag and moisten with kerosene. Rub down any areas of overspray.
8. Repeat the process every three or four rides. It's easier when you stay on top of it.
9. IMPORTANT: THE EDGES OF THE ROLLERS SHOULD ALWAYS APPEAR WET OR BE FREE OF GRIME. IF YOUR CHAIN LOOKS DRY, THEN YOUR CHAIN IS NOT PROPERLY LUBRICATED.
I'm partial to the following chain lubricants:
http://www.fuchslubricants.com/silkolene/maintain.htm
http://www.maximausa.com/products/ch...s/chainwax.asp
And for persons who don't know what a Grunge Brush is:
http://www.finishlineusa.com/products/grunge-brush.htm
Good luck.
WERA Expert #243, NESBA Adv #243/#266
1995 Ducati 900SS/CR (Street)
1999 Ducati 748S, Yellow (Street)
2000 Suzuki GSX-R750, Red/White/Blue (Track)
2003 Ducati 749R, Red, No. 296 (Track)
madman748 is offline
Old 03-21-2006, 10:16 PM   #2 (permalink)
DazalC
World Superbike Champion
DazalC's Avatar
Casino Cash: $20019
Sportbike: 03/Kawasaki/ZZR-250
DazalC is on a distinguished road
where do u guys get kereozene from? can i just use regular gas? or wd40?
edit: btw, i found this on another thread: http://www.webbikeworld.com/t2/motorcycle-chain-lube/
it was expained really well, with great detail.
DazalC is offline
Old 04-02-2006, 08:27 PM   #3 (permalink)
Kila-Beave
Kila-Beave's Avatar
Casino Cash: $12650
Sportbike: 2005 CBR F4i
Kila-Beave is on a distinguished road
Lowe's, Wallmart, Camping Stores... some gas stations in the country still sell kerosene from a pump outside. I found a gallon of pure kerosene (for the little portable heaters) at Lowe's for $7.
--- Beave ---
Kila-Beave is offline
Old 04-03-2006, 03:34 AM   #4 (permalink)
ZXLNT
Kawpuke Extraordinare!
ZXLNT's Avatar
Casino Cash: $3909
Sportbike: ZX12.7R/ZX-14
ZXLNT is on a distinguished road
No dont use gasoline, its way way to flammable and it will damage the rubber O-rings..
ZXLNT is offline
Old 04-17-2006, 11:18 AM   #5 (permalink)
Dawson-ZX
Dawson-ZX's Avatar
Sportbike: 2005 Kawasaki ZX-10R
Dawson-ZX is on a distinguished road
How about cleaning it by spraying/wiping with brake/parts cleaner... it's pretty flammable too though.... don't know if it'll damage rubber...
Dawson-ZX is offline
Old 04-17-2006, 03:50 PM   #6 (permalink)
bumblebee
bumblebee's Avatar
Casino Cash: $55210
bumblebee will become famous soon enough bumblebee will become famous soon enough
you need a mild solvent like kerosene or WD-40...Also, after you think you have dried it, and BEFORE you put lube on it...use your air compressor and blow down through the chain while holding a towel under it...Keep blowing and rubbing the chain, while spinning the tire, changing the towel frequently until the towel is clean while rubbing...
Any solvent left in the rollers or sideplates will prevent the lube from sticking and will "gum" up the chain again...
When the government's boot is on your throat, does it matter if it is a boot from the left or a boot from the right?
bumblebee is offline
Old 11-27-2006, 12:45 AM   #7 (permalink)
crx81
Ride Naked
crx81's Avatar
Casino Cash: $18902
Sportbike: SOLD... looking for something new.
crx81 is on a distinguished road
I was told that diesel was the same thing. Can anyone verify this?
crx81 is offline
Old 11-27-2006, 09:06 AM   #8 (permalink)
bumblebee
bumblebee's Avatar
Casino Cash: $55210
gas, diesel and kero all come from crude...they are just at different steps in the refining process...
Old 12-25-2006, 12:05 AM   #9 (permalink)
Colin
Superbike Champion
Casino Cash: $2259
Sportbike: '07 GSXR750
Colin is on a distinguished road
Close, but not quite. Diesel has more lubricity than kerosene.
Colin is offline
Old 12-25-2006, 12:08 AM   #10 (permalink)
crx81
Ride Naked
crx81's Avatar
Casino Cash: $18902
Nothin' wrong with a little extra lube!
crx81 is offline
Closed Thread
